OK so I plugged in the PiFiDAC back and below are the "stats"
Kernel version
~ $ uname -a
Linux Raspi3BP1 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l GNU/Linux
below is the audio section of the config.txt file
The Pimoroni pHAT DAC was added yesterday during the test.
prior to the upgrade, both the RPi on-board audio and DAC were active and functional
dtparam=audio=on
disable_audio_dither=on
# iQAudio DAC+ Settings:
#dtoverlay=iqaudio-dacplus
#HifiBerry DAC Settings: (for SainSmartDAC):
dtoverlay=hifiberry-dacplus
#Pimoroni pHAT DAC Settings:
#dtoverlay=hifiberry-dac
Kodi full log (started Kodi, then closed it)
we all know that Kodi makes 2 sounds when it starts. Mine doesn't.
I also noticed in the logs that the DAC is not listed.
2019-04-17 20:37:09.419 T:1899969808 NOTICE: -----------------------------------------------------------------------
2019-04-17 20:37:09.419 T:1899969808 NOTICE: Starting Kodi (18.1 Git:20190220-5494e5ffac). Platform: Linux ARM 32-bit
2019-04-17 20:37:09.419 T:1899969808 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
2019-04-17 20:37:09.419 T:1899969808 NOTICE: Kodi compiled 2019-02-22 by GCC 6.3.0 for Linux ARM 32-bit version 4.9.82 (264530)
2019-04-17 20:37:09.419 T:1899969808 NOTICE: Running on Raspbian GNU/Linux 9 (stretch), kernel: Linux ARM 32-bit version 4.14.98-v7+
2019-04-17 20:37:09.428 T:1899969808 NOTICE: FFmpeg version/source: 4.0.3-Kodi
2019-04-17 20:37:09.428 T:1899969808 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
2019-04-17 20:37:09.428 T:1899969808 NOTICE: ARM Features: Neon enabled
2019-04-17 20:37:09.428 T:1899969808 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
2019-04-17 20:37:09.428 T:1899969808 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
2019-04-17 20:37:09.428 T:1899969808 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
2019-04-17 20:37:09.428 T:1899969808 NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
2019-04-17 20:37:09.428 T:1899969808 NOTICE: special://envhome/ is mapped to: /home/pi
2019-04-17 20:37:09.428 T:1899969808 NOTICE: special://home/ is mapped to: /home/pi/.kodi
2019-04-17 20:37:09.428 T:1899969808 NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
2019-04-17 20:37:09.428 T:1899969808 NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
2019-04-17 20:37:09.428 T:1899969808 NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi-rbpi_v7
2019-04-17 20:37:09.428 T:1899969808 NOTICE: Local hostname: Raspi3BP1
2019-04-17 20:37:09.428 T:1899969808 NOTICE: Log File is located: /home/pi/.kodi/temp/kodi.log
2019-04-17 20:37:09.428 T:1899969808 NOTICE: -----------------------------------------------------------------------
2019-04-17 20:37:09.439 T:1899969808 INFO: loading settings
2019-04-17 20:37:09.440 T:1899969808 NOTICE: special://profile/ is mapped to: special://masterprofile/
2019-04-17 20:37:09.470 T:1899969808 DEBUG: CSkinSettings: no <skinsettings> tag found
2019-04-17 20:37:09.470 T:1899969808 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
2019-04-17 20:37:09.474 T:1899969808 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2019-04-17 20:37:09.475 T:1899969808 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<fanartres>720</fanartres>
<imageres>540</imageres>
<video>
<busydialogdelayms>750</busydialogdelayms>
</video>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<cache>
<memorysize>31457280</memorysize>
</cache>
</advancedsettings>
2019-04-17 20:37:09.475 T:1899969808 WARNING: CSettingsManager: missing version attribute
2019-04-17 20:37:09.476 T:1899969808 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2019-04-17 20:37:09.476 T:1899969808 NOTICE: Default Video Player: VideoPlayer
2019-04-17 20:37:09.476 T:1899969808 NOTICE: Default Audio Player: paplayer
2019-04-17 20:37:09.477 T:1899969808 NOTICE: Disabled debug logging due to GUI setting. Level 0.
