fbe
MPD and bluetooth speaker issue in Raspbian Buster (used to work with Stretch)
Sat Jul 13, 2019 10:22 pm
Installed Raspbian Buster Lite (2019-07-10).
sudo apt install mpd mpc bluealsa
After reboot paired and connected my speaker using bluetoothctl.
aplay -D bluealsa:HCI=hci0,DEV=78:44:05:8d:06:74,PROFILE=a2dp /usr/share/sounds/alsa/Front_Center.wav
produces sound as expected.
Appended configuration to /etc/mpd.conf
audio_output {
        type            "alsa"
        name            "JBL GO"
        device          "bluealsa:HCI=hci0,DEV=78:44:05:8d:06:74,PROFILE=a2dp"
mixer_type "software"
Restarting mpd and play something...
sudo systemctl restart mpd
mpc clear
mpc add file:///usr/share/sounds/alsa/Front_Center.wav
mpc play 1
This used to work with Raspbian Stretch. In Buster I have an error in /var/log/mpd/mpd.log:
Jul 13 23:41 : exception: Failed to play on "JBL GO" (alsa): snd_pcm_poll_descriptors_revents() failed: Invalid argument
Is there anybody successfully using mpd and bluetooth speakers with Raspbian Buster?
fbe
Re: MPD and bluetooth speaker issue in Raspbian Buster (used to work with Stretch)
Mon Jul 15, 2019 7:44 pm
First success with workaround:
audio_output {
       type            "pipe"
       name            "pipe to JBL GO"
       command         "aplay -D bluealsa:HCI=hci0,DEV=78:44:05:8d:06:74,PROFILE=a2dp -f cd 2>/dev/null"
       format          "44100:16:2"
in /etc/mpd.conf
delcre
Sat Jul 20, 2019 2:52 pm
I had exactly the same problem.
Things worked in 'Stretch", but they did not work in 'Buster'.
The workaround shown in this thread worked. Thank you!
But does anyone know about root cause of this?
