fuzzyonion
Fresh Install: Cannot set Wifi Country
Sat Apr 06, 2019 6:07 pm
I've installed a fresh Raspbian OS from NOOBS over Wifi. Now when I booted up the OS it says that the Wifi country is not set. It seems no matter what I do I cannot set the country. No error message. Just doesn't seem to save the country. After what seemed to be a smooth installation process I've hit a wall with no feedback.
After much frustration I found this article from a year ago: https://miapple.me/fix-raspberry-pi-wif ... y-not-set/
Is this the recommended fix? Why does this issue persist after a year? NOOBS had no trouble installing an OS over Wifi but Raspbian fails at such a basic task and seems to communicate nothing about the problem. I apologize if my frustration shows, I'm very much confused by this experience.
JonnyQuest
Re: Fresh Install: Cannot set Wifi Country
Sun Apr 07, 2019 11:27 pm
Have you set the country through raspi-config? If not, run the following code:
sudo raspi-config
Option 2 is the network option
N2 configures Country and Wi-Fi settings
fuzzyonion
Wed Apr 10, 2019 9:13 pm
Thanks for the reply. I'll give that a try.
