pcfreak49
crontab update
Sun Aug 04, 2019 1:33 pm
I have a problem I want crontab to perform an update, but that doesn't work
0 20 * * * sudo apt-get update
pcmanbob
Re: crontab update
Sun Aug 04, 2019 1:44 pm
So first off if you want to run a command in cron as root then use
sudo crontab -e
that way you are running the command as root and you don't need the sudo command in the line.
second how do you know its not running ?
as cron runs things in a background there will be no output to the screen.
pcfreak49
Re: crontab update
Sun Aug 04, 2019 1:51 pm
Yes I know via crontab -e and then 0 16 * * * sudo apt-get update && sudo apt-get upgrade, && sudo reboot but it doesn't work
knute
Re: crontab update
Sun Aug 04, 2019 5:22 pm
If apt-get upgrade stops and asks for input it isn't going to get any and will hang right there forever.
One of the easiest ways to know that cron has done a job for you is to have it email you the output from the command. To do that you need to install a mail system. The simplest and easiest way I think is to install sendmail and mailutils. No configuration is required except to create a fully qualified domain name in /etc/hosts/ before you install sendmail. Just change the last line to something like:
127.0.1.1 raspberrypi raspberrypi.local
When the crontab does a job and there is output it will be mailed to the crontab user. Use the mail command to read your mail. If you want to root's crontab output mailed to pi, just put this line in /etc/aliases:
root: pi
While the sudo command works from pi's crontab I agree with the other fellow that I would put the commands in root's crontab.
Re: crontab update
Sun Aug 04, 2019 5:35 pm
If you want auto update there are easier ways than hacking around in root's crontab.
sudo apt install unattended-upgrades apt-listchanges
sudo dpkg-reconfigure -plow unattended-upgrades
Or manually with sudo nano /etc/apt/apt.conf.d/20-auto-upgrades
APT::Periodic::Update-Package-Lists "1";
APT::Periodic::Unattended-Upgrade "1";
This is a doctor free zone.
pcfreak49
Re: crontab update
Mon Aug 05, 2019 6:57 am
the pi user has been deleted for security, have created a new user crontab works via date to save a file date >> /home/tim/date.txt
the intention is to plan these assignments
first take a backup at 5am and then a full update at 6am and then do it clean at 7am and then restart the pie every day
root: pi
pcfreak49
Re: crontab update
Fri Aug 09, 2019 6:57 am
I have several raspberry pi that is used for home automation therefore it must always be up to date, and another for the studies
crontab -e already looks like this
but is not working yet
#update
0 6 * * * sudo apt-get update && sudo apt-get -y upgrade && sudo rpi update && $
#clean
0 7 * * * sudo apt-get autoremove --purge -y && sudo apt-get remove --purge -y
pcmanbob
Re: crontab update
Fri Aug 09, 2019 7:30 am
One thing you should not be doing is running " sudo rpi update " on an in-service system, it will load what may be an unstable updates , its only to be used to fix a specific problem if instructed and even then it may lead to a corrupt OS which you would be on your own in trying to recover.
pcfreak49
Re: crontab update
Fri Aug 09, 2019 7:39 am
Okay but how can you automatically download and install the updates please
pcmanbob
Re: crontab update
Fri Aug 09, 2019 7:44 am
have you not read Dougie's post above ?
pcfreak49
Re: crontab update
Fri Aug 09, 2019 7:48 am
yes but only 0 6 * * * sudo apt-get update && sudo apt-get -y upgrade
Cancelor
Re: crontab update
Fri Aug 09, 2019 8:10 am
It looks like you also missed the first reply ''you don't need the sudo command in the line''
sudo crontab -e
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
RaTTuS
Contact: Twitter YouTube
Re: crontab update
Fri Aug 09, 2019 8:22 am
just do
https://www.raspberrypi.org/forums/view ... f#p1513135
everythying else is wrong on so many levels
1) don't do sudo in cron
2) don't do apt update in cron
3) apt upgrade in cron will bock as soon as it asks for anything [use -y yo get around this but not in cron]
4) never use rpi-update ever really unless you are debugging something specific , and never on a production machine
5) do read and understand useful comments
6) it's not wrong to ask questions
Covfefe
pcfreak49
Re: crontab update
Fri Aug 09, 2019 8:25 am
I read somewhere else that I had to do that
just do
Re: crontab update
Fri Aug 09, 2019 8:31 am
pcfreak49
Re: crontab update
Fri Aug 09, 2019 8:45 am
can you also bless which day and hour the update will take place please?
Re: crontab update
Fri Aug 09, 2019 8:47 am
I don't know (I wouldn't dare to use that), go and read the man page. It's driven off a system crontab.
https://wiki.debian.org/UnattendedUpgrades
