filippos
kernel Oops 5
Thu Jun 20, 2019 6:13 pm
after 20 minutes of working fine my Rpi2 stops with the following error:
Message from syslogd@kix2 at Jun 20 09:50:15 ...
 kernel:[  873.415170] Internal error: Oops: 5 [#1] SMP ARM
Any help is appreciated.
Paeryn
Re: kernel Oops 5
Thu Jun 20, 2019 10:37 pm
There should be more information in the logs than just that line, there should be a few lines before it giving more information and a load of lines after giving a dump of the processor state and a memory dump of (part of) the stack at the time the error happened. I think they are in /var/log/messages, if not then probably /var/log/syslog.
I think error 5 is a user-mode protection fault, if so it is likely caused by either a null or an invalid pointer being dereferenced but you need the other lines around the oops line to tell you where the error occured.
filippos
Re: kernel Oops 5
Fri Jun 21, 2019 6:07 am
Hi Paeryn,
thanks for replying
I've checked the above logs but there was nothing there, but I run a script to log w,dmesg,and ps.
The Oops message was displayed running ssh to Rpi from my pc.
my script's log
F S UID        PID  PPID  C PRI  NI ADDR SZ WCHAN  STIME TTY          TIME CMD
4 S root         1     0  0  80   0 -  1377 -      09:35 ?        00:00:04 /sbin/init
1 S root         2     0  0  80   0 -     0 -      09:35 ?        00:00:00 [kthreadd]
1 I root         3     2  0  80   0 -     0 -      09:35 ?        00:00:00 [kworker/0:0]
1 I root         4     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [kworker/0:0H]
1 I root         5     2  0  80   0 -     0 -      09:35 ?        00:00:00 [kworker/u8:0]
1 I root         6     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [mm_percpu_wq]
1 S root         7     2  0  80   0 -     0 -      09:35 ?        00:00:00 [ksoftirqd/0]
1 I root         8     2  0  80   0 -     0 -      09:35 ?        00:00:00 [rcu_sched]
1 I root         9     2  0  80   0 -     0 -      09:35 ?        00:00:00 [rcu_bh]
1 S root        10     2  0 -40   - -     0 -      09:35 ?        00:00:00 [migration/0]
1 S root        11     2  0  80   0 -     0 -      09:35 ?        00:00:00 [cpuhp/0]
1 S root        12     2  0  80   0 -     0 -      09:35 ?        00:00:00 [cpuhp/1]
1 S root        13     2  0 -40   - -     0 -      09:35 ?        00:00:00 [migration/1]
1 S root        14     2  0  80   0 -     0 -      09:35 ?        00:00:00 [ksoftirqd/1]
1 I root        16     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [kworker/1:0H]
1 S root        17     2  0  80   0 -     0 -      09:35 ?        00:00:00 [cpuhp/2]
1 S root        18     2  0 -40   - -     0 -      09:35 ?        00:00:00 [migration/2]
1 S root        19     2  0  80   0 -     0 -      09:35 ?        00:00:00 [ksoftirqd/2]
1 I root        21     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [kworker/2:0H]
1 S root        22     2  0  80   0 -     0 -      09:35 ?        00:00:00 [cpuhp/3]
1 S root        23     2  0 -40   - -     0 -      09:35 ?        00:00:00 [migration/3]
1 S root        24     2  0  80   0 -     0 -      09:35 ?        00:00:00 [ksoftirqd/3]
1 I root        26     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [kworker/3:0H]
5 S root        27     2  0  80   0 -     0 -      09:35 ?        00:00:00 [kdevtmpfs]
1 I root        28     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [netns]
1 I root        29     2  0  80   0 -     0 -      09:35 ?        00:00:00 [kworker/0:1]
1 I root        31     2  0  80   0 -     0 -      09:35 ?        00:00:00 [kworker/2:1]
1 I root        32     2  0  80   0 -     0 -      09:35 ?        00:00:00 [kworker/3:1]
1 S root        33     2  0  80   0 -     0 -      09:35 ?        00:00:00 [khungtaskd]
1 S root        34     2  0  80   0 -     0 -      09:35 ?        00:00:00 [oom_reaper]
1 I root        35     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [writeback]
1 S root        36     2  0  80   0 -     0 -      09:35 ?        00:00:00 [kcompactd0]
1 I root        37     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [crypto]
1 I root        38     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [kblockd]
1 I root        39     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [watchdogd]
1 I root        40     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [rpciod]
1 I root        41     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [xprtiod]
1 S root        44     2  0  80   0 -     0 -      09:35 ?        00:00:00 [kswapd0]
1 I root        45     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [nfsiod]
1 I root        55     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [kthrotld]
1 I root        56     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [iscsi_eh]
1 I root        57     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [dwc_otg]
1 I root        58     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [DWC Notificatio]
1 S root        59     2  0  61 -19 -     0 -      09:35 ?        00:00:00 [vchiq-slot/0]
1 S root        60     2  0  61 -19 -     0 -      09:35 ?        00:00:00 [vchiq-recy/0]
1 S root        61     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [vchiq-sync/0]
1 S root        62     2  0  80   0 -     0 -      09:35 ?        00:00:00 [vchiq-keep/0]
1 S root        63     2  0  70 -10 -     0 -      09:35 ?        00:00:00 [SMIO]
1 I root        64     2  0  80   0 -     0 -      09:35 ?        00:00:00 [kworker/1:2]
1 S root        65     2  0  80   0 -     0 -      09:35 ?        00:00:01 [mmcqd/0]
1 S root        67     2  0  80   0 -     0 -      09:35 ?        00:00:00 [jbd2/mmcblk0p7-]
1 I root        68     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [ext4-rsv-conver]
1 I root        69     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [ipv6_addrconf]
1 I root        89     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [kworker/1:1H]
1 I root        99     2  0  80   0 -     0 -      09:35 ?        00:00:00 [kworker/2:2]
1 I root       102     2  0  80   0 -     0 -      09:35 ?        00:00:00 [kworker/u8:2]
1 I root       112     2  0  80   0 -     0 -      09:35 ?        00:00:00 [kworker/3:2]
4 S root       120     1  0  80   0 -  2482 -      09:35 ?        00:00:01 /lib/systemd/systemd-journald
4 S root       123     1  0  80   0 -  3012 -      09:35 ?        00:00:00 /lib/systemd/systemd-udevd
4 S root       418     1  0  80   0 -  8035 -      09:35 ?        00:00:00 /usr/sbin/rsyslogd -n
4 S root       427     1  0  80   0 -  1274 -      09:35 ?        00:00:00 /usr/sbin/cron -f
4 S avahi      429     1  0  80   0 -   968 -      09:35 ?        00:00:00 avahi-daemon: running [kix2.local]
4 S message+   433     1  0  80   0 -  1372 -      09:35 ?        00:00:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
5 S nobody     444     1  0  80   0 -   572 -      09:35 ?        00:00:00 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/triggers.d/ --socket /var/run/thd.socket --pidfile /var/run/thd.pid --user nobody /dev/input/event*
1 S avahi      449   429  0  80   0 -   968 -      09:35 ?        00:00:00 avahi-daemon: chroot helper
1 I root       456     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [cfg80211]
5 S root       457     1  0  80   0 -   640 -      09:35 ?        00:00:00 /sbin/dhcpcd -q -b
4 S root       471     1  0  80   0 -   962 -      09:35 ?        00:00:00 /lib/systemd/systemd-logind
4 S root       473     1  0  80   0 -  3107 -      09:35 ?        00:00:00 /usr/sbin/cupsd -f
4 S root       480     1  0  80   0 -  2566 -      09:35 ?        00:00:00 /usr/sbin/cups-browsed
1 I root       497     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [kworker/0:1H]
1 I root       620     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [kworker/3:1H]
5 S ntp        623     1  0  80   0 -  1421 -      09:35 ?        00:00:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 107:112
4 S root       680     1  0  80   0 -  1416 -      09:35 tty1     00:00:00 /bin/login -f
4 S root       717     1  0  80   0 -  1964 -      09:35 ?        00:00:00 /usr/sbin/sshd -D
4 S root       971     1  0  80   0 - 26521 -      09:35 ?        00:00:00 php-fpm: master process (/etc/php5/fpm/php-fpm.conf)
5 S www-data  1007   971  0  80   0 - 26521 -      09:35 ?        00:00:00 php-fpm: pool www
5 S www-data  1009   971  0  80   0 - 26521 -      09:35 ?        00:00:00 php-fpm: pool www
4 S root      1020   717  0  80   0 -  2377 -      09:35 ?        00:00:00 sshd: pi [priv]
5 S Debian-+  1036     1  0  80   0 -  2435 -      09:35 ?        00:00:00 /usr/sbin/exim4 -bd -q30m
5 S root      1044     1  0  80   0 - 27012 -      09:35 ?        00:00:00 /usr/sbin/apache2 -k start
4 S pi        1049     1  0  80   0 -  1243 SyS_ep 09:35 ?        00:00:00 /lib/systemd/systemd --user
5 S pi        1053  1049  0  80   0 -  1716 -      09:35 ?        00:00:00 (sd-pam)
5 S www-data  1056  1044  0  80   0 - 27018 -      09:35 ?        00:00:00 /usr/sbin/apache2 -k start
5 S www-data  1057  1044  0  80   0 - 27018 -      09:35 ?        00:00:00 /usr/sbin/apache2 -k start
5 S www-data  1058  1044  0  80   0 - 27018 -      09:35 ?        00:00:00 /usr/sbin/apache2 -k start
5 S www-data  1059  1044  0  80   0 - 27018 -      09:35 ?        00:00:00 /usr/sbin/apache2 -k start
5 S www-data  1060  1044  0  80   0 - 27018 -      09:35 ?        00:00:00 /usr/sbin/apache2 -k start
5 S pi        1062  1020  0  80   0 -  2377 -      09:35 ?        00:00:00 sshd: pi@pts/0
0 S pi        1064  1062  0  80   0 -  1644 wait   09:35 pts/0    00:00:01 -bash
4 S pi        1089   680  0  80   0 -  1641 wait_w 09:35 tty1     00:00:00 -bash
1 S root      1093     1  6  80   0 - 15019 -      09:35 ?        00:00:51 /usr/bin/python /usr/bin/fail2ban-server -b -s /var/run/fail2ban/fail2ban.sock -p /var/run/fail2ban/fail2ban.pid
1 I root      1115     2  0  60 -20 -     0 -      09:35 ?        00:00:00 [kworker/2:1H]
0 S pi        1222  1064  0  80   0 -   477 wait   09:37 pts/0    00:00:01 sh bin/ch.sh
