There was storm at my parents house and seems like out TV Samsung has been damaged as it won't turn on. TV is currently in service center.
Short story:
CEC is not working,
I see constantly overheating (full) icon
Is there any way to verify HDMI port was damaged on parents RPI during storm?
Can I somehow measure board's components to check if something burned out?
Full story:
I'm using OSMC.
I've replaced TV with different one but when RPi3 was connected I've got no screen no matter which HDMI imput I use.
- I've took this RPi home and tried on my LG TV where I'm also running RPi3. Same issue.
- So I took out SD card from my (working) RPi3 and put it to my parents Rpi3. First no screen, but after some time screen shows up but was flickering in a way that it gets dark for few sec and than on for few sec. Resolution seemed to be wrong and CBC was not working.
- when I put parent's SD card to my RPi everyting works ok including CBC
- I've made backup of SD card from parents RPi and installed new one OSMC on the card. Connected parents RPi and turned on. Again no boot screen, but after while screen showed up with initial settings. No CBC. After while overheating icon showed up with full bar
- I connected mouse and went through settings. After completion still no CBC, overheating still shows, processor unplesantly how on touch.
- I've checked CBC settings in OSMC and everything seems fine.
- I've checked board but no ovbious burnout is visible
Thank you for any suggestions.
