nevetsokyeron
Pi4 - force HDMI to specific framebuffer?
Tue Jul 16, 2019 12:06 am
I have a Pi4 setup with an ssd1322 (128x64) OLED display for it's primary task. It's set to use /dev/fb0.
Now when I plug in an HDMI monitor (to do some debugging from the console), the HDMI wants to take over fb0 and forces the OLED to fb1 - at which point i get console on the OLED and my application on the HDMI.
If I remove the HDMI monitor, the OLED goes back to using fb0.
I tried settingframebuffer_priority=X to 0,1 or 2 with no change. (although I don't fully understand what that parameter is supposed to set).
On the Pi3, HDMI was always fb0, so I could set my OLED to fb1 and forget about it, but now the Pi4 seems to allocate the framebuffer dynamically so it changes depending on what's hooked up(?)
Is there a way to force HDMI to use fb1 instead of fb0?
topguy
Re: Pi4 - force HDMI to specific framebuffer?
Tue Jul 16, 2019 12:12 am
Probably easier to force the OLED driver to always choose fb1.
nevetsokyeron
Tue Jul 16, 2019 5:10 pm
How exactly would I do that?
If no HDMI devices are in use, the OLED defaults to fb0
