thrustpork
RPI4 4gb, not loading textures properly in some games, and an issue with chrome, hardware accel, and the latest debian.
Sun Jul 07, 2019 8:39 pm
So I'm getting this weird issue where my RPI4 4gb doesn't seem to load textures properly in some games.
https://imgur.com/a/9yMzuXT
I've tested it on a few different ones with the same result. This particular one is LittleWarGame.com.
I'm running Raspbian Buster. I've done apt-get update, apt-get dist-upgrade, and rpi-update (did this for the latest firmware that allows hardware acceleration in chromium again). My chrome://gpu shows hardware acceleration is working. I've also tried setting gpu_mem=512 in the config.txt.
Any idea on what's going on?
Edit:
Here's my chrome://gpu to clear that up.
Graphics Feature Status
Canvas: Hardware accelerated
Flash: Hardware accelerated
Flash Stage3D: Hardware accelerated
Flash Stage3D Baseline profile: Hardware accelerated
Compositing: Hardware accelerated
Multiple Raster Threads: Enabled
Native GpuMemoryBuffers: Software only. Hardware acceleration disabled
Out-of-process Rasterization: Disabled
Hardware Protected Video Decode: Unavailable
Rasterization: Software only. Hardware acceleration disabled
Skia Renderer: Disabled
Surface Control: Disabled
Surface Synchronization: Enabled
Viz Service Display Compositor: Enabled
WebGL: Hardware accelerated
WebGL2: Hardware accelerated
Edit 2:
I don't think it's actually HTML5 related as it's happening in games from apt-get like Seven Kingdoms and Widelands as well. Some games run fine, others seem to have the texture bug. Adjusted title to reflect this.
thrustpork
Re: RPI4 4gb, not loading textures properly in some games?
Mon Jul 08, 2019 4:26 pm
I’ve got another issue now. I ran apt update last night and my debian switched from test to inrelease as well as downloaded some files. Now when I try to play a video in chromium the whole tab turns black and locks up.
I’m running the latest rpi-update and if I disable the hardware acceleration in chrome it works, but I think the fix in testing was broken by the debian update somehow.