1 I root      1827     2  0  80   0 -     0 -      09:40 ?        00:00:00 [kworker/1:0]
1 I root      2813     2  0  80   0 -     0 -      09:46 ?        00:00:00 [kworker/1:1]
0 R pi        3576  1222  0  80   0 -  1185 -      09:50 pts/0    00:00:00 ps -efl
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Linux version 4.14.94-v7+ (dom@dom-XPS-13-9370) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1193 SMP Tue Jan 22 15:34:30 GMT 2019
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 2 Model B Rev 1.1
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 8 MiB at 0x3a800000
[    0.000000] On node 0 totalpages: 241664
[    0.000000] free_area_init_node: node 0, pgdat 80c85780, node_mem_map b9fa8000
[    0.000000]   Normal zone: 2124 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 241664 pages, LIFO batch:31
[    0.000000] percpu: Embedded 17 pages/cpu @b9f52000 s38720 r8192 d22720 u69632
[    0.000000] pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 239540
[    0.000000] Kernel command line: bcm2708_fb.fbwidth=592 bcm2708_fb.fbheight=448 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 936176K/966656K available (7168K kernel code, 577K rwdata, 2080K rodata, 1024K init, 698K bss, 22288K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
    lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x80800000   (8160 kB)
      .init : 0x80b00000 - 0x80c00000   (1024 kB)
      .data : 0x80c00000 - 0x80c906b4   ( 578 kB)
       .bss : 0x80c97ef8 - 0x80d468f0   ( 699 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 25296 entries in 75 pages
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000030] Switching to timer-based delay loop, resolution 52ns
[    0.000349] Console: colour dummy device 80x30
[    0.000973] console [tty1] enabled
[    0.001018] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001068] pid_max: default: 32768 minimum: 301
[    0.001492] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001538] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002763] Disabling memory control group subsystem
[    0.002922] CPU: Testing write buffer coherency: ok
[    0.003551] CPU0: update cpu_capacity 1024
[    0.003589] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.004237] Setting up static identity map for 0x100000 - 0x10003c
[    0.004460] Hierarchical SRCU implementation.
[    0.005513] smp: Bringing up secondary CPUs ...
[    0.006711] CPU1: update cpu_capacity 1024
[    0.006723] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.007985] CPU2: update cpu_capacity 1024
[    0.007995] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.009204] CPU3: update cpu_capacity 1024
[    0.009214] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.009364] smp: Brought up 1 node, 4 CPUs
[    0.009509] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.009534] CPU: All CPU(s) started in HYP mode.
[    0.009556] CPU: Virtualization extensions available.
[    0.010883] devtmpfs: initialized
[    0.023231] random: get_random_u32 called from bucket_table_alloc+0xfc/0x24c with crng_init=0
[    0.024030] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.024392] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.024453] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.025292] pinctrl core: initialized pinctrl subsystem
[    0.026429] NET: Registered protocol family 16
[    0.029591] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.035651] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.035703] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.035984] Serial: AMBA PL011 UART driver
[    0.038316] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.079761] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dmachans=0x1
[    0.081803] SCSI subsystem initialized
[    0.082151] usbcore: registered new interface driver usbfs
[    0.082247] usbcore: registered new interface driver hub
[    0.082408] usbcore: registered new device driver usb
[    0.090408] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-01-22 16:50
[    0.092141] clocksource: Switched to clocksource arch_sys_counter
[    0.179219] VFS: Disk quotas dquot_6.6.0
[    0.179381] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.179662] FS-Cache: Loaded
[    0.179979] CacheFiles: Loaded
[    0.192873] NET: Registered protocol family 2
[    0.193902] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.194063] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.194275] TCP: Hash tables configured (established 8192 bind 8192)
[    0.194480] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.194564] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.194914] NET: Registered protocol family 1
[    0.195642] RPC: Registered named UNIX socket transport module.
[    0.195680] RPC: Registered udp transport module.
[    0.195704] RPC: Registered tcp transport module.
[    0.195728] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.197620] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.201468] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.212027] FS-Cache: Netfs 'nfs' registered for caching
[    0.213012] NFS: Registering the id_resolver key type
[    0.213084] Key type id_resolver registered
[    0.213109] Key type id_legacy registered
[    0.213148] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.216002] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.216255] io scheduler noop registered
[    0.216287] io scheduler deadline registered (default)
[    0.216553] io scheduler cfq registered
[    0.216583] io scheduler mq-deadline registered
[    0.216608] io scheduler kyber registered
[    0.218926] BCM2708FB: allocated DMA memory fa900000
[    0.219004] BCM2708FB: allocated DMA channel 0 @ bb813000
[    0.228294] Console: switching to colour frame buffer device 74x28
[    0.238278] bcm2835-rng 3f104000.rng: hwrng registered
[    0.241107] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    0.247266] vc-sm: Videocore shared memory driver
[    0.250540] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    0.270405] brd: module loaded
[    0.285176] loop: module loaded
[    0.287893] Loading iSCSI transport class v2.0-870.
[    0.291476] libphy: Fixed MDIO Bus: probed
[    0.294385] usbcore: registered new interface driver lan78xx
[    0.297243] usbcore: registered new interface driver smsc95xx
[    0.299935] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.330568] dwc_otg 3f980000.usb: base=0xf0980000
[    0.533517] Core Release: 2.80a
[    0.536071] Setting default values for core params
[    0.538704] Finished setting default values for core params
[    0.741685] Using Buffer DMA mode
[    0.744386] Periodic Transfer Interrupt Enhancement - disabled
[    0.747188] Multiprocessor Interrupt Enhancement - disabled
[    0.750000] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.752870] Dedicated Tx FIFOs mode
[    0.756241] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xba914000 dma = 0xfa914000 len=9024
[    0.761913] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[    0.775202] dwc_otg: Microframe scheduler enabled
[    0.775278] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805ed1d4
[    0.778002] WARN::hcd_init_fiq:460: FIQ ASM at 0x805ed53c length 36
[    0.780710] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
[    0.783484] dwc_otg 3f980000.usb: DWC OTG Controller
[    0.786190] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    0.791627] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    0.794527] Init: Port Power? op_state=1
[    0.797309] Init: Power Port (0)
[    0.800323] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.805897] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.811595] usb usb1: Product: DWC OTG Controller
[    0.814528] usb usb1: Manufacturer: Linux 4.14.94-v7+ dwc_otg_hcd
[    0.817504] usb usb1: SerialNumber: 3f980000.usb
[    0.821215] hub 1-0:1.0: USB hub found
[    0.824151] hub 1-0:1.0: 1 port detected
[    0.827595] dwc_otg: FIQ enabled
[    0.827602] dwc_otg: NAK holdoff enabled
[    0.827608] dwc_otg: FIQ split-transaction FSM enabled
[    0.827620] Module dwc_common_port init
[    0.827963] usbcore: registered new interface driver usb-storage
[    0.831094] mousedev: PS/2 mouse device common for all mice
[    0.834122] IR NEC protocol handler initialized
[    0.837030] IR RC5(x/sz) protocol handler initialized
[    0.839929] IR RC6 protocol handler initialized
[    0.842861] IR JVC protocol handler initialized
[    0.845665] IR Sony protocol handler initialized
[    0.848457] IR SANYO protocol handler initialized
[    0.851209] IR Sharp protocol handler initialized
[    0.853927] IR MCE Keyboard/mouse protocol handler initialized
[    0.856604] IR XMP protocol handler initialized
[    0.860157] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.865936] bcm2835-cpufreq: min=600000 max=600000
[    0.869140] sdhci: Secure Digital Host Controller Interface driver
[    0.871894] sdhci: Copyright(c) Pierre Ossman
[    0.875067] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[    0.880453] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.884017] ledtrig-cpu: registered to indicate activity on CPUs
[    0.886950] hidraw: raw HID events driver (C) Jiri Kosina
[    0.889943] usbcore: registered new interface driver usbhid
[    0.892869] usbhid: USB HID core driver
[    0.896427] vchiq: vchiq_init_state: slot_zero = ba980000, is_master = 0
[    0.903862] [vc_sm_connected_init]: start
[    0.912914] [vc_sm_connected_init]: end - returning 0
[    0.916601] Initializing XFRM netlink socket
[    0.919554] NET: Registered protocol family 17
[    0.922672] Key type dns_resolver registered
[    0.925958] Registering SWP/SWPB emulation handler
[    0.929805] registered taskstats version 1
[    0.940331] uart-pl011 3f201000.serial: cts_event_workaround enabled
[    0.943682] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    0.952273] sdhost: log_buf @ ba913000 (fa913000)
[    1.032181] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    1.036581] of_cfs_init
[    1.039696] of_cfs_init: OK
[    1.043336] Waiting for root device /dev/mmcblk0p7...
