cbkn76
Bluetooth issue when python script run from boot console
Fri Jul 12, 2019 8:38 pm
First off, my apologies for any confusing details I post, I am new to raspbian and all the nomenclature. I have searched for a few days online, but unable to find a solution as most of the search results refer to all the general Bluetooth issues, which i have had and fixed. I wouldn’t be asking now if I wasn’t at the end of my rope.
Pi 3b+
I have a python script on raspberry pi. The script has a function that plays a wav/mp3 over Bluetooth speaker and worked fine.
when the script is set to run on boot from console the Bluetooth speaker connects, but will not play sound. The full path to the wav/MP3’s are in the python script.
Any and all help is appreciated.
neilgl
Re: Bluetooth issue when python script run from boot console
Fri Jul 12, 2019 9:07 pm
Ah, how are you setting the script to run on boot?
Andyroo
Fri Jul 12, 2019 9:31 pm
My guess is a user / path issue
This may help https://www.dexterindustries.com/howto/ ... t-startup/ but please do not let that stop you posting details as requested above :lol:
cbkn76
Fri Jul 12, 2019 9:40 pm
Thanks for responding,
Using .bashrc
sudo python3 /home/pi/keypad_rpi/test_rfid.py
Just to be clear the code runs on boot and performs other functions , but does not play the sound. No errors appear and the code keeps running.
Douglas6
Fri Jul 12, 2019 9:44 pm
My guess is that the Bluetooth stack is not established, or the speaker is not connected when the program needs them. Try adding a 20-second pause to the start of your script.
cbkn76
Fri Jul 12, 2019 9:46 pm
I was going to add that the user/ permissions may be an issue as my developer had several of these issues when starting the script on boot.
Also wondered if pulse audio is running at boot, but no idea on how to check.
cbkn76
Fri Jul 12, 2019 10:02 pm
Would that look like this?
sleep 20 sudo python3 /home/pi/keypad_rpi/test_rfid.py
Douglas6
Fri Jul 12, 2019 10:20 pm
No, I believe it's
sleep 20; sudo python3 /home/pi/keypad_rpi/test_rfid.py
with a semicolon between commands. Or you can put a sleep() at the top of the Python script.
Andyroo
Fri Jul 12, 2019 10:30 pm
Any reason you need to run under SUDO?
It’s never good practise as a mistake can access all files etc :lol:
cbkn76
Added the sleep 20 and it still doesn’t work,
Also added echo Running at boot just above that, no dice.
Any other ideas???
neilgl
Sat Jul 13, 2019 7:43 pm
Can you post the script in full so we can test it. Thanks.
fbe
Sat Jul 13, 2019 8:08 pm
Your recommended help.
Sudo, sudo, sudo, lovely sudo
Wonderful sudo, lovely sudo
Any other ideas???
Is the sound coming over the audio jack or HDMI instead?
cbkn76
Tue Jul 16, 2019 5:01 am
I can get sound through hdmi, and its finicky, but I can occasionally get Bluetooth sound, but never when the script is run at boot from console.
By the way, I removed sudo and the script still ran, so I left sudo.
I’m a novice at this, can anyone recommend somewhere where I can hire someone to work on this? I tried a couple of people on Fiverr, they can’t fix, but say it is definitely not the script. Need a little higher caliber than fiverr
fbe
Tue Jul 16, 2019 7:45 pm
You were asked to post the script in full (or the link to the source where you found the script and other instructions that you are following)...
