AaronRPI
Grading app?
Thu Jul 25, 2019 12:47 am
Hello, how do i create an app/program that will put a Roman numeral after a number like this
100= ll
99=llll
98=l
Is there any way to do this with libreoffice excel?
All help is appreciated.
"I will go anywhere as long as it is forward" David Livingstone
W. H. Heydt
Re: Grading app?
Thu Jul 25, 2019 1:34 am
One can certainly write a program that takes a decimal value in a puts Roman Numerals out. The conversion is pretty simple. I would not that your examples are not actually equalities, though.
100 --> C
99 --> LXXXXVIIII, or LXLIX, or some other possibilities
98 --> LXLVIII
Not sure where the values you show came from or what they're supposed to be.
Paeryn
Re: Grading app?
Thu Jul 25, 2019 4:49 am
100 --> C
98 --> LXLVIII
Your 90s aren't standard, general rules are
I can only prefix V and X (1 before 5 or 10),
X can only prefix L and C (10 before 50 or 100),
C can only prefix D and M (100 before 500 or 1000).
V, L & D (5, 50 & 500) can't be repeated, only I, X, C & M (1, 10, 100 & 1000).
You shouldn't have more than three letters repeated (too easy to misread four consecutive identical letters as three).
So 90 shouldn't be written as LXXXX (50 + 10 + 10 + 10 + 10) or LXL (50 + 10 before 50), it should be XC (10 before 100).
98 --> XCVIII
99 --> XCIX
Michiel O.
Re: Grading app?
Thu Jul 25, 2019 5:03 am
Just out of curiosity, what does the 'grading' mean?
"You can't actually make computers run faster, you can only make them do less." - RiderOfGiraffes
Re: Grading app?
Thu Jul 25, 2019 5:56 am
https://javascriptsource.com/roman-numerals/
There's a bit of JavaScript I wrote 19 years ago.
This is a doctor free zone.
W. H. Heydt
Re: Grading app?
Thu Jul 25, 2019 6:12 am
It's probably been done in every programming language ever used.
scruss
Re: Grading app?
Thu Jul 25, 2019 9:19 am
100= ll
99=llll
98=l
LibreOffice Calc has a ROMAN(Number; Mode) function. I don't understand your grading schema, but this works:
N	ROMAN(N,4)
100	C
99	IC
98	VCIII
… as far as Roman numerals could ever be said to ‘work’. Toothpaste For Dinner's new numbers make about as much sense.
AaronRPI
Re: Grading app?
Thu Jul 25, 2019 10:08 am
Sorry for my stupidity, I ment tally marks. Also I would like the code in java. I mean grading so I can compare scores easier. I want to be able to type a number like 98 and the computer puts a tally mark after that number, so I have more typing and less mousing.
scotty101
Re: Grading app?
Thu Jul 25, 2019 10:32 am
If you want it to work with libreoffice, you would be better using the libreoffice macros than Java.
https://documentation.libreoffice.org/a ... acros.html
Do you want a number like 99 to have 99 tally marks? Or what do you want? It isn't clear what the pattern is from your examples.
scruss
Re: Grading app?
Thu Jul 25, 2019 2:25 pm
Unicode has fence/tally marks for two numbers, 1 and 5:
1D377	 𝍷 	Tally Mark One
1D378	 𝍸 	Tally Mark Five
You'll need to do the integer division and modulus bit to find out how many of each glyph you'll need
AaronRPI
Re: Grading app?
Fri Jul 26, 2019 1:18 pm
I want the app to put one tally mark beside each number each time I type that number, and I would like the tally mark on ONLY the number i type in.
I'm not sure how to put it any other way...
PhatFil
Re: Grading app?
Fri Jul 26, 2019 1:48 pm
how about specifying the range of all possible scores and each tally mark you want associated with each number. or is the actual tally mark irrelevant and you just want a token visual tally mark to show next to the score you just/last changed or to indicate which score is being edited/'in focus'?
scruss
Re: Grading app?
Fri Jul 26, 2019 3:23 pm
Something like this as you enter them?
Student         Mark    Tally
Ainsley         83	I		← 83 seen for the first time
Student         Mark    Tally
Ainsley         83
Babcock         86	I		← 86 seen for the first time
Student         Mark    Tally
Ainsley         83
Babcock         86
Bland           83	II		← 83 seen again
Student         Mark    Tally
Ainsley         83
Babcock         86
Bland           83
Carthorse       85	I		← 85 seen for the first time
Student         Mark    Tally
Ainsley         83
Babcock         86
Bland           83
Carthorse       85
Dint            83	III		← 83 seen for the third time
cpc464
Re: Grading app?
Sat Jul 27, 2019 11:57 am
Cool.
Unix engineer since 1989
