HawaiianPi
Re: I can´t boot from usb in pi 4
Sat Jul 13, 2019 12:14 am
grayerbeard wrote:
Mon Jul 08, 2019 5:09 pm
Because of some security issue you can't just put a fresh Raspian on the drive on the USB it ONLY works with a copy of what is on the SD card
Wait, what? :?
That is absolutely not true. You can write a Raspbian image directly to the USB drive and copy the files from the "boot" partition to a FAT32 formatted micro SD card, and with a simple file edit it will boot fine (all you need to do is remove the command that launches the resize script from cmdline.txt). I've been meaning to do a full tutorial on this, but I've been dealing with some "life" nonsense and haven't had time.
Simple version of hybrid SD-USB boot tutorial:
  1. Write Raspbian image to USB drive with Etcher.
  2. Edit cmdline.txt to remove the resize script launch (see edit below).
  3. Copy files from USB "boot" partition to FAT32 micro SD card.
  4. Plug card and USB drive into Pi4 and boot it up.
Once the system is up and running, edit /etc/fstab to mount the card as /boot (so that kernel and firmware updates are correctly applied) and reboot. Also, for headless boot, put ssh and wpa_supplicant.conf files on the USB drive (not the card, because USB mounts as /boot initially).
Then, of course, you'll need to resize the 2nd partition...
EDIT:
Forgot to mention, when you remove the resize command from cmdline.txt, make sure you only leave a single space.
Gavinmc42
Sat Jul 13, 2019 12:27 am
You're forgetting that the primary purpose of the Pi was (and AFIK still is) providing cheap educational computers for kids to learn coding on. Not something that can easily be done with SSD or HDD storage.
And for education market I can see network booting would be a much higher priority than USB booting.
A classroom of Pi's without uSD's or USB drives that can going walking.
We keep thinking about our wants, but RPF has a Mission.
After spending 3 x times the cost of a Pi on memory this week, netbooting is making more sense now.
I'm dancing on Rainbows.
LTolledo
Sat Jul 13, 2019 3:44 am
After spending 3 x times the cost of a Pi on memory this week, netbooting is making now sense now.
hmmm...good point....
....and that's one good reasoning why netbooting is taking priority over USB boot....
...one of these days am going to try this method....
(help with some procedures... please.... ;) )
Some people be like:
Gavinmc42
Sat Jul 13, 2019 5:17 am
I will wait till it works, still need to get another Pi4 and a Gigabit switch and probably better cabling.
Seen 8, 16, 24, do they have 32 port switches?
Those would make sense in a classroom.
And with the faster LAN speed, how quick would they boot?
Especially if that was checked first in the Boot EEPROM.
Going to make school IT support so much easier.
With the right lesson plans autobooting etc.
I don't do this stuff so this is just a guess.
Now if they had 4A's with WiFi boot, no need for the LAN stuff.
Might need bigger EEPROM for those?
I use old Dell monitors with USB hubs in them, great use for 3A+.
But the Official Pi keyboard has a hub, use it with 4A?
Whoops more brain dumping.
kyliael
Sat Jul 13, 2019 6:56 am
Nice to see how some guys don't want to admit there's an issue. For every single customer complaining about the lack and regression of usb boot support OUT OF THE BOX as it is for the previous version, the pi 3b+, you're saying they are a minority, most of people don't care about usb booting blablabla.
I'm seeing more and more customers complaining or at least, just asking for an APPROXIMATIVE date for release. 1 month, 3 months, 6 months?
And you guys just make fun on them.
Nice mindset.
gsh
Sat Jul 13, 2019 7:02 am
Probably around another two or three weeks for Ethernet booting, another month for USB flash booting
Gordon Hollingworth PhD
Gavinmc42
Sat Jul 13, 2019 7:57 am
Thanks Gordon for the update.
So if you guys had waited for those two issues to be fixed there would be about 1/2 Million Pi's sitting in a warehouse or two.
The Pi3B+ was the second version, the Pi3B did not have USB boot on release either.
