littlemonkey
"New" booting problem
Fri Jul 19, 2019 1:43 pm
Hello there.
Recently, we've bought a set of 6 Raspberry Pi's, model 3B+. It were 6 complete packages: including an SD card with Raspbian, power supply and a case. 5 of them are doing fine and working like a charm. 1 of them however, is acting particularly strange; it is not booting. Originally we didn’t mind, because we ordered 1 extra, just to be sure. However, now we would really like to get that 1 running as well.
When I try to boot with only the power supply and a monitor via HDMI, I get the infamous green ACT LED blinking 4 times. I read the sticky boot-problems topic (https://www.raspberrypi.org/forums/view ... 28&t=58151), but unfortunately without a positive result. I have tried the following:
  • Booting with a power supply of another Pi 3B+ that is working: not booting
  • Booting another Pi 3B+ with the power supply: booting! So it’s not the power supply.
  • Reformatting SD card using the Etcher program: not booting
  • Booting another Pi 3B+ with the reformatted SD card: booting! So it’s not the SD Card
  • also checked the HDMI connection, it worked properly on other Pi’s. So it’s not the HDMI cable or monitor.
  • Booting from USB, still the same error pattern from the green LED
I’m confused because the 4 times blinking usually means that there’s a problem with the start.elf, but this was not the case here as the SD card was working on another Pi 3B+. I also tried unconventional methods like trying to lift the black switch near the SD card slot (https://www.youtube.com/watch?v=6S74EQ4Oz6E&t=81s), but without a positive result.
The one thing I could image being the problem is that I accidently dropped the Pi once, but managed to break the fall with my shoe. I think it’s unlikely, but hey, maybe my clumsiness is the problem.
Do you bright minds have any clue? Is the hardware simply broken? Or did I overlooked something obvious?
jdb
Re: "New" booting problem
Fri Jul 19, 2019 3:02 pm
What are you describing as a switch? There are no switches on the Pi 3B+ board.
Rockets are loud.
https://astro-pi.org
RaTTuS
Fri Jul 19, 2019 3:04 pm
Hello there.....
the sdcard holder may have borked in the drop
Covfefe
littlemonkey
Mon Jul 22, 2019 5:46 am
Check the YouTube link, it's not really a switch, merely a black thing I do not know the function of.
littlemonkey
Mon Jul 22, 2019 5:47 am
Hello there.....
Is that something I can fix? Or should I leave it for dead and buy a new one.
Michiel O.
Mon Jul 22, 2019 6:01 am
Can you boot it from USB?
"You can't actually make computers run faster, you can only make them do less." - RiderOfGiraffes
HawaiianPi
Mon Jul 22, 2019 7:12 am
The 3B+ model has USB booting enabled by default. Use Etcher to write a Raspbian image to a USB flash drive and see if the troubled Pi will boot from that. Note that USB booting is quite a bit slower, and nothing will seem to happen after you connect the power, but if you wait a moment you should see the GPU test (color square) and shortly after that the 3B+ should start to boot from USB. If that works, then your SD card holder may have been damaged in the fall.
Video is nonsense. Dude in the video seems to think the cable latch for the display connector is some kind of reset switch. Image
littlemonkey
Tue Jul 23, 2019 8:33 am
I tried booting from USB, but the pi in question still does not boot. I tried it with another (working) pi, and got the splash screen, but it didn't fully boot properly. Got the same green LED pattern as before, only taking a few seconds longer to display the pattern. Maybe the flashing wasn't completed correctly. Image of the working Pi: http://nl.tinypic.com/r/339udm9/9
HawaiianPi
Wed Jul 24, 2019 1:47 am
Possibly, or it could be a compatibility issue (the Pi3 boot-loader is not compatible with all USB mass storage devices). You could try flashing the USB drive again, and double-check that the Etcher verify step passed without error. Or you could try a different USB drive.
However, if your "working" Pi at least started to boot and the suspect Pi did not, it seems likely that it has a problem.