[    1.055670] Indeed it is in host mode hprt0 = 00021501
[    1.147864] random: fast init done
[    1.160321] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.169148] mmc0: new high speed SDHC card at address 0007
[    1.172811] mmcblk0: mmc0:0007 SD32G 29.0 GiB (quirks 0x80000000)
[    1.180657]  mmcblk0: p1 p2 < p5 p6 p7 > p3
[    1.225211] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[    1.231066] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[    1.245704] devtmpfs: mounted
[    1.252190] Freeing unused kernel memory: 1024K
[    1.262197] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    1.265831] Indeed it is in host mode hprt0 = 00001101
[    1.502593] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    1.508872] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.516139] hub 1-1:1.0: USB hub found
[    1.519497] hub 1-1:1.0: 5 ports detected
[    1.572734] random: systemd: uninitialized urandom read (16 bytes read)
[    1.582093] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    1.592747] systemd[1]: Detected architecture 'arm'.
[    1.713613] NET: Registered protocol family 10
[    1.718306] Segment Routing with IPv6
[    1.721654] systemd[1]: Inserted module 'ipv6'
[    1.727928] systemd[1]: Set hostname to <kix2.01.eu>.
[    1.842260] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    1.853161] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[    1.972653] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    1.979023] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.988380] smsc95xx v1.0.6
[    2.034393] random: systemd: uninitialized urandom read (16 bytes read)
[    2.087090] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:b9:65:1e
[    2.152285] Under-voltage detected! (0x00050005)
[    2.293328] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    2.300385] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.307188] systemd[1]: Starting Remote File Systems (Pre).
[    2.314893] systemd[1]: Reached target Remote File Systems (Pre).
[    2.318548] systemd[1]: Starting Encrypted Volumes.
[    2.326129] systemd[1]: Reached target Encrypted Volumes.
[    2.612428] fuse init (API version 7.26)
[    2.635181] i2c /dev entries driver
[    3.015805] systemd-udevd[123]: starting version 215
[    3.680317] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[    3.705714] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    3.719492] bcm2835_alsa bcm2835_alsa: card created with 8 channels
[    4.186260] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[    4.186581] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    4.517612] systemd-journald[120]: Received request to flush runtime journal from PID 1
[    5.790234] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
[    5.793712] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    5.889800] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[   13.901356] ip_tables: (C) 2000-2006 Netfilter Core Team
[   22.736471] random: crng init done
[   22.736488] random: 7 urandom warning(s) missed due to ratelimiting
 09:50:12 up 14 min,  2 users,  load average: 0.04, 0.07, 0.07
USER     TTY      FROM             LOGIN@   IDLE   JCPU   PCPU WHAT
pi       pts/0    192.168.1.4   09:34   12:20   3.13s  0.01s w
pi       tty1                      09:34   16:00   0.96s  0.86s -bash
filippos
Re: kernel Oops 5
Fri Jun 21, 2019 6:08 am
syslog (has no log at that time)
Jun 20 09:34:08 kix2 rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="418" x-info="http://www.rsyslog.com"] exiting on signal 15.
Jun 20 09:34:14 kix2 rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="418" x-info="http://www.rsyslog.com"] start
Jun 20 09:34:14 kix2 systemd-modules-load[91]: Failed to find module 'lp'
Jun 20 09:34:14 kix2 systemd-modules-load[91]: Failed to find module 'ppdev'
Jun 20 09:34:14 kix2 kernel: [    0.000000] Booting Linux on physical CPU 0xf00
Jun 20 09:34:14 kix2 kernel: [    0.000000] Linux version 4.14.94-v7+ (dom@dom-XPS-13-9370) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1193 SMP Tue Jan 22 15:34:30 GMT 2019
Jun 20 09:34:14 kix2 kernel: [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
Jun 20 09:34:14 kix2 kernel: [    0.000000] CPU: div instructions available: patching division code
Jun 20 09:34:14 kix2 systemd-modules-load[91]: Failed to find module 'parport_pc'
Jun 20 09:34:14 kix2 kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Jun 20 09:34:14 kix2 kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 2 Model B Rev 1.1
Jun 20 09:34:14 kix2 kernel: [    0.000000] Memory policy: Data cache writealloc
Jun 20 09:34:14 kix2 systemd-modules-load[91]: Inserted module 'fuse'
Jun 20 09:34:14 kix2 kernel: [    0.000000] cma: Reserved 8 MiB at 0x3a800000
Jun 20 09:34:14 kix2 kernel: [    0.000000] On node 0 totalpages: 241664
Jun 20 09:34:14 kix2 kernel: [    0.000000] free_area_init_node: node 0, pgdat 80c85780, node_mem_map b9fa8000
Jun 20 09:34:14 kix2 kernel: [    0.000000]   Normal zone: 2124 pages used for memmap
Jun 20 09:34:14 kix2 systemd-modules-load[91]: Inserted module 'i2c_dev'
Jun 20 09:34:14 kix2 kernel: [    0.000000]   Normal zone: 0 pages reserved
Jun 20 09:34:14 kix2 kernel: [    0.000000]   Normal zone: 241664 pages, LIFO batch:31
Jun 20 09:34:14 kix2 kernel: [    0.000000] percpu: Embedded 17 pages/cpu @b9f52000 s38720 r8192 d22720 u69632
Jun 20 09:34:14 kix2 systemd[1]: Mounted Configuration File System.
Jun 20 09:34:14 kix2 kernel: [    0.000000] pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*4096
Jun 20 09:34:14 kix2 kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Jun 20 09:34:14 kix2 kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 239540
Jun 20 09:34:14 kix2 kernel: [    0.000000] Kernel command line: bcm2708_fb.fbwidth=592 bcm2708_fb.fbheight=448 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Jun 20 09:34:14 kix2 systemd[1]: Mounted FUSE Control File System.
Jun 20 09:34:14 kix2 kernel: [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
Jun 20 09:34:14 kix2 kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Jun 20 09:34:14 kix2 kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Jun 20 09:34:14 kix2 systemd[1]: Started Apply Kernel Variables.
Jun 20 09:34:14 kix2 kernel: [    0.000000] Memory: 936176K/966656K available (7168K kernel code, 577K rwdata, 2080K rodata, 1024K init, 698K bss, 22288K reserved, 8192K cma-reserved)
Jun 20 09:34:14 kix2 kernel: [    0.000000] Virtual kernel memory layout:
Jun 20 09:34:14 kix2 kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Jun 20 09:34:14 kix2 systemd[1]: Started Create Static Device Nodes in /dev.
Jun 20 09:34:14 kix2 kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Jun 20 09:34:14 kix2 kernel: [    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
Jun 20 09:34:14 kix2 kernel: [    0.000000]     lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
Jun 20 09:34:14 kix2 kernel: [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
Jun 20 09:34:14 kix2 systemd[1]: Starting udev Kernel Device Manager...
Jun 20 09:34:14 kix2 kernel: [    0.000000]       .text : 0x80008000 - 0x80800000   (8160 kB)
Jun 20 09:34:14 kix2 kernel: [    0.000000]       .init : 0x80b00000 - 0x80c00000   (1024 kB)
Jun 20 09:34:14 kix2 kernel: [    0.000000]       .data : 0x80c00000 - 0x80c906b4   ( 578 kB)
Jun 20 09:34:14 kix2 systemd[1]: Started udev Kernel Device Manager.
Jun 20 09:34:14 kix2 kernel: [    0.000000]        .bss : 0x80c97ef8 - 0x80d468f0   ( 699 kB)
Jun 20 09:34:14 kix2 kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Jun 20 09:34:14 kix2 kernel: [    0.000000] ftrace: allocating 25296 entries in 75 pages
Jun 20 09:34:14 kix2 kernel: [    0.000000] Hierarchical RCU implementation.
Jun 20 09:34:14 kix2 systemd[1]: Starting LSB: Set preliminary keymap...
Jun 20 09:34:14 kix2 kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Jun 20 09:34:14 kix2 kernel: [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
Jun 20 09:34:14 kix2 kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Jun 20 09:34:14 kix2 systemd[1]: Starting LSB: Tune IDE hard disks...
Jun 20 09:34:14 kix2 kernel: [    0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Jun 20 09:34:14 kix2 kernel: [    0.000030] Switching to timer-based delay loop, resolution 52ns
Jun 20 09:34:14 kix2 kernel: [    0.000349] Console: colour dummy device 80x30
Jun 20 09:34:14 kix2 kernel: [    0.000973] console [tty1] enabled
Jun 20 09:34:14 kix2 fake-hwclock[85]: Thu Jun 20 06:34:11 UTC 2019
Jun 20 09:34:14 kix2 kernel: [    0.001018] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
Jun 20 09:34:14 kix2 kernel: [    0.001068] pid_max: default: 32768 minimum: 301
Jun 20 09:34:14 kix2 kernel: [    0.001492] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Jun 20 09:34:14 kix2 kernel: [    0.001538] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Jun 20 09:34:14 kix2 systemd[1]: Started Copy rules generated while the root was ro.
