Esskaaell
No Ethernet connection after reboot.
Thu Jul 18, 2019 11:49 pm
Hi guys,
After reboot, my Pi4 cannot connect back with PuTTY and VNC. No ping answer. I tried with a different cable. I tried with pure DHCP and with quasi DHCP fixed IP. I tried before update/upgrade and after it and tried on other port. My 2 other Pis (Pi2. Pi3) work fine on ethernet cable. The only solution I found is detaching and re-attaching the cable and the Pi 4 gets IP and everything works fine. I use a 15W USB-C phone power brick to it. The Pi 4 is in headless mode.
Now I cannot imagine another thing, this is a hardware issue.
pcmanbob
Re: No Ethernet connection after reboot.
Fri Jul 19, 2019 7:13 am
Hi.
I suggest you read this thread as it seems to be the same problem you are having.
https://www.raspberrypi.org/forums/view ... 8&t=245144
Esskaaell
Fri Jul 19, 2019 2:40 pm
Hi.
I really appreciate your answer. I have the very same issue like in the other topic and it looks like it is hardware related. I am going to the shop where I bought it and change it.
Thx.
Andyroo
Fri Jul 19, 2019 4:52 pm
I would look at buying a decent power supplier and not a charger.
The original Pi 3B had Ethernet issues (and WiFi) till I changed to a proper supply - saved me hours of frustration :lol:
Esskaaell
Fri Jul 19, 2019 5:01 pm
The USB phone charger is a decent one, an original Google Pixel 3 phone charger.
I have an original HP power brick also with 4A. I tried it also connected to pins. I use this one to power my Pi 3B+ with an SSD for a while without any issue.
So I think this not a power issue.
andrum99
Fri Jul 19, 2019 9:26 pm
It doesn't matter how good the charger is - chargers are not power supplies. The Pi 4 is not a Pi 3. Get an official Raspberry Pi USB-C power supply.
Esskaaell
Fri Jul 19, 2019 9:49 pm
Oh yeah. The Raspberrypie.org is very famous nowadays how to follow the USB-C specifications :)
Sat Jul 20, 2019 6:05 am
If you're going to troll, at least get the name of the web site right. :roll: ;)
epoch1970
Sat Jul 20, 2019 10:38 am
So I trust you tried the workaround found in that thread. Does it work for you?
