i0ntempest
Weird HDMI Audio Problem on Pi 4 (PulseAudio)
Thu Aug 01, 2019 9:59 am
Hi guys,
So I just got my new 4GB Raspberry Pi 4 today and almost finished migrating from Pi 3B+. The performance increase is just mind blowing.
However I do have a few problems and one of them is about audio. I have PulseAudio installed to use with GNOME, however the volume keeps going up and down by itself when playing music. I have commented out
module-udev-detect
section and loaded the drivers statically in
default.pa
, because if not the output will be mono. Using
module-detect
yields the same result.
If I specify an audio device by doing
mplayer -ao alsa:device=hw=0,0 some.mp3
the file will play without any problem, no volume fluctuates and no distortion. However if I try
pactl set-default-sink alsa_output.hw_0_0
It will say
Failure: No such entity
This setup worked really well on my 3B+ but is broken on 4. Anyone has had similar problems like this?
More info will be provided below. Any help is appreciated!!
Result of "pacmd list-sinks":
pi@raspberry-pi:~ $ pacmd list-sinks
1 sink(s) available.
  * index: 0
        driver: <module-alsa-sink.c>
        flags: HARDWARE DECIBEL_VOLUME LATENCY FLAT_VOLUME DYNAMIC_LATENCY
        state: RUNNING
        suspend cause: (none)
        priority: 9000
        volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
                balance 0.00
        base volume: 65536 / 100% / 0.00 dB
        volume steps: 65537
        muted: no
        current latency: 80.57 ms
        max request: 15 KiB
        max rewind: 15 KiB
        monitor source: 0
        sample spec: s16le 2ch 44100Hz
        channel map: front-left,front-right
                     Stereo
        used by: 1
        linked by: 1
        configured latency: 90.00 ms; range is 0.50 .. 743.04 ms
        module: 5
        properties:
                alsa.resolution_bits = "16"
                device.api = "alsa"
                device.class = "sound"
                alsa.class = "generic"
                alsa.subclass = "generic-mix"
                alsa.name = "bcm2835 ALSA"
                alsa.id = "bcm2835 ALSA"
                alsa.subdevice = "0"
                alsa.subdevice_name = "subdevice #0"
                alsa.device = "0"
                alsa.card = "0"
                alsa.card_name = "bcm2835 ALSA"
                alsa.long_card_name = "bcm2835 ALSA"
                alsa.driver_name = "snd_bcm2835"
                device.bus_path = "platform-soc:audio"
                sysfs.path = "/devices/platform/soc/soc:audio/sound/card0"
                device.form_factor = "internal"
                device.string = "default"
                device.buffering.buffer_size = "131072"
                device.buffering.fragment_size = "131072"
                device.access_mode = "mmap+timer"
                device.description = "Built-in Audio"
                device.icon_name = "audio-card"
Content of ".asoundrc"
pcm.!default {
        type hw
        card 0
ctl.!defalt {
        type hw
        card 0
PulseAudio config files attached.
Archive.zip
(4.01 KiB) Downloaded 14 times
mentaluproar
Re: Weird HDMI Audio Problem on Pi 4 (PulseAudio)
Wed Oct 09, 2019 2:57 am
Any solution for this? I only see analog mono but one of the hdmi puts out audio. It’s really screwy.
matzrm
Wed Oct 09, 2019 8:56 am
I'm in the same situation, pulseaudio shows only analog mono, but using amixer cset numid=, I can switch from analog to hdmi.
Anyone know why pulseaudio shows only one sink?
