Rupiert
Wrong Image Color
Thu Jun 20, 2019 5:07 am
Hey there!
I have some Rpi's with this cam: https://www.amazon.de/Electreeks-Raspbe ... r=8-5&th=1
They all make wrong color on pictures like that:
my raspistill cmd look like this:
raspistill -o $FILENAME -q 10 -a 12 -a 1024 -a "Zeropi#1 %Y-%m-%d %X" -awb auto
What is wrong and how can i fix it.
[Mod: edited out bad language. Don't do it again]
Re: Wrong Image Color
Thu Jun 20, 2019 7:08 am
That doesn't look like an official Raspberry Pi camera module, it is possibly one of the clones of the original version. As it has the dodgy big IR LEDS on either side, it is probably a NoIR or night vision version with no infrared filter over the lens. That can make colours distorted in natural light.
Also, please watch your language. This is a family friendly forum and that sort of language is not acceptable here.
Thu Jun 20, 2019 8:48 am
Indeed, looks like a NOIR camera, which will give strange colour effects in daylight conditions.
gordon77
Thu Jun 20, 2019 9:09 am
In English it says... NIGHT VISION - High performance infrared LEDs guarantee optimal night vision. Since the Raspi NOIR camera module does not have an IR filter, the infrared radiation that is invisible to the human eye can be recorded.
So it certainly looks like a noir camera.
Rupiert
Thu Jun 20, 2019 11:43 am
One of my Rpi's make right pictures. So i do not understand what is the difference. The only one capture green like in a real picture, the other's don't!
gordon77
Thu Jun 20, 2019 11:47 am
Earlier you said
"They all make wrong color on pictures like that" , so what changed?
Rupiert
Thu Jun 20, 2019 12:29 pm
I bought the one, one month bevor.
gordon77
Thu Jun 20, 2019 12:37 pm
If you mean the camera could it be a normal one, not noir?
Rupiert
Fri Jun 21, 2019 6:31 am
So: I have 6 Rpi's (half zero pi's) there all have the same cam. One Rpi makes normal pictures. I bought the cam 1-month bevor for testing. I don't know why.
gordon77
Fri Jun 21, 2019 6:44 am
If you swap the 'normal' camera with a 'bad' one does the problem move?
I suggest one camera is a normal one or noir
RaTTuS
Fri Jun 21, 2019 7:56 am
"NIGHT VISION - High performance infrared LEDs guarantee optimal night vision. Since the Raspi NOIR "...
or
"NIGHT-VISION - Hochleistungs-Infrarot-LED's garantieren optimale Nachtsicht-Aufnahmen. Da das Raspi NOIR Kamera-Modul keinen IR-Filter besitzt, kann die für das menschliche Auge nicht sichbare Infrarotstrahlung aufgenommen werden."
this is a NOIR camera
it has no IR filter so daylight colours are washed out .... though it's better with IR illumination for night viewing - those modules do not provide much in the way of illumination - OK for close up stuff
if you want good night illumination then I suggest getting a couple of https://www.aliexpress.com/item/32296264695.html or similar [not saying these are any good]
Covfefe
Burngate
Fri Jun 21, 2019 9:43 am
Do you mean you have only one camera that you swap between the six Pis, or do you have six supposedly identical cameras, one for each Pi?
gordon77
Fri Jun 21, 2019 12:57 pm
I admit l am a bit confused whether 1 or 6 cameras, and don't know how the output can vary between Pi's with the same camera if running the same code.
Rupiert
Sat Jun 22, 2019 4:41 am
6 camera (no matter by hardware)
6 rpm (3 rpm, 3 rpm zero)
I thought so well that it comes from noir. But it was confusing because you also take normal pictures.