2019-04-17 20:37:09.477 T:1899969808 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
2019-04-17 20:37:09.589 T:1899969808 NOTICE: Running database version Addons27
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: game.controller.default v1.0.8 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: game.controller.snes v1.0.8 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: kodi.resource v1.0.0 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: metadata.album.universal v3.1.1 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: metadata.artists.universal v4.3.0 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: metadata.common.allmusic.com v3.2.0 installed
2019-04-17 20:37:09.680 T:1899969808 NOTICE: ADDON: metadata.common.fanart.tv v3.6.1 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: metadata.common.imdb.com v3.1.4 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.1 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.2 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: metadata.common.themoviedb.org v3.1.9 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: metadata.local v1.0.0 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: metadata.themoviedb.org v5.1.7 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.1.0 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: repository.xbmc.org v3.1.5 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.32 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.53 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: script.module.pil v1.1.7 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: service.xbmc.versioncheck v0.4.6 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: skin.estouchy v2.0.22 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: skin.estuary v2.0.21 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: xbmc.addon v18.1.0 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: xbmc.core v0.1.0 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: xbmc.gui v5.14.0 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: xbmc.json v10.1.2 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: xbmc.python v2.26.0 installed
2019-04-17 20:37:09.681 T:1899969808 NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2019-04-17 20:37:09.721 T:1899969808 ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2019-04-17 20:37:09.943 T:1868559072 NOTICE: Found 2 Lists of Devices
2019-04-17 20:37:09.943 T:1868559072 NOTICE: Enumerated ALSA devices:
2019-04-17 20:37:09.943 T:1868559072 NOTICE: Device 1
2019-04-17 20:37:09.944 T:1868559072 NOTICE: m_deviceName : @
2019-04-17 20:37:09.944 T:1868559072 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
2019-04-17 20:37:09.944 T:1868559072 NOTICE: m_displayNameExtra:
2019-04-17 20:37:09.944 T:1868559072 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2019-04-17 20:37:09.944 T:1868559072 NOTICE: m_channels : FL, FR
2019-04-17 20:37:09.944 T:1868559072 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000
2019-04-17 20:37:09.944 T:1868559072 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
2019-04-17 20:37:09.944 T:1868559072 NOTICE: m_streamTypes : No passthrough capabilities
2019-04-17 20:37:09.944 T:1868559072 NOTICE: Enumerated PI devices:
2019-04-17 20:37:09.944 T:1868559072 NOTICE: Device 1
2019-04-17 20:37:09.945 T:1868559072 NOTICE: m_deviceName : HDMI
2019-04-17 20:37:09.945 T:1868559072 NOTICE: m_displayName : HDMI
2019-04-17 20:37:09.945 T:1868559072 NOTICE: m_displayNameExtra:
2019-04-17 20:37:09.945 T:1868559072 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
2019-04-17 20:37:09.945 T:1868559072 NOTICE: m_channels : FL, FR
2019-04-17 20:37:09.945 T:1868559072 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
2019-04-17 20:37:09.945 T:1868559072 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
2019-04-17 20:37:09.945 T:1868559072 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
2019-04-17 20:37:09.945 T:1868559072 NOTICE: Device 2
2019-04-17 20:37:09.946 T:1868559072 NOTICE: m_deviceName : Analogue
2019-04-17 20:37:09.946 T:1868559072 NOTICE: m_displayName : Analogue
2019-04-17 20:37:09.946 T:1868559072 NOTICE: m_displayNameExtra:
2019-04-17 20:37:09.946 T:1868559072 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2019-04-17 20:37:09.946 T:1868559072 NOTICE: m_channels : FL, FR
2019-04-17 20:37:09.946 T:1868559072 NOTICE: m_sampleRates : 48000
2019-04-17 20:37:09.946 T:1868559072 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2019-04-17 20:37:09.946 T:1868559072 NOTICE: m_streamTypes : No passthrough capabilities
2019-04-17 20:37:09.946 T:1868559072 NOTICE: Device 3
2019-04-17 20:37:09.946 T:1868559072 NOTICE: m_deviceName : Both
2019-04-17 20:37:09.946 T:1868559072 NOTICE: m_displayName : HDMI and Analogue
2019-04-17 20:37:09.947 T:1868559072 NOTICE: m_displayNameExtra:
2019-04-17 20:37:09.947 T:1868559072 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2019-04-17 20:37:09.947 T:1868559072 NOTICE: m_channels : FL, FR
2019-04-17 20:37:09.947 T:1868559072 NOTICE: m_sampleRates : 48000
2019-04-17 20:37:09.947 T:1868559072 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2019-04-17 20:37:09.947 T:1868559072 NOTICE: m_streamTypes : No passthrough capabilities
