bullen
Can't apt-get install on Wheezy
Wed Jul 24, 2019 5:45 pm
http://mirrordirector.raspbian.org/rasp ... _armhf.deb
Returns a 404.
I did apt-get update first. If you look in the folder:
http://mirrordirector.raspbian.org/rasp ... m-sensors/
You will see the 3.3.2-2 is missing as the versions are:
libsensors4_3.3.5-2_armhf.deb
libsensors4_3.4.0-4_armhf.deb
So how does one fix this?
https://github.com/tinspin/rupy - A tiny Java async HTTP application server.
trejan
Re: Can't apt-get install on Wheezy
Wed Jul 24, 2019 5:47 pm
https://www.raspberrypi.org/forums/view ... p?t=237469
You need to manually edit the repo location and change archive to legacy.
bullen
Wed Jul 24, 2019 5:58 pm
Ah thanx...