Jun 20 09:34:14 kix2 kernel: [    0.002763] Disabling memory control group subsystem
Jun 20 09:34:14 kix2 kernel: [    0.002922] CPU: Testing write buffer coherency: ok
Jun 20 09:34:14 kix2 kernel: [    0.003551] CPU0: update cpu_capacity 1024
Jun 20 09:34:14 kix2 kernel: [    0.003589] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
Jun 20 09:34:14 kix2 systemd-fsck[93]: e2fsck 1.43.3 (04-Sep-2016)
Jun 20 09:34:14 kix2 kernel: [    0.004237] Setting up static identity map for 0x100000 - 0x10003c
Jun 20 09:34:14 kix2 kernel: [    0.004460] Hierarchical SRCU implementation.
Jun 20 09:34:14 kix2 kernel: [    0.005513] smp: Bringing up secondary CPUs ...
Jun 20 09:34:14 kix2 kernel: [    0.006711] CPU1: update cpu_capacity 1024
Jun 20 09:34:14 kix2 systemd-fsck[93]: root: clean, 141714/1794048 files, 1507734/7171072 blocks
Jun 20 09:34:14 kix2 kernel: [    0.006723] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
Jun 20 09:34:14 kix2 kernel: [    0.007985] CPU2: update cpu_capacity 1024
Jun 20 09:34:14 kix2 kernel: [    0.007995] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
Jun 20 09:34:14 kix2 kernel: [    0.009204] CPU3: update cpu_capacity 1024
Jun 20 09:34:14 kix2 hdparm[127]: Setting parameters of disc: (none).
Jun 20 09:34:14 kix2 kernel: [    0.009214] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
Jun 20 09:34:14 kix2 kernel: [    0.009364] smp: Brought up 1 node, 4 CPUs
Jun 20 09:34:14 kix2 kernel: [    0.009509] SMP: Total of 4 processors activated (153.60 BogoMIPS).
Jun 20 09:34:14 kix2 kernel: [    0.009534] CPU: All CPU(s) started in HYP mode.
Jun 20 09:34:14 kix2 systemd[1]: Started LSB: Tune IDE hard disks.
Jun 20 09:34:14 kix2 kernel: [    0.009556] CPU: Virtualization extensions available.
Jun 20 09:34:14 kix2 kernel: [    0.010883] devtmpfs: initialized
Jun 20 09:34:14 kix2 kernel: [    0.023231] random: get_random_u32 called from bucket_table_alloc+0xfc/0x24c with crng_init=0
Jun 20 09:34:14 kix2 keyboard-setup[125]: Setting preliminary keymap...done.
Jun 20 09:34:14 kix2 kernel: [    0.024030] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
Jun 20 09:34:14 kix2 kernel: [    0.024392] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Jun 20 09:34:14 kix2 kernel: [    0.024453] futex hash table entries: 1024 (order: 4, 65536 bytes)
Jun 20 09:34:14 kix2 kernel: [    0.025292] pinctrl core: initialized pinctrl subsystem
Jun 20 09:34:14 kix2 systemd[1]: Started LSB: Set preliminary keymap.
Jun 20 09:34:14 kix2 kernel: [    0.026429] NET: Registered protocol family 16
Jun 20 09:34:14 kix2 kernel: [    0.029591] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Jun 20 09:34:14 kix2 systemd[1]: Starting Show Plymouth Boot Screen...
Jun 20 09:34:14 kix2 kernel: [    0.035651] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Jun 20 09:34:14 kix2 kernel: [    0.035703] hw-breakpoint: maximum watchpoint size is 8 bytes.
Jun 20 09:34:14 kix2 kernel: [    0.035984] Serial: AMBA PL011 UART driver
Jun 20 09:34:14 kix2 systemd[1]: Starting Remount Root and Kernel File Systems...
Jun 20 09:34:14 kix2 kernel: [    0.038316] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
Jun 20 09:34:14 kix2 kernel: [    0.079761] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dmachans=0x1
Jun 20 09:34:14 kix2 kernel: [    0.081803] SCSI subsystem initialized
Jun 20 09:34:14 kix2 kernel: [    0.082151] usbcore: registered new interface driver usbfs
Jun 20 09:34:14 kix2 kernel: [    0.082247] usbcore: registered new interface driver hub
Jun 20 09:34:14 kix2 systemd[1]: Started Remount Root and Kernel File Systems.
Jun 20 09:34:14 kix2 kernel: [    0.082408] usbcore: registered new device driver usb
Jun 20 09:34:14 kix2 kernel: [    0.090408] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-01-22 16:50
Jun 20 09:34:14 kix2 kernel: [    0.092141] clocksource: Switched to clocksource arch_sys_counter
Jun 20 09:34:14 kix2 systemd[1]: Started Various fixups to make systemd work better on Debian.
Jun 20 09:34:14 kix2 kernel: [    0.179219] VFS: Disk quotas dquot_6.6.0
Jun 20 09:34:14 kix2 kernel: [    0.179381] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jun 20 09:34:14 kix2 kernel: [    0.179662] FS-Cache: Loaded
Jun 20 09:34:14 kix2 kernel: [    0.179979] CacheFiles: Loaded
Jun 20 09:34:14 kix2 systemd[1]: Starting Local File Systems (Pre).
Jun 20 09:34:14 kix2 kernel: [    0.192873] NET: Registered protocol family 2
Jun 20 09:34:14 kix2 kernel: [    0.193902] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Jun 20 09:34:14 kix2 kernel: [    0.194063] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Jun 20 09:34:14 kix2 systemd[1]: Reached target Local File Systems (Pre).
Jun 20 09:34:14 kix2 kernel: [    0.194275] TCP: Hash tables configured (established 8192 bind 8192)
Jun 20 09:34:14 kix2 kernel: [    0.194480] UDP hash table entries: 512 (order: 2, 16384 bytes)
Jun 20 09:34:14 kix2 kernel: [    0.194564] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Jun 20 09:34:14 kix2 systemd[1]: Starting Load/Save Random Seed...
Jun 20 09:34:14 kix2 kernel: [    0.194914] NET: Registered protocol family 1
Jun 20 09:34:14 kix2 kernel: [    0.195642] RPC: Registered named UNIX socket transport module.
Jun 20 09:34:14 kix2 kernel: [    0.195680] RPC: Registered udp transport module.
Jun 20 09:34:14 kix2 kernel: [    0.195704] RPC: Registered tcp transport module.
Jun 20 09:34:14 kix2 systemd[1]: Started Load/Save Random Seed.
Jun 20 09:34:14 kix2 kernel: [    0.195728] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jun 20 09:34:14 kix2 kernel: [    0.197620] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
Jun 20 09:34:14 kix2 kernel: [    0.201468] workingset: timestamp_bits=14 max_order=18 bucket_order=4
Jun 20 09:34:14 kix2 systemd-udevd[208]: failed to execute '/lib/udev/mtp-probe' 'mtp-probe /sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1 1 3': No such file or directory
Jun 20 09:34:14 kix2 kernel: [    0.212027] FS-Cache: Netfs 'nfs' registered for caching
Jun 20 09:34:14 kix2 kernel: [    0.213012] NFS: Registering the id_resolver key type
Jun 20 09:34:14 kix2 kernel: [    0.213084] Key type id_resolver registered
Jun 20 09:34:14 kix2 kernel: [    0.213109] Key type id_legacy registered
Jun 20 09:34:14 kix2 systemd[1]: Received SIGRTMIN+20 from PID 199 (plymouthd).
Jun 20 09:34:14 kix2 kernel: [    0.213148] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Jun 20 09:34:14 kix2 kernel: [    0.216002] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Jun 20 09:34:14 kix2 kernel: [    0.216255] io scheduler noop registered
Jun 20 09:34:14 kix2 kernel: [    0.216287] io scheduler deadline registered (default)
Jun 20 09:34:14 kix2 systemd[1]: Started Show Plymouth Boot Screen.
Jun 20 09:34:14 kix2 kernel: [    0.216553] io scheduler cfq registered
Jun 20 09:34:14 kix2 kernel: [    0.216583] io scheduler mq-deadline registered
Jun 20 09:34:14 kix2 kernel: [    0.216608] io scheduler kyber registered
Jun 20 09:34:14 kix2 kernel: [    0.218926] BCM2708FB: allocated DMA memory fa900000
Jun 20 09:34:14 kix2 systemd[1]: Starting Forward Password Requests to Plymouth Directory Watch.
Jun 20 09:34:14 kix2 kernel: [    0.219004] BCM2708FB: allocated DMA channel 0 @ bb813000
Jun 20 09:34:14 kix2 kernel: [    0.228294] Console: switching to colour frame buffer device 74x28
Jun 20 09:34:14 kix2 kernel: [    0.238278] bcm2835-rng 3f104000.rng: hwrng registered
Jun 20 09:34:14 kix2 systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Jun 20 09:34:14 kix2 systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Jun 20 09:34:14 kix2 ifplugd(lo)[229]: ifplugd 0.28 initializing.
Jun 20 09:34:14 kix2 ifplugd(lo)[229]: Using interface lo/00:00:00:00:00:00
Jun 20 09:34:14 kix2 ifplugd(lo)[229]: Using detection mode: SIOCETHTOOL
Jun 20 09:34:14 kix2 ifplugd(lo)[229]: Initialization complete, link beat detected.
Jun 20 09:34:14 kix2 systemd[1]: Starting Sound Card.
