XMCK
raspbian.raspberrypi.org down?
Thu Jun 13, 2019 2:54 pm
I am trying to install a package via apt but seems that the repo is down. Is this correct? Or should i look for my network settings?
ShiftPlusOne
Re: raspbian.raspberrypi.org down?
Thu Jun 13, 2019 2:58 pm
jahboater
Thu Jun 13, 2019 3:00 pm
Just an "apt update" and its fine.
Thu Jun 13, 2019 3:34 pm
If you are still getting errors can you post the full messages you are experiencing. It may be a single mirror that is offline or not synchronised with the others that is causing the problem.
hippy
Thu Jun 13, 2019 3:36 pm
My ISP was screwing up earlier today causing all sorts of random errors from bad gateways to site timeouts, some sites accessible, some not. As always, check multiple sites and if problems are seen elsewhere, leave it all alone, try again later.
XMCK
Thu Jun 13, 2019 3:57 pm
the problem was actually my network configuration. I had a problem resolving the correct dns.. Strange to me.. But now it works. Thanks for all the replies
