Psychlist
RPi4 Buster Kernel Mismatch Error
Fri Aug 16, 2019 3:07 pm
I'm getting a repeated "Pending kernel upgrade!" message during updates that is not resolved by rebooting. The output of needrestart is as follows:
pwt@raspberrypi-4:~ $ needrestart -k
Scanning linux images...
Running kernel version:
  4.19.58-v7l+
Diagnostics:
  The currently running kernel version is not the expected kernel version 4.19.58-v7+.
Restarting the system to load the new kernel will not be handled automatically, so you should consider rebooting. [Return]
I'm running a fully updated Raspbian Buster on a 4GB RPi 4. Any ideas?
Thanks!
ShiftPlusOne
Re: RPi4 Buster Kernel Mismatch Error
Mon Aug 19, 2019 9:37 am
Whatever is giving you that message, it's not installed by default. I don't know where it's getting its information from, but it probably expects a standard debian kernel setup, which is not something we use.
Psychlist
Thu Aug 29, 2019 5:50 pm
Thanks for the response. FWIW, this was a standard Raspbian Desktop install, downloaded from the standard place. The problem emerged at some point after a normal update.