Jun 20 09:34:14 kix2 systemd[1]: Reached target Sound Card.
Jun 20 09:34:14 kix2 ifplugd(eth0)[234]: ifplugd 0.28 initializing.
Jun 20 09:34:14 kix2 systemd[1]: Found device /dev/mmcblk0p6.
Jun 20 09:34:14 kix2 systemd[1]: Starting File System Check on /dev/mmcblk0p6...
Jun 20 09:34:14 kix2 ifplugd(lo)[229]: Executing '/etc/ifplugd/ifplugd.action lo up'.
Jun 20 09:34:14 kix2 ifplugd(eth0)[234]: Using interface eth0/B8:27:EB:B9:65:1E with driver <smsc95xx> (version: 22-Aug-2005)
Jun 20 09:34:14 kix2 ifplugd(eth0)[234]: Using detection mode: SIOCETHTOOL
Jun 20 09:34:14 kix2 ifplugd(eth0)[234]: Initialization complete, link beat not detected.
Jun 20 09:34:14 kix2 ifplugd(lo)[229]: client: /sbin/ifup: failed to open lockfile /run/network/.ifstate.lock: No such file or directory
Jun 20 09:34:14 kix2 ifplugd(lo)[229]: client: run-parts: /etc/ifplugd/action.d//ifupdown exited with return code 1
Jun 20 09:34:14 kix2 systemd-fsck[237]: fsck.fat 3.0.27 (2014-11-12)
Jun 20 09:34:14 kix2 systemd-fsck[237]: /dev/mmcblk0p6: 184 files, 11266/30651 clusters
Jun 20 09:34:14 kix2 systemd[1]: Started File System Check on /dev/mmcblk0p6.
Jun 20 09:34:14 kix2 kernel: [    0.241107] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
Jun 20 09:34:14 kix2 kernel: [    0.247266] vc-sm: Videocore shared memory driver
Jun 20 09:34:14 kix2 kernel: [    0.250540] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
Jun 20 09:34:14 kix2 systemd[1]: Mounting /boot...
Jun 20 09:34:14 kix2 kernel: [    0.270405] brd: module loaded
Jun 20 09:34:14 kix2 kernel: [    0.285176] loop: module loaded
Jun 20 09:34:14 kix2 kernel: [    0.287893] Loading iSCSI transport class v2.0-870.
Jun 20 09:34:14 kix2 ifplugd(lo)[229]: Program execution failed, return value is 1.
Jun 20 09:34:14 kix2 kernel: [    0.291476] libphy: Fixed MDIO Bus: probed
Jun 20 09:34:14 kix2 systemd[1]: Mounted /boot.
Jun 20 09:34:14 kix2 kernel: [    0.294385] usbcore: registered new interface driver lan78xx
Jun 20 09:34:14 kix2 kernel: [    0.297243] usbcore: registered new interface driver smsc95xx
Jun 20 09:34:14 kix2 kernel: [    0.299935] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Jun 20 09:34:14 kix2 kernel: [    0.330568] dwc_otg 3f980000.usb: base=0xf0980000
Jun 20 09:34:14 kix2 kernel: [    0.533517] Core Release: 2.80a
Jun 20 09:34:14 kix2 systemd[1]: Starting Local File Systems.
Jun 20 09:34:14 kix2 kernel: [    0.536071] Setting default values for core params
Jun 20 09:34:14 kix2 kernel: [    0.538704] Finished setting default values for core params
Jun 20 09:34:14 kix2 kernel: [    0.741685] Using Buffer DMA mode
Jun 20 09:34:14 kix2 kernel: [    0.744386] Periodic Transfer Interrupt Enhancement - disabled
Jun 20 09:34:14 kix2 systemd[1]: Reached target Local File Systems.
Jun 20 09:34:14 kix2 kernel: [    0.747188] Multiprocessor Interrupt Enhancement - disabled
Jun 20 09:34:14 kix2 kernel: [    0.750000] OTG VER PARAM: 0, OTG VER FLAG: 0
Jun 20 09:34:14 kix2 systemd[1]: Starting Create Volatile Files and Directories...
Jun 20 09:34:14 kix2 kernel: [    0.752870] Dedicated Tx FIFOs mode
Jun 20 09:34:14 kix2 kernel: [    0.756241] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xba914000 dma = 0xfa914000 len=9024
Jun 20 09:34:14 kix2 systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Jun 20 09:34:14 kix2 kernel: [    0.761913] FIQ FSM acceleration enabled for :
Jun 20 09:34:14 kix2 kernel: [    0.761913] Non-periodic Split Transactions
Jun 20 09:34:14 kix2 kernel: [    0.761913] Periodic Split Transactions
Jun 20 09:34:14 kix2 kernel: [    0.761913] High-Speed Isochronous Endpoints
Jun 20 09:34:14 kix2 systemd[1]: Starting LSB: Raise network interfaces....
Jun 20 09:34:14 kix2 kernel: [    0.761913] Interrupt/Control Split Transaction hack enabled
Jun 20 09:34:14 kix2 kernel: [    0.775202] dwc_otg: Microframe scheduler enabled
Jun 20 09:34:14 kix2 systemd[1]: Starting Remote File Systems.
Jun 20 09:34:14 kix2 kernel: [    0.775278] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805ed1d4
Jun 20 09:34:14 kix2 kernel: [    0.778002] WARN::hcd_init_fiq:460: FIQ ASM at 0x805ed53c length 36
Jun 20 09:34:14 kix2 kernel: [    0.780710] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
Jun 20 09:34:14 kix2 systemd[1]: Reached target Remote File Systems.
Jun 20 09:34:14 kix2 kernel: [    0.783484] dwc_otg 3f980000.usb: DWC OTG Controller
Jun 20 09:34:14 kix2 kernel: [    0.786190] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
Jun 20 09:34:14 kix2 kernel: [    0.791627] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
Jun 20 09:34:14 kix2 kernel: [    0.794527] Init: Port Power? op_state=1
Jun 20 09:34:14 kix2 systemd[1]: Starting Trigger Flushing of Journal to Persistent Storage...
Jun 20 09:34:14 kix2 kernel: [    0.797309] Init: Power Port (0)
Jun 20 09:34:14 kix2 kernel: [    0.800323] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jun 20 09:34:14 kix2 kernel: [    0.805897] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 20 09:34:14 kix2 kernel: [    0.811595] usb usb1: Product: DWC OTG Controller
Jun 20 09:34:14 kix2 systemd[1]: Starting LSB: Prepare console...
Jun 20 09:34:14 kix2 kernel: [    0.814528] usb usb1: Manufacturer: Linux 4.14.94-v7+ dwc_otg_hcd
Jun 20 09:34:14 kix2 kernel: [    0.817504] usb usb1: SerialNumber: 3f980000.usb
Jun 20 09:34:14 kix2 kernel: [    0.821215] hub 1-0:1.0: USB hub found
Jun 20 09:34:14 kix2 systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Jun 20 09:34:14 kix2 kernel: [    0.824151] hub 1-0:1.0: 1 port detected
Jun 20 09:34:14 kix2 kernel: [    0.827595] dwc_otg: FIQ enabled
Jun 20 09:34:14 kix2 kernel: [    0.827602] dwc_otg: NAK holdoff enabled
Jun 20 09:34:14 kix2 kernel: [    0.827608] dwc_otg: FIQ split-transaction FSM enabled
Jun 20 09:34:14 kix2 systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Jun 20 09:34:14 kix2 kernel: [    0.827620] Module dwc_common_port init
Jun 20 09:34:14 kix2 kernel: [    0.827963] usbcore: registered new interface driver usb-storage
Jun 20 09:34:14 kix2 kernel: [    0.831094] mousedev: PS/2 mouse device common for all mice
Jun 20 09:34:14 kix2 systemd[1]: Started Trigger Flushing of Journal to Persistent Storage.
Jun 20 09:34:14 kix2 kernel: [    0.834122] IR NEC protocol handler initialized
Jun 20 09:34:14 kix2 kernel: [    0.837030] IR RC5(x/sz) protocol handler initialized
Jun 20 09:34:14 kix2 kernel: [    0.839929] IR RC6 protocol handler initialized
Jun 20 09:34:14 kix2 systemd[1]: Started Create Volatile Files and Directories.
Jun 20 09:34:14 kix2 kernel: [    0.842861] IR JVC protocol handler initialized
Jun 20 09:34:14 kix2 kernel: [    0.845665] IR Sony protocol handler initialized
Jun 20 09:34:14 kix2 kernel: [    0.848457] IR SANYO protocol handler initialized
Jun 20 09:34:14 kix2 kernel: [    0.851209] IR Sharp protocol handler initialized
Jun 20 09:34:14 kix2 kbd[262]: Setting console screen modes.
Jun 20 09:34:14 kix2 kernel: [    0.853927] IR MCE Keyboard/mouse protocol handler initialized
Jun 20 09:34:14 kix2 kernel: [    0.856604] IR XMP protocol handler initialized
Jun 20 09:34:14 kix2 kernel: [    0.860157] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
Jun 20 09:34:14 kix2 raspi-config[263]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Jun 20 09:34:14 kix2 kernel: [    0.865936] bcm2835-cpufreq: min=600000 max=600000
Jun 20 09:34:14 kix2 kernel: [    0.869140] sdhci: Secure Digital Host Controller Interface driver
Jun 20 09:34:14 kix2 kernel: [    0.871894] sdhci: Copyright(c) Pierre Ossman
Jun 20 09:34:14 kix2 kernel: [    0.875067] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
Jun 20 09:34:14 kix2 kernel: [    0.880453] sdhci-pltfm: SDHCI platform and OF driver helper
Jun 20 09:34:14 kix2 raspi-config[263]: No. Switching to ondemand scaling governor.