2019-04-17 20:37:10.114 T:1899969808 NOTICE: Raspberry PI firmware version: Mar 27 2019 15:45:53
Copyright (c) 2012 Broadcom
version 2e98b31d18547962e564bdf88e57b3df7085c29b (clean) (release) (start)
2019-04-17 20:37:10.114 T:1899969808 NOTICE: ARM mem: 832MB GPU mem: 192MB MPG2:0 WVC1:0
2019-04-17 20:37:10.114 T:1899969808 NOTICE: cache.memorysize: 30MB libass.cache: 21MB
2019-04-17 20:37:10.114 T:1899969808 NOTICE: Config:
aphy_params_current=819
arm_freq=1400
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x331df0
desired_osc_freq_boost=0x3c45b0
disable_commandline_tags=2
disable_l2cache=1
display_hdmi_rotate=-1
display_lcd_rotate=-1
dphy_params_current=547
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_drive=2
hdmi_force_cec_address=65535
hdmi_force_hotplug=1
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=62500
over_voltage_avs_boost=0x27ac4
pause_burst_frames=1
program_serial_random=1
sdram_freq=450
device_tree=-
2019-04-17 20:37:10.116 T:1899969808 NOTICE: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2019-04-17 20:37:10.116 T:1899969808 NOTICE: Found resolution 640 x 480 with 640 x 480 @ 59.940063 Hz
2019-04-17 20:37:10.116 T:1899969808 NOTICE: Found resolution 640 x 480 with 640 x 480 @ 75.000000 Hz
2019-04-17 20:37:10.116 T:1899969808 NOTICE: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2019-04-17 20:37:10.116 T:1899969808 NOTICE: Found resolution 800 x 600 with 800 x 600 @ 59.940063 Hz
2019-04-17 20:37:10.116 T:1899969808 NOTICE: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2019-04-17 20:37:10.116 T:1899969808 NOTICE: Found resolution 1024 x 768 with 1024 x 768 @ 59.940063 Hz
2019-04-17 20:37:10.116 T:1899969808 NOTICE: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2019-04-17 20:37:10.116 T:1899969808 NOTICE: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940063 Hz
2019-04-17 20:37:10.116 T:1899969808 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2019-04-17 20:37:10.116 T:1899969808 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 59.940063 Hz
2019-04-17 20:37:10.116 T:1899969808 NOTICE: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2019-04-17 20:37:10.117 T:1899969808 NOTICE: Found resolution 720 x 480 with 720 x 480 @ 59.940063 Hz
2019-04-17 20:37:10.117 T:1899969808 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2019-04-17 20:37:10.117 T:1899969808 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940063 Hz
2019-04-17 20:37:10.117 T:1899969808 NOTICE: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2019-04-17 20:37:10.117 T:1899969808 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2019-04-17 20:37:10.117 T:1899969808 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2019-04-17 20:37:10.117 T:1899969808 NOTICE: Found (1920x1080@60.000000) at 29, setting to RES_DESKTOP at 16
2019-04-17 20:37:10.117 T:1899969808 NOTICE: EGL_VERSION = 1.4
2019-04-17 20:37:10.117 T:1899969808 NOTICE: EGL_VENDOR = Broadcom
2019-04-17 20:37:10.118 T:1899969808 NOTICE: EGL_EXTENSIONS = EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_vg_parent_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_lock_surface
2019-04-17 20:37:10.118 T:1899969808 NOTICE: EGL_CLIENT_EXTENSIONS = NULL
2019-04-17 20:37:10.120 T:1899969808 NOTICE: Checking resolution 16
2019-04-17 20:37:10.308 T:1899969808 NOTICE: GL_VENDOR = Broadcom
2019-04-17 20:37:10.308 T:1899969808 NOTICE: GL_RENDERER = VideoCore IV HW
2019-04-17 20:37:10.308 T:1899969808 NOTICE: GL_VERSION = OpenGL ES 2.0
2019-04-17 20:37:10.308 T:1899969808 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
2019-04-17 20:37:10.308 T:1899969808 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
2019-04-17 20:37:11.507 T:1774600928 NOTICE: Running database version Addons27
2019-04-17 20:37:11.510 T:1774600928 NOTICE: Running database version ViewModes6
2019-04-17 20:37:11.513 T:1774600928 NOTICE: Running database version Textures13
2019-04-17 20:37:11.522 T:1774600928 NOTICE: Running database version MyMusic72
2019-04-17 20:37:11.536 T:1774600928 NOTICE: Running database version MyVideos116
2019-04-17 20:37:11.540 T:1774600928 NOTICE: Running database version TV32
2019-04-17 20:37:11.543 T:1774600928 NOTICE: Running database version Epg12
2019-04-17 20:37:11.545 T:1899969808 NOTICE: start dvd mediatype detection
2019-04-17 20:37:11.623 T:1899969808 NOTICE: load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.21)
2019-04-17 20:37:12.281 T:1899969808 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
2019-04-17 20:37:12.368 T:1899969808 NOTICE: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2019-04-17 20:37:12.369 T:1899969808 NOTICE: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2019-04-17 20:37:12.373 T:1899969808 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2019-04-17 20:37:12.375 T:1899969808 NOTICE: Loaded playercorefactory configuration
2019-04-17 20:37:12.377 T:1899969808 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2019-04-17 20:37:12.378 T:1899969808 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2019-04-17 20:37:12.414 T:1899969808 NOTICE: initialize done
2019-04-17 20:37:12.415 T:1899969808 NOTICE: Running the application...
