Not being able to update properly
Posted: Tue Jul 09, 2019 1:03 am
by 1305_A
pi@raspberrypi:~ $ sudo apt update
Get:1 http://archive.raspberrypi.org/debian buster InRelease [25.1 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Reading package lists... Done
E: Release file for http://archive.raspberrypi.org/debian/dists/buster/InRelease is not valid yet (invalid for another 17d 21h 7min 45s). Updates for this repository will not be applied.
E: Release file for http://raspbian.raspberrypi.org/raspbian/dists/buster/InRelease is not valid yet (invalid for another 18d 5h 22min 28s). Updates for this repository will not be applied.
Is there anything I have to do to fix this? I honestly don't know the problem here.
Re: Not being able to update properly
Posted: Tue Jul 09, 2019 1:08 am
by plugwash
Looks like your system's clock is wrong.
Posted: Tue Jul 09, 2019 6:54 pm
by 1305_A
That is indeed the case, as it displays the current date as June 20th. How do I fix this?
Posted: Tue Jul 09, 2019 9:44 pm
by DougieLawson
sudo date -s '9 Jul 2019 22:44'
Posted: Tue Jul 09, 2019 11:51 pm
by Mettauk
Same or similar issue except date is correct
:~ $ sudo apt-get update && sudo apt-get dist-upgrade
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'testing' to 'stable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
:~ $ date
Wed 10 Jul 00:50:32 BST 2019
Posted: Wed Jul 10, 2019 1:02 am
by plugwash
sudo apt-get update --allow-releaseinfo-change
Posted: Wed Jul 10, 2019 8:18 pm
by 1305_A
That worked. Thanks! :D
Posted: Wed Jul 10, 2019 9:04 pm
by Mettauk
Thanks that fixed both instances, one on a P4b the other on a B+
Posted: Wed Jul 10, 2019 10:12 pm
by gkaiseril
The date command will set both date and time. It is best to supply both when issuing the command.
For more information see the man page for date.
One can also use the timedatectl command to set the date and time.