Jun 20 09:34:14 kix2 kernel: [    0.884017] ledtrig-cpu: registered to indicate activity on CPUs
Jun 20 09:34:14 kix2 kernel: [    0.886950] hidraw: raw HID events driver (C) Jiri Kosina
Jun 20 09:34:14 kix2 kernel: [    0.889943] usbcore: registered new interface driver usbhid
Jun 20 09:34:14 kix2 kernel: [    0.892869] usbhid: USB HID core driver
Jun 20 09:34:14 kix2 systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Jun 20 09:34:14 kix2 kernel: [    0.896427] vchiq: vchiq_init_state: slot_zero = ba980000, is_master = 0
Jun 20 09:34:14 kix2 kernel: [    0.903862] [vc_sm_connected_init]: start
Jun 20 09:34:14 kix2 kernel: [    0.912914] [vc_sm_connected_init]: end - returning 0
Jun 20 09:34:14 kix2 systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Jun 20 09:34:14 kix2 kernel: [    0.916601] Initializing XFRM netlink socket
Jun 20 09:34:14 kix2 kernel: [    0.919554] NET: Registered protocol family 17
Jun 20 09:34:14 kix2 kernel: [    0.922672] Key type dns_resolver registered
Jun 20 09:34:14 kix2 kernel: [    0.925958] Registering SWP/SWPB emulation handler
Jun 20 09:34:14 kix2 systemd[1]: Started Update UTMP about System Boot/Shutdown.
Jun 20 09:34:14 kix2 kernel: [    0.929805] registered taskstats version 1
Jun 20 09:34:14 kix2 kernel: [    0.940331] uart-pl011 3f201000.serial: cts_event_workaround enabled
Jun 20 09:34:14 kix2 kbd[262]: setterm: $TERM is not defined.
Jun 20 09:34:14 kix2 kernel: [    0.943682] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
Jun 20 09:34:14 kix2 kernel: [    0.952273] sdhost: log_buf @ ba913000 (fa913000)
Jun 20 09:34:14 kix2 kernel: [    1.032181] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Jun 20 09:34:14 kix2 systemd[1]: Started LSB: Prepare console.
Jun 20 09:34:14 kix2 kernel: [    1.036581] of_cfs_init
Jun 20 09:34:14 kix2 kernel: [    1.039696] of_cfs_init: OK
Jun 20 09:34:14 kix2 kernel: [    1.043336] Waiting for root device /dev/mmcblk0p7...
Jun 20 09:34:14 kix2 kernel: [    1.055670] Indeed it is in host mode hprt0 = 00021501
Jun 20 09:34:14 kix2 systemd[1]: Starting LSB: Set console font and keymap...
Jun 20 09:34:14 kix2 kernel: [    1.147864] random: fast init done
Jun 20 09:34:14 kix2 kernel: [    1.160321] mmc0: host does not support reading read-only switch, assuming write-enable
Jun 20 09:34:14 kix2 kernel: [    1.169148] mmc0: new high speed SDHC card at address 0007
Jun 20 09:34:14 kix2 networking[259]: Configuring network interfaces...done.
Jun 20 09:34:14 kix2 kernel: [    1.172811] mmcblk0: mmc0:0007 SD32G 29.0 GiB (quirks 0x80000000)
Jun 20 09:34:14 kix2 kernel: [    1.180657]  mmcblk0: p1 p2 < p5 p6 p7 > p3
Jun 20 09:34:14 kix2 kernel: [    1.225211] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
Jun 20 09:34:14 kix2 kernel: [    1.231066] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
Jun 20 09:34:14 kix2 kernel: [    1.245704] devtmpfs: mounted
Jun 20 09:34:14 kix2 systemd[1]: Started LSB: Raise network interfaces..
Jun 20 09:34:14 kix2 kernel: [    1.252190] Freeing unused kernel memory: 1024K
Jun 20 09:34:14 kix2 kernel: [    1.262197] usb 1-1: new high-speed USB device number 2 using dwc_otg
Jun 20 09:34:14 kix2 kernel: [    1.265831] Indeed it is in host mode hprt0 = 00001101
Jun 20 09:34:14 kix2 console-setup[329]: Setting up console font and keymap...done.
Jun 20 09:34:14 kix2 kernel: [    1.502593] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Jun 20 09:34:14 kix2 kernel: [    1.508872] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 20 09:34:14 kix2 kernel: [    1.516139] hub 1-1:1.0: USB hub found
Jun 20 09:34:14 kix2 kernel: [    1.519497] hub 1-1:1.0: 5 ports detected
Jun 20 09:34:14 kix2 systemd[1]: Started LSB: Set console font and keymap.
Jun 20 09:34:14 kix2 kernel: [    1.572734] random: systemd: uninitialized urandom read (16 bytes read)
Jun 20 09:34:14 kix2 kernel: [    1.713613] NET: Registered protocol family 10
Jun 20 09:34:14 kix2 kernel: [    1.718306] Segment Routing with IPv6
Jun 20 09:34:14 kix2 systemd[1]: Starting System Initialization.
Jun 20 09:34:14 kix2 kernel: [    1.842260] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Jun 20 09:34:14 kix2 kernel: [    1.853161] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
Jun 20 09:34:14 kix2 kernel: [    1.972653] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Jun 20 09:34:14 kix2 systemd[1]: Reached target System Initialization.
Jun 20 09:34:14 kix2 kernel: [    1.979023] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 20 09:34:14 kix2 kernel: [    1.988380] smsc95xx v1.0.6
Jun 20 09:34:14 kix2 systemd[1]: Starting Avahi mDNS/DNS-SD Stack Activation Socket.
Jun 20 09:34:14 kix2 kernel: [    2.034393] random: systemd: uninitialized urandom read (16 bytes read)
Jun 20 09:34:14 kix2 kernel: [    2.087090] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:b9:65:1e
Jun 20 09:34:14 kix2 systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Jun 20 09:34:14 kix2 kernel: [    2.152285] Under-voltage detected! (0x00050005)
Jun 20 09:34:14 kix2 kernel: [    2.612428] fuse init (API version 7.26)
Jun 20 09:34:14 kix2 kernel: [    2.635181] i2c /dev entries driver
Jun 20 09:34:14 kix2 systemd[1]: Starting D-Bus System Message Bus Socket.
Jun 20 09:34:14 kix2 kernel: [    3.680317] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
Jun 20 09:34:14 kix2 kernel: [    3.705714] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Jun 20 09:34:14 kix2 kernel: [    3.719492] bcm2835_alsa bcm2835_alsa: card created with 8 channels
Jun 20 09:34:14 kix2 kernel: [    4.186260] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Jun 20 09:34:14 kix2 systemd[1]: Listening on D-Bus System Message Bus Socket.
Jun 20 09:34:14 kix2 kernel: [    4.186581] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Jun 20 09:34:14 kix2 systemd[1]: Starting Daily Cleanup of Temporary Directories.
Jun 20 09:34:14 kix2 systemd[1]: Started Daily Cleanup of Temporary Directories.
Jun 20 09:34:14 kix2 systemd[1]: Starting Timers.
Jun 20 09:34:14 kix2 systemd[1]: Reached target Timers.
Jun 20 09:34:14 kix2 systemd[1]: Starting CUPS Printing Service Sockets.
Jun 20 09:34:14 kix2 systemd[1]: Listening on CUPS Printing Service Sockets.
Jun 20 09:34:14 kix2 systemd[1]: Starting Sockets.
Jun 20 09:34:14 kix2 systemd[1]: Reached target Sockets.
Jun 20 09:34:14 kix2 systemd[1]: Starting CUPS Printer Service Spool.
Jun 20 09:34:14 kix2 systemd[1]: Started CUPS Printer Service Spool.
Jun 20 09:34:14 kix2 systemd[1]: Starting Paths.
Jun 20 09:34:14 kix2 systemd[1]: Reached target Paths.
Jun 20 09:34:14 kix2 systemd[1]: Started Manage Sound Card State (restore and store).
Jun 20 09:34:14 kix2 systemd[1]: Starting Restore Sound Card State...
Jun 20 09:34:14 kix2 systemd[1]: Starting Basic System.
Jun 20 09:34:14 kix2 systemd[1]: Reached target Basic System.
Jun 20 09:34:14 kix2 systemd[1]: Starting LSB: Autogenerate and use a swap file...
Jun 20 09:34:14 kix2 systemd[1]: Starting LSB: triggerhappy hotkey daemon...
Jun 20 09:34:14 kix2 systemd[1]: Starting LSB: Start Motion detection...
Jun 20 09:34:14 kix2 systemd[1]: Started Turn on SSH if /boot/ssh is present.
Jun 20 09:34:14 kix2 systemd[1]: Started Configure Bluetooth Modems connected by UART.
Jun 20 09:34:14 kix2 systemd[1]: Starting System Logging Service...
Jun 20 09:34:14 kix2 systemd[1]: Starting Self Monitoring and Reporting Technology (SMART) Daemon...
Jun 20 09:34:14 kix2 systemd[1]: Started Self Monitoring and Reporting Technology (SMART) Daemon.
Jun 20 09:34:14 kix2 systemd[1]: Starting Regular background program processing daemon...