2019-04-17 20:37:12.426 T:1899969808 NOTICE: starting zeroconf publishing
2019-04-17 20:37:12.427 T:1899969808 NOTICE: CWebServer[8080]: Started
2019-04-17 20:37:12.430 T:1657778912 NOTICE: ES: Starting UDP Event server on port 9777
2019-04-17 20:37:12.431 T:1657778912 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
2019-04-17 20:37:12.439 T:1899969808 NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to audio sink
2019-04-17 20:37:12.447 T:1899969808 NOTICE: VideoPlayer::OpenFile: /var/run/lirc/lircd
2019-04-17 20:37:12.471 T:1622708960 NOTICE: Creating InputStream
2019-04-17 20:37:12.477 T:1622708960 ERROR: CVideoPlayer::OpenInputStream - error opening [/var/run/lirc/lircd]
2019-04-17 20:37:12.477 T:1622708960 NOTICE: CVideoPlayer::OnExit()
2019-04-17 20:37:12.614 T:1726505696 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
2019-04-17 20:37:13.085 T:1899969808 NOTICE: CVideoPlayer::CloseFile()
2019-04-17 20:37:13.086 T:1899969808 NOTICE: VideoPlayer: waiting for threads to exit
2019-04-17 20:37:13.086 T:1899969808 NOTICE: VideoPlayer: finished waiting
2019-04-17 20:37:13.138 T:1899969808 WARNING: OnMessage: Suspiciously long time to handle GUI_MSG_PLAYBACK_STARTED (0.25s)
2019-04-17 20:37:22.044 T:1899969808 WARNING: CGUIWindowManager - HandleAction - ignoring action 92, because topmost modal dialog closing animation is running
2019-04-17 20:37:31.901 T:1899969808 NOTICE: stop player
2019-04-17 20:37:31.901 T:1899969808 NOTICE: Storing total System Uptime
2019-04-17 20:37:31.902 T:1899969808 NOTICE: Saving settings
2019-04-17 20:37:31.918 T:1899969808 NOTICE: Saving skin settings
2019-04-17 20:37:31.922 T:1899969808 NOTICE: stop all
2019-04-17 20:37:31.923 T:1899969808 NOTICE: ES: Stopping event server
2019-04-17 20:37:31.923 T:1899969808 NOTICE: stopping zeroconf publishing
2019-04-17 20:37:31.933 T:1899969808 NOTICE: CWebServer[8080]: Stopped
2019-04-17 20:37:32.451 T:1657778912 NOTICE: ES: UDP Event server stopped
2019-04-17 20:37:32.455 T:1899969808 NOTICE: stop dvd detect media
2019-04-17 20:37:32.696 T:1899969808 NOTICE: stopped
2019-04-17 20:37:32.897 T:1899969808 NOTICE: destroy
2019-04-17 20:37:34.364 T:1899969808 NOTICE: unload skin
2019-04-17 20:37:34.438 T:1899969808 NOTICE: unload sections
2019-04-17 20:37:35.017 T:1899969808 NOTICE: application stopped...
