donavyn
Post Buster Update Seems Broke
Mon Jul 15, 2019 8:59 pm
Hello everyone.
Previously I sought help from the forums regarding why update and upgrade wasn't working. I was provided a link on how to upgrade from Stretch to Buster, and everything went along smoothly.
I left it over the weekend and when I attempted to issue a sudo apt-get update, this is the output that I received:
pi@raspberrypi:~ $ sudo apt-get update
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Get:3 http://archive.raspberrypi.org/debian buster/main i386 Packages [109 kB]
Fetched 109 kB in 7s (16.5 kB/s)
Reading package lists... Done
N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' doesn't support architecture 'i386'
N: Skipping acquire of configured file 'contrib/binary-i386/Packages' as repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' doesn't support architecture 'i386'
N: Skipping acquire of configured file 'non-free/binary-i386/Packages' as repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' doesn't support architecture 'i386'
N: Skipping acquire of configured file 'rpi/binary-i386/Packages' as repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' doesn't support architecture 'i386'
W: Skipping acquire of configured file 'staging/binary-i386/Packages' as repository 'http://archive.raspberrypi.org/debian buster InRelease' doesn't have the component 'staging' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'staging/binary-armhf/Packages' as repository 'http://archive.raspberrypi.org/debian buster InRelease' doesn't have the component 'staging' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'staging/i18n/Translation-en' as repository 'http://archive.raspberrypi.org/debian buster InRelease' doesn't have the component 'staging' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'staging/i18n/Translation-en_US' as repository 'http://archive.raspberrypi.org/debian buster InRelease' doesn't have the component 'staging' (component misspelt in sources.list?)
Not sure what to do with that exactly, I proceeded to issue sudo apt-get upgrade:
pi@raspberrypi:~ $ sudo apt-get upgrade
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up triggerhappy (0.5.0-1) ...
/bin/systemctl: error while loading shared libraries: libidn.so.11: cannot open shared object file: No such file or directory
/usr/bin/deb-systemd-helper: error: systemctl preset failed on triggerhappy.service: No such file or directory
/usr/bin/deb-systemd-helper: error: systemctl preset failed on triggerhappy.socket: No such file or directory
/sbin/runlevel: error while loading shared libraries: libidn.so.11: cannot open shared object file: No such file or directory
invoke-rc.d: could not determine current runlevel
invoke-rc.d: initscript triggerhappy, action "start" failed.
dpkg: error processing package triggerhappy (--configure):
 installed triggerhappy package post-installation script subprocess returned error exit status 127
 triggerhappy
I've attempted to reinstall 'triggerhappy', while the install seemed successful, re-issuing the upgrade command results the same.
I attempted to reinstall the OS again from the page that I was referred to earlier, but still no dice.
How bad is it, really docs?
trejan
Re: Post Buster Update Seems Broke
Mon Jul 15, 2019 9:12 pm
What did you run? It looks like this is a PC running Raspberry Pi Desktop but you've configured it to point at http://raspbian.raspberrypi.org/raspbian which is only for ARM. Raspberry Pi Desktop uses the regular Debian repo.
If this is actually a RPi board then you've set it to look for x86 packages.
In either case, something is misconfigured hence all the errors. The instructions you used to upgrade are suspect. It isn't recommended to do major version upgrades.
fbe
Mon Jul 15, 2019 9:15 pm
Are you using a Raspberry Pi with Raspbian or a PC with Debian and Raspberry Pi Desktop?
