TwoTerriers
Cannot connect to CUPS
Tue Aug 13, 2019 3:13 pm
Hi
I'm new to the Raspberry Pi and to this forum so apologies if this is in the wrong part of the forum and for what is probably a very simple problem.
I'm trying to connect my Raspberry Pi to a printer.
After a couple of attempts I have installed CUPS.
I have typed http://localhost:631 into the address bar - in my case http://31.53.34.205:631 and ... not a lot happens. It does not connect
Whilst I have double checked my IP address - I'm pretty certain that it is not my usual one.
Any suggestions gratefully received.
Re: Cannot connect to CUPS
Wed Aug 14, 2019 12:49 am
Hi
Personally I use the CUPS GUI:
sudo apt update
sudo apt install system-config-printer cups
adieu
TwoTerriers
Sun Aug 25, 2019 6:08 pm
Thanks for the suggestion
I've installed the CUPS GUI.
I've connected to the printer and can see it (it is connected via a USB)
However if I print a document, the Brother DCP-7055 printer indicates that it is receiving data - and that is it. Nothing happens.
The printer server indicates that the file has been printed.
I have subsequently checked the printer with a W10 laptop and it is working.
Suggestions? Thanks
Sun Aug 25, 2019 6:23 pm
Suggestions? Thanks
You will likely need the correct drivers, it is supported by brlaser package
sudo apt update
sudo apt install brlaser
https://github.com/pdewacht/brlaser
adieu
bls
Sun Aug 25, 2019 7:12 pm
Hi
In the first case (localhost:631) are you running the browser ON the Pi or on another computer? In the second case (31.53.34.205:631) where did you get that address? That is a public IP address, not an address on your local network, so no surprise that fails.
Can you bring up a terminal on the Pi and type: 'sudo netstat -ltpn' (that's a lower case L, not a digit 1) and post the output here?
TwoTerriers
Mon Aug 26, 2019 9:14 am
Thanks for your reply
sudo apt update ..... Done
sudo apt install brlaser .... Tried this and
"Reading package lists... Done
Building dependency tree
E: Unable to locate package brlaser
As the printer was usb connected and switched on - beyond me
So I tried "Add/Remove Software - printer-driver-brlaser-41"
It installed. Tried printing. Data transferred. No printout.
I'm afraid that - https://github.com/pdewacht/brlaser - is completely beyond me. If the answer lies there, then I'm going to need help.
Thanks in anticipation
Mon Aug 26, 2019 9:57 am
Apologies, try
sudo apt update
sudo apt install printer-driver-brlaser
adieu
TwoTerriers
Mon Aug 26, 2019 11:07 am
Pi reports that latest version is already installed