I imagine if there is ever a 4B+ it would boot from USB, Network etc on release.
Some people are never happy.
Nice mindset.
Mountains out of molehills?
Old timers are grateful for hardware that works faster and software that will just get better if we have patience.
I wonder about those that complain the most, how much coding experience they have.
Sat Jul 13, 2019 8:05 am
Nice mindset.
We accept there is an issue with usb-c for some power supplies and will be fixing it. We know usb boot is wanted by some people and will be adding it. So pretty sure we have admitted everything you are complaining about. You also have an approximate schedule for the added boot features. So what's the problem?
HawaiianPi
Sat Jul 13, 2019 8:27 am
The problem is the whiners rushed out a bought something without doing any research whatsoever, and now they're unhappy that it wasn't what they imagined it would be.
I love how all these self-important people come on here to tell the Raspberry Pi Foundation what they *should* do, regardless of what anyone else feels. And then when we try to tell them that, they just dismiss our opinions as nonsense. :roll:
A lot of us here are fine with running a Pi from an SD card, or hybrid SD-USB booting until the firmware is updated. But you don't care about that at all, do you kyliael, because apparently you are the most important person in the entire world, and your opinion is all that matters.
So remember that, Jamesh. Next time you and your cronies plan on releasing a product 6 months ahead of schedule, you better check with kyliael first, to see if it's okay. Because if kyliael's not happy, none of us are allowed to be happy. Image
Sat Jul 13, 2019 9:22 am
Probably best to lay off any sort of personal attacks. But your point is taken.
We could of course, have held on for another month or two or three or four or five, fixed up the remaining issues, had everything there from the launch.
But those people who have no need of the extra features would have to wait another few months to get a product that is already does what they want.
So effectively, the Pi4 is good enough for most people, and will get better over time to satisfy the rest. Not sure why people think that is a bad approach.
jdb
Sat Jul 13, 2019 9:46 am
Nice mindset.
One last time:
What is stopping you from running the root filesystem on a USB SSD?
Rockets are loud.
https://astro-pi.org
LTolledo
Sat Jul 13, 2019 9:59 am
his mindset ..perhaps... :mrgreen:
" ....where there's a will.... there's always a way....
....in the absence of such...there will always be excuses and complaints all the way....."
Gavinmc42
Sat Jul 13, 2019 10:10 am
I found the Pi4 release perfect timing as my home PC running Linux Mint died the day my first Pi4 arrived.
My biggest beef is Warzone2100 won't run 4 player maps without going psychedelic on me.
Previously half the map was black, so it is getting better ;)
Got a USB dock and had trouble getting it going using Win10/Etcher.
Turns out uSD cards had a price drop, I'm now using a 64GB one.
Runs about twice as fast as the old 3B+.
I found it a bit offensive.
Basically saying you guys don't know what you are doing after making how many Pi versions?
Is RPF becoming a victim of their own success and expectations are now beyond mere mortals ability to deliver?
Keep making Pi's, some of us will keep buying them.
Besides you guys are not even close to finishing the Mission, OCPP?
How many kids in the World?
HawaiianPi
Sat Jul 13, 2019 10:25 am
thagrol
Sat Jul 13, 2019 11:46 am
Nice mindset.
Nobody is denying there is an issue.
Nobody is making fun of anybody.
Some folks are doing a good job of making themselves look stupid and childish.
Some folks are also giving the impression that they prefer to whinge rather than apply a know good workaround for the USB boot issue.
Can we have some context and hard evidence to back up your claim that "I'm seeing more and more customers complaining"? Something we can compare with the number of 4Bs sold.
Lastly, here a question for you:
When PC manufacturers stopped including floppy drives did you take the same attitude or did you apply a workaround buy providing your own? I'm assuming here, you're old enough to have been around during that time but given your obvious immaturity I doubt that's the case.
This space unintentionally left blank.
kyliael
Sat Jul 13, 2019 10:26 pm
The staff gave - at last - a response about usb boot feature delay, and network boot.
Thank you.
