marius_bogdan96
No access to dev/mem
Wed May 29, 2019 12:09 pm
Hello!
I am trying to make an automatic license plate recognition parking system with a camera andna servo. I am havingbsome troubles right at the begging with access to dev/mem. I have tried everything from old posts but nothing seems to work.
The error is for:
GPIO. setup(17, GPIO. IN, pull_up_down=GPIO. PUD_UP)
RuntimeError: No access to /dev/mem. Try running as root.
My user has acces to GPIO, i have checked.
dl324
Re: No access to dev/mem
Wed May 29, 2019 3:00 pm
As the error message indicates, root privileges are required to access /dev/mem.
croston
Wed May 29, 2019 3:02 pm
* What OS / Distro are you using?
* What username is your Python program running under?
* What version of RPi.GPIO are you using?
hippy
Wed May 29, 2019 4:11 pm
Your user may have access to GPIO via /dev/gpiomem, but will need root privileges to access /dev/mem,
marius_bogdan96
Thu May 30, 2019 6:03 am
The user is Pi. I have tried to give root access to the user byt it says it already has.
The program runed, it used to have other erros but in the process of solving them, when I finally succeded to process the image and get de number plate of the picture, it gave this error.
marius_bogdan96
Thu May 30, 2019 6:04 am
How do I give root privileges?
croston
Thu May 30, 2019 9:18 am
You shouldn't need root privileges with an up to date version of Raspbian and RPi.GPIO. You have still not answered my questions about the versions of things a few posts earlier. Without this information, we can only guess as to what is going wrong and what the solution is.
dl324
Thu May 30, 2019 3:19 pm
Run the script using sudo.
hippy
Thu May 30, 2019 5:29 pm
My guess would be it's either an ancient version of RPi.GPIO - if that is what is being used - because RPI.GPIO should be using /dev/gpiomem rather than /dev/mem to do its thing.
But RPi.GPIO falls back to using /dev/mem when it cannot gain access to /dev/gpiomem, so it could be 'lack of /dev/gpiomem' or something related which is causing the issue.
Still, running with "sudo" should allow the fall-back to using /dev/mem to work.
marius_bogdan96
Thu May 30, 2019 9:15 pm
Thank you all. I have runed the program through MU and it works just fine, even if it still gives the gpio error in spyder 3 and geany.