Again there is audio from DAC if I watch YouTube videos
but no DAC audio from Kodi
Note: its the same RPi3B+ that has its Kodi logs in the Kodi forum (Re: Delay in returning to menu after watching video)
below is the snippet from that Kodi log
2019-03-02 17:38:59.163 T:1899277584 ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2019-03-02 17:38:59.429 T:1868559088 NOTICE: Found 2 Lists of Devices
2019-03-02 17:38:59.430 T:1868559088 NOTICE: Enumerated ALSA devices:
2019-03-02 17:38:59.430 T:1868559088 NOTICE: Device 1
2019-03-02 17:38:59.430 T:1868559088 NOTICE: m_deviceName : @
2019-03-02 17:38:59.430 T:1868559088 NOTICE: m_displayName : Default (snd_rpi_hifiberry_dacplus Analog)
2019-03-02 17:38:59.430 T:1868559088 NOTICE: m_displayNameExtra:
2019-03-02 17:38:59.430 T:1868559088 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2019-03-02 17:38:59.431 T:1868559088 NOTICE: m_channels : FL, FR
2019-03-02 17:38:59.431 T:1868559088 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
2019-03-02 17:38:59.431 T:1868559088 NOTICE: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2019-03-02 17:38:59.431 T:1868559088 NOTICE: m_streamTypes : No passthrough capabilities
2019-03-02 17:38:59.431 T:1868559088 NOTICE: Enumerated PI devices:
2019-03-02 17:38:59.431 T:1868559088 NOTICE: Device 1
2019-03-02 17:38:59.431 T:1868559088 NOTICE: m_deviceName : HDMI
2019-03-02 17:38:59.431 T:1868559088 NOTICE: m_displayName : HDMI
2019-03-02 17:38:59.431 T:1868559088 NOTICE: m_displayNameExtra:
2019-03-02 17:38:59.431 T:1868559088 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
2019-03-02 17:38:59.432 T:1868559088 NOTICE: m_channels : FL, FR
2019-03-02 17:38:59.432 T:1868559088 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
2019-03-02 17:38:59.432 T:1868559088 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
2019-03-02 17:38:59.432 T:1868559088 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
2019-03-02 17:38:59.432 T:1868559088 NOTICE: Device 2
2019-03-02 17:38:59.432 T:1868559088 NOTICE: m_deviceName : Analogue
2019-03-02 17:38:59.433 T:1868559088 NOTICE: m_displayName : Analogue
2019-03-02 17:38:59.433 T:1868559088 NOTICE: m_displayNameExtra:
2019-03-02 17:38:59.433 T:1868559088 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2019-03-02 17:38:59.433 T:1868559088 NOTICE: m_channels : FL, FR
2019-03-02 17:38:59.433 T:1868559088 NOTICE: m_sampleRates : 48000
2019-03-02 17:38:59.433 T:1868559088 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2019-03-02 17:38:59.433 T:1868559088 NOTICE: m_streamTypes : No passthrough capabilities
2019-03-02 17:38:59.433 T:1868559088 NOTICE: Device 3
2019-03-02 17:38:59.433 T:1868559088 NOTICE: m_deviceName : Both
2019-03-02 17:38:59.433 T:1868559088 NOTICE: m_displayName : HDMI and Analogue
2019-03-02 17:38:59.434 T:1868559088 NOTICE: m_channels : FL, FR
2019-03-02 17:38:59.434 T:1868559088 NOTICE: m_sampleRates : 48000
2019-03-02 17:38:59.434 T:1868559088 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2019-03-02 17:38:59.434 T:1868559088 NOTICE: m_streamTypes : No passthrough capabilities
2019-03-02 17:38:59.646 T:1899277584 NOTICE: Raspberry PI firmware version: Feb 12 2019 19:42:42
version 8eff5e4023657a8b3b59e1f90dc966f62d74908c (clean) (release) (start)
2019-03-02 17:38:59.646 T:1899277584 NOTICE: ARM mem: 832MB GPU mem: 192MB MPG2:0 WVC1:0
2019-03-02 17:38:59.646 T:1899277584 NOTICE: cache.memorysize: 30MB libass.cache: 21MB
2019-03-02 17:38:59.646 T:1899277584 NOTICE: Config:
arm_freq=1400
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=400
disable_l2cache=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_swap=1
gpu_freq=300
hdmi_drive=2
lcd_framerate=60
over_voltage_avs=0x19f0a
over_voltage_avs_boost=0x325aa
sdram_freq=450
device_tree=-