Just note that if this was clearly explained in a sticky post, on the documentation, or even just said when we were asking for it since the release, this kind of frustration won't have occurred.
Concerning all other people, just responding to make fun on me, well you just giving the proof I was right concerning your mindset.
kyliael
Sat Jul 13, 2019 10:37 pm
Comparing end of life of floppy disk and the hability to use boot from USB to only use a ssd instead of Micro SD card?
Well, don't you see how stupid is your comparison?
I don't know you, you don't know me. You shouldn't feel yourself so smart or confident when throwing this kind of immature and personal attack on a forum.
By the way, my first computer was not equipped with a floppy drive... It was a ti99/4a
thagrol
Sat Jul 13, 2019 10:42 pm
As I said above, nobody is making fun of you.
Some of us have commented on how you are coming across to us which is not the same thing at all. And the quote above just serves to reinforce that impression.
Some of us have also tried to point why your position is, at best, mistaken.
Many of us have tried to point out your alternatives, often more than once, including at least one staff member. You've not done yourself any favours by refusing to acknowledge this and by refusing to reply when direct questions have been asked of you.
LTolledo
Sat Jul 13, 2019 10:50 pm
Maybe you missed this, or did read it but did not try (or never tried) to understand. Its been there since RPi4B's release
https://www.raspberrypi.org/documentati ... teeprom.md
PXE and USB Boot
Support for these additional bootmodes will be added in the future via optional bootloader updates. The current schedule is to release PXE boot first, then USB boot.
Now this is some kind of proof doesnt it?
Something wrong with our mindsets you say?
kyliael
Sat Jul 13, 2019 10:51 pm
Just don't want to use a uSD card.
I want to flash an OS to an USB drive, boot on it directly just out of the box like the pi3b+ without having to do it manually.
By the way, the first response from staff was : no progress
Last response, about 1.5-2 months delay.
That's OK, at least we have a clear response now.
thagrol
Sat Jul 13, 2019 10:56 pm
No, I don't.
In both situations technology was removed that a minority of folks relied upon. In both cases suitable work arounds existed that could be implimented by the end user.
I don't recall anyone doing what you are doing now back then though at that time the internet was a different beast.
True. All we have to go on is the tone of the words we write. Yours has been consistenly immature, agressive, and petulant. As this is a family friendly forum (and you're the one who's been both swearing and impolite) it is not unreasonable to assume, given your posts in this and other threads that you were a teenager given the lack of evidence to the contrary.
No direct personal attack was made or intended though a speculation based on your previous posts was made.
Neither was mine but I'm not about start comparing anatomy. Not least because there are folks around here who've been in this game much longer than I have. And I don't see how that is A. relevant, and B. proof of age.
LTolledo
Sat Jul 13, 2019 11:00 pm
Ok, your point is clear now... just be patient then... until the eventual roll out...
thagrol
Sat Jul 13, 2019 11:01 pm
That's not an unreasonable desire.
Sadly that's currently not possible as was known before you joined this thread.
The way you've gone about things has, in my opinion, done little but alienate folks who are here to help.
kyliael
Sat Jul 13, 2019 11:03 pm
PXE and USB Boot
Another good example. Please stop now. There's bunch of customers waiting for usb boot.
neocalm wrote:
Thu Jul 04, 2019 4:00 pm
Step 4. And it didn't work, so I google'd it again with my result and ended up here.
So there you have it. If it had said something like "USB boot is available on the Raspberry Pi 3B, 3B+, 3A+ and Raspberry Pi 2B v1.2 models only. Raspberry Pi 4 uses a different system and will not work" I would have stopped there.
Cheers!
jdb
Sat Jul 13, 2019 11:09 pm
Allow me to clarify further: you are permanently banned from these forums.
Guides and tutorials have been posted in response to your - uh - questions, and you haven't said at any point whether these have worked, or have been insufficient for your needs.
Instead you've consistently sought to seek a stick with which to beat "the staff" and have resorted to various insults along the way. I don't have time for this nonsense.
Rockets are loud.