Jun 20 09:34:14 kix2 systemd[1]: Started Regular background program processing daemon.
Jun 20 09:34:14 kix2 systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Jun 20 09:34:14 kix2 systemd[1]: Starting dhcpcd on all interfaces...
Jun 20 09:34:14 kix2 systemd[1]: Starting D-Bus System Message Bus...
Jun 20 09:34:14 kix2 systemd[1]: Started D-Bus System Message Bus.
Jun 20 09:34:14 kix2 cron[427]: (CRON) INFO (pidfile fd = 3)
Jun 20 09:34:14 kix2 dphys-swapfile[415]: Starting dphys-swapfile swapfile setup ...
Jun 20 09:34:14 kix2 motion[417]: Not starting motion daemon, disabled via /etc/default/motion ... (warning).
Jun 20 09:34:14 kix2 triggerhappy[416]: Error opening '/dev/input/event*': No such file or directory
Jun 20 09:34:14 kix2 cron[427]: (CRON) INFO (Running @reboot jobs)
Jun 20 09:34:14 kix2 dhcpcd[431]: dhcpcd[431]: unknown option: SSID
Jun 20 09:34:14 kix2 dhcpcd[431]: unknown option: SSID
Jun 20 09:34:14 kix2 dhcpcd[431]: version 6.7.1 starting
Jun 20 09:34:14 kix2 dhcpcd[431]: dev: loaded udev
Jun 20 09:34:14 kix2 avahi-daemon[429]: Found user 'avahi' (UID 106) and group 'avahi' (GID 111).
Jun 20 09:34:14 kix2 avahi-daemon[429]: Successfully dropped root privileges.
Jun 20 09:34:14 kix2 avahi-daemon[429]: avahi-daemon 0.6.31 starting up.
Jun 20 09:34:14 kix2 dhcpcd[431]: eth0: adding address fe80::ac4f:2f4c:5dda:dd9
Jun 20 09:34:14 kix2 dhcpcd[431]: forked to background, child pid 457
Jun 20 09:34:14 kix2 dphys-swapfile[415]: want /var/swap=100MByte, checking existing: keeping it
Jun 20 09:34:14 kix2 kernel: [    5.790234] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
Jun 20 09:34:14 kix2 kernel: [    5.793712] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Jun 20 09:34:14 kix2 avahi-daemon[429]: Successfully called chroot().
Jun 20 09:34:14 kix2 avahi-daemon[429]: Successfully dropped remaining capabilities.
Jun 20 09:34:14 kix2 avahi-daemon[429]: Loading service file /services/udisks.service.
Jun 20 09:34:14 kix2 avahi-daemon[429]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::ac4f:2f4c:5dda:dd9.
Jun 20 09:34:14 kix2 avahi-daemon[429]: New relevant interface eth0.IPv6 for mDNS.
Jun 20 09:34:14 kix2 avahi-daemon[429]: Network interface enumeration completed.
Jun 20 09:34:14 kix2 avahi-daemon[429]: Registering new address record for fe80::ac4f:2f4c:5dda:dd9 on eth0.*.
Jun 20 09:34:14 kix2 avahi-daemon[429]: Registering HINFO record with values 'ARMV7L'/'LINUX'.
Jun 20 09:34:14 kix2 systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Jun 20 09:34:14 kix2 systemd[1]: Starting Login Service...
Jun 20 09:34:14 kix2 systemd[1]: Started getty on tty2-tty6 if dbus and logind are not available.
Jun 20 09:34:14 kix2 kernel: [    5.889800] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
Jun 20 09:34:14 kix2 systemd[1]: Starting CUPS Printing Service...
Jun 20 09:34:14 kix2 systemd[1]: Started CUPS Printing Service.
Jun 20 09:34:14 kix2 systemd[1]: Starting Make remote CUPS printers available locally...
Jun 20 09:34:14 kix2 systemd[1]: Started Make remote CUPS printers available locally.
Jun 20 09:34:14 kix2 systemd[1]: Started System Logging Service.
Jun 20 09:34:14 kix2 dphys-swapfile[415]: done.
Jun 20 09:34:14 kix2 systemd[1]: Started Restore Sound Card State.
Jun 20 09:34:14 kix2 smartd[422]: smartd 6.4 2014-10-07 r4002 [armv7l-linux-4.14.94-v7+] (local build)
Jun 20 09:34:14 kix2 smartd[422]: Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org
Jun 20 09:34:14 kix2 smartd[422]: Opened configuration file /etc/smartd.conf
Jun 20 09:34:14 kix2 smartd[422]: Drive: DEVICESCAN, implied '-a' Directive on line 21 of file /etc/smartd.conf
Jun 20 09:34:14 kix2 smartd[422]: Configuration file /etc/smartd.conf was parsed, found DEVICESCAN, scanning devices
Jun 20 09:34:14 kix2 systemd[1]: Started LSB: Autogenerate and use a swap file.
Jun 20 09:34:14 kix2 systemd[1]: Started LSB: triggerhappy hotkey daemon.
Jun 20 09:34:14 kix2 systemd[1]: Started LSB: Start Motion detection.
Jun 20 09:34:14 kix2 systemd[1]: Started dhcpcd on all interfaces.
Jun 20 09:34:14 kix2 smartd[422]: Problem creating device name scan list
Jun 20 09:34:14 kix2 smartd[422]: In the system's table of devices NO devices found to scan
Jun 20 09:34:14 kix2 smartd[422]: Unable to monitor any SMART enabled devices. Try debug (-d) option. Exiting...
Jun 20 09:34:14 kix2 systemd[1]: smartd.service: main process exited, code=exited, status=17/n/a
Jun 20 09:34:14 kix2 systemd[1]: Unit smartd.service entered failed state.
Jun 20 09:34:14 kix2 systemd[1]: Starting Network.
Jun 20 09:34:14 kix2 systemd[1]: Reached target Network.
Jun 20 09:34:14 kix2 systemd[1]: Starting Network is Online.
Jun 20 09:34:14 kix2 systemd[1]: Reached target Network is Online.
Jun 20 09:34:14 kix2 systemd[1]: Starting LSB: Start/stop fail2ban...
Jun 20 09:34:14 kix2 systemd[1]: Starting LSB: Apache2 web server...
Jun 20 09:34:14 kix2 systemd[1]: Starting LSB: Start NTP daemon...
Jun 20 09:34:14 kix2 systemd[1]: Starting LSB: Brings up/down network automatically...
Jun 20 09:34:14 kix2 systemd[1]: Starting LSB: exim Mail Transport Agent...
Jun 20 09:34:14 kix2 systemd[1]: Starting OpenVPN service...
Jun 20 09:34:14 kix2 systemd[1]: Starting The PHP FastCGI Process Manager...
Jun 20 09:34:14 kix2 systemd[1]: Starting OpenBSD Secure Shell server...
Jun 20 09:34:14 kix2 systemd[1]: Starting /etc/rc.local Compatibility...
Jun 20 09:34:14 kix2 systemd[1]: Starting Permit User Sessions...
Jun 20 09:34:14 kix2 ifplugd(eth0)[234]: Link beat detected.
Jun 20 09:34:14 kix2 systemd[1]: Started OpenVPN service.
Jun 20 09:34:14 kix2 systemd[1]: Started /etc/rc.local Compatibility.
Jun 20 09:34:14 kix2 systemd[1]: Started Permit User Sessions.
Jun 20 09:34:14 kix2 systemd[1]: Started Login Service.
Jun 20 09:34:14 kix2 ifplugd[514]: Network Interface Plugging Daemon...skip eth0...done.
Jun 20 09:34:14 kix2 systemd[1]: Started LSB: Brings up/down network automatically.
Jun 20 09:34:14 kix2 ifplugd(eth0)[234]: Executing '/etc/ifplugd/ifplugd.action eth0 up'.
Jun 20 09:34:14 kix2 systemd[1]: Starting Hold until boot process finishes up...
Jun 20 09:34:14 kix2 systemd[1]: Starting Terminate Plymouth Boot Screen...
Jun 20 09:34:14 kix2 ntpd[564]: ntpd 4.2.6p5@1.2349-o Mon Jul 25 22:35:28 UTC 2016 (1)
Jun 20 09:34:14 kix2 ntp[513]: Starting NTP server: ntpd.
Jun 20 09:34:14 kix2 ntpd[623]: proto: precision = 1.146 usec
Jun 20 09:34:14 kix2 systemd[1]: Started LSB: Start NTP daemon.
Jun 20 09:34:14 kix2 systemd[1]: Received SIGRTMIN+21 from PID 199 (plymouthd).
Jun 20 09:34:14 kix2 systemd[1]: Started Terminate Plymouth Boot Screen.
Jun 20 09:34:15 kix2 ntpd[623]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Jun 20 09:34:15 kix2 systemd[1]: Started Hold until boot process finishes up.
Jun 20 09:34:15 kix2 ntpd[623]: Listen and drop on 1 v6wildcard :: UDP 123
Jun 20 09:34:15 kix2 ntpd[623]: Listen normally on 2 lo 127.0.0.1 UDP 123
Jun 20 09:34:15 kix2 ntpd[623]: Listen normally on 3 lo ::1 UDP 123
Jun 20 09:34:15 kix2 ntpd[623]: peers refreshed
Jun 20 09:34:15 kix2 ntpd[623]: Listening on routing socket on fd #20 for interface updates
Jun 20 09:34:15 kix2 avahi-daemon[429]: Server startup complete. Host name is kix2.local. Local service cookie is 2022448163.
Jun 20 09:34:15 kix2 systemd[1]: Starting Getty on tty1...
Jun 20 09:34:15 kix2 systemd[1]: Started Getty on tty1.
Jun 20 09:34:15 kix2 systemd[1]: Starting Login Prompts.
Jun 20 09:34:15 kix2 systemd[1]: Reached target Login Prompts.
Jun 20 09:34:15 kix2 ntpd[623]: Deferring DNS for 0.debian.pool.ntp.org 1
Jun 20 09:34:15 kix2 ntpd[623]: Deferring DNS for 1.debian.pool.ntp.org 1
Jun 20 09:34:15 kix2 ntpd[623]: Deferring DNS for 2.debian.pool.ntp.org 1
Jun 20 09:34:15 kix2 ntpd[623]: Deferring DNS for 3.debian.pool.ntp.org 1
Jun 20 09:34:15 kix2 ntpd[693]: signal_no_reset: signal 17 had flags 4000000
Jun 20 09:34:15 kix2 systemd[1]: Started OpenBSD Secure Shell server.
Jun 20 09:34:15 kix2 dhcpcd[457]: eth0: waiting for carrier
Jun 20 09:34:15 kix2 dhcpcd[457]: eth0: carrier acquired
Jun 20 09:34:15 kix2 dhcpcd[457]: unknown option: SSID
Jun 20 09:34:15 kix2 dhcpcd[457]: DUID 00:01:00:01:1d:96:d4:23:b8:27:eb:b9:65:1e
Jun 20 09:34:15 kix2 dhcpcd[457]: eth0: IAID eb:b9:65:1e
Jun 20 09:34:15 kix2 systemd[1]: Reloading OpenBSD Secure Shell server.
Jun 20 09:34:15 kix2 avahi-daemon[429]: Service "kix2" (/services/udisks.service) successfully established.
Jun 20 09:34:15 kix2 systemd[1]: Reloaded OpenBSD Secure Shell server.
Jun 20 09:34:15 kix2 dhcpcd[457]: eth0: using static address 192.168.1.170/24
Jun 20 09:34:15 kix2 avahi-daemon[429]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.170.
Jun 20 09:34:16 kix2 avahi-daemon[429]: New relevant interface eth0.IPv4 for mDNS.
Jun 20 09:34:16 kix2 avahi-daemon[429]: Registering new address record for 192.168.1.170 on eth0.IPv4.
Jun 20 09:34:16 kix2 dhcpcd[457]: eth0: adding route to 192.168.1.0/24
Jun 20 09:34:16 kix2 dhcpcd[457]: eth0: adding default route via 192.168.1.1
Jun 20 09:34:16 kix2 ifplugd(eth0)[234]: Program executed successfully.
Jun 20 09:34:16 kix2 systemd[1]: Started The PHP FastCGI Process Manager.
Jun 20 09:34:16 kix2 exim4[520]: Starting MTA: exim4.
Jun 20 09:34:16 kix2 exim4[520]: ALERT: exim paniclog /var/log/exim4/paniclog has non-zero size, mail system possibly broken
Jun 20 09:34:16 kix2 systemd[1]: Started LSB: exim Mail Transport Agent.
Jun 20 09:34:17 kix2 systemd[1]: Starting user-1000.slice.
Jun 20 09:34:17 kix2 systemd[1]: Created slice user-1000.slice.
Jun 20 09:34:17 kix2 systemd[1]: Starting User Manager for UID 1000...
Jun 20 09:34:17 kix2 systemd[1]: Starting Session c1 of user pi.
Jun 20 09:34:17 kix2 systemd[1]: Started Session c1 of user pi.
Jun 20 09:34:17 kix2 ntpd_intres[693]: DNS 0.debian.pool.ntp.org -> 194.177.210.54
Jun 20 09:34:17 kix2 ntpd_intres[693]: DNS 1.debian.pool.ntp.org -> 193.93.164.195
Jun 20 09:34:17 kix2 systemd[1049]: Starting Paths.
Jun 20 09:34:17 kix2 systemd[1049]: Reached target Paths.
Jun 20 09:34:17 kix2 systemd[1049]: Starting Timers.
Jun 20 09:34:17 kix2 systemd[1049]: Reached target Timers.
Jun 20 09:34:17 kix2 systemd[1049]: Starting Sockets.
Jun 20 09:34:17 kix2 systemd[1049]: Reached target Sockets.
Jun 20 09:34:17 kix2 systemd[1049]: Starting Basic System.
Jun 20 09:34:17 kix2 systemd[1049]: Reached target Basic System.
Jun 20 09:34:17 kix2 systemd[1049]: Starting Default.
Jun 20 09:34:17 kix2 systemd[1049]: Reached target Default.
Jun 20 09:34:17 kix2 systemd[1049]: Startup finished in 128ms.
Jun 20 09:34:17 kix2 systemd[1]: Started User Manager for UID 1000.
Jun 20 09:34:17 kix2 ntpd_intres[693]: DNS 2.debian.pool.ntp.org -> 194.177.210.54
Jun 20 09:34:17 kix2 ntpd_intres[693]: DNS 3.debian.pool.ntp.org -> 193.239.214.227
Jun 20 09:34:17 kix2 ntpd[623]: Listen normally on 4 eth0 192.168.1.170 UDP 123
Jun 20 09:34:17 kix2 ntpd[623]: Listen normally on 5 eth0 fe80::ac4f:2f4c:5dda:dd9 UDP 123
Jun 20 09:34:17 kix2 ntpd[623]: peers refreshed
Jun 20 09:34:18 kix2 apache2[511]: Starting web server: apache2.
Jun 20 09:34:18 kix2 systemd[1]: Started LSB: Apache2 web server.
Jun 20 09:34:20 kix2 systemd[1]: Starting Session c2 of user pi.
Jun 20 09:34:20 kix2 systemd[1]: Started Session c2 of user pi.
Jun 20 09:34:22 kix2 kernel: [   13.901356] ip_tables: (C) 2000-2006 Netfilter Core Team
Jun 20 09:34:22 kix2 fail2ban[506]: Starting authentication failure monitor: fail2ban.
Jun 20 09:34:22 kix2 systemd[1]: Started LSB: Start/stop fail2ban.
Jun 20 09:34:22 kix2 systemd[1]: Starting Multi-User System.
Jun 20 09:34:22 kix2 systemd[1]: Reached target Multi-User System.
Jun 20 09:34:22 kix2 systemd[1]: Starting Update UTMP about System Runlevel Changes...
Jun 20 09:34:22 kix2 systemd[1]: Started Update UTMP about System Runlevel Changes.
Jun 20 09:35:57 kix2 systemd[1049]: Time has been changed
Jun 20 09:35:57 kix2 systemd[1]: Time has been changed
Jun 20 09:36:04 kix2 kernel: [   22.736471] random: crng init done
Jun 20 09:36:04 kix2 kernel: [   22.736488] random: 7 urandom warning(s) missed due to ratelimiting
Jun 20 09:37:13 kix2 systemd[1]: Job dev-sda1.device/start timed out.
Jun 20 09:37:13 kix2 systemd[1]: Timed out waiting for device dev-sda1.device.
Jun 20 09:37:13 kix2 systemd[1]: Dependency failed for /home/disks/mydisk1.
Jun 20 09:37:13 kix2 systemd[1]: Dependency failed for File System Check on /dev/sda1.
Jun 20 09:37:13 kix2 systemd[1]: Startup finished in 1.522s (kernel) + 1min 30.859s (userspace) = 1min 32.381s.
Jun 20 09:39:01 kix2 CRON[1430]: (root) CMD (  [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean)
Paeryn
Re: kernel Oops 5
Fri Jun 21, 2019 9:36 am
Hmm, is it in /var/log/kern.log ?
filippos
Re: kernel Oops 5
Fri Jun 21, 2019 10:30 am
nope
last lines of kern.log:
filippos
Re: kernel Oops 5
Mon Jul 01, 2019 7:57 am
It's not the hardware, I've checked it with another sd card, it's not the sd card, I've copied it to another same card.
That lead us that is the software to blame
Oops: 17 now, Oops 5 before
3 minutes today 20 minutes before!
What do I check to find what the problem is?
*** on ssh:
Message from syslogd@kix2 at Jul  1 10:37:00 ...
 kernel:[  227.919930] Internal error: Oops: 17 [#1] SMP ARM
filippos
Re: kernel Oops 5
Mon Jul 01, 2019 8:38 am
Latest Screen shot :
https://paste.pics/5YFAC
filippos
Re: kernel Oops 5
Thu Jul 04, 2019 4:16 am
Hi
I'm stacked!
Please help
I've only found a similar error here: https://pastebin.com/tuTAB1Ra but not any explanation or how to fix/debug, but it has a kernel error code.
My Rpi problem is an interrupt
hardware name: BCM2835
exception error cpu3 stopping swaper/3 tainted d   4.14.94 -v7+ #1193
filippos
Re: kernel Oops 5
Wed Jul 17, 2019 9:43 am
At last, after a month, I managed to install new updates and new rpi-update and the system is back again.
RaTTuS
Re: kernel Oops 5
Wed Jul 17, 2019 9:58 am
rpi-update will kill your machine is used unless oyu know what your doing
Covfefe
pfletch101
Re: kernel Oops 5
Wed Jul 17, 2019 4:09 pm
...and sometimes even if you do know what you are doing! :)
