arcanon
Re: USB redux
Fri Dec 07, 2012 7:56 pm
Just posting an interesting observation. I finally got HD web streaming to work from a USB camera. The trick was that the software had to be able to capture data fast enough. If I set it to 5fps, it does not work, but at 15 and up all is good. This seems to be inline from the previous error data "the host controller could not retrieve data from system memory fast enough".
Link to the other thread where I link to which software this worked with:
http://www.raspberrypi.org/phpBB3/viewt ... 04#p229204
piotr-e
Re: USB redux
Tue Dec 11, 2012 9:44 am
piotr-e wrote:
gsh wrote: The only reason problems will go away for Model A would be because you plugged in a USB1.1 device (i.e. a single keyboard or mouse) as soon as you plug in a hub any split transaction problems will re-occur)
Gordon
When I use only one device (easycap) and SSH through RJ-45 and I also have a problem with USB. In my opinion split transaction isn't reason in this case. For easycap(STK1160 driver from github) USB works too slow. Maybe it is second reason of USB problem. Tomorrow I compile newest linux kernel from github, I run easycap and I put full report here.
@gsh sorry for late answer. I had some problems with kernel compilation. So, I made tests for 700MHz and for turbo mode(1GHz).
I use only one usb dvice(only easycap) and I use vncserver.
-First for 700MHz.
dmesg after system starts:
root@raspberrypi:/home/pi# dmesg
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.2.27+ (root@pi-VirtualBox) (gcc version 4.7.2 (Ubuntu/Linaro 4.7.2-1ubuntu1) ) #1 PREEMPT Mon Dec 10 17:41:31 CET 2012
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine: BCM2708
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] On node 0 totalpages: 49152
[    0.000000] free_area_init_node: node 0, pgdat c04fb778, node_mem_map c05a2000
[    0.000000]   Normal zone: 384 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 48768 pages, LIFO batch:15
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 48768
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x4 bcm2708.serial=0xea3a3961 smsc95xx.macaddr=B8:27:EB:3A:39:61 sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0xc000000 vc_mem.mem_size=0x10000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 192MB = 192MB total
[    0.000000] Memory: 189056k/189056k available, 7552k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xcc800000 - 0xe8000000   ( 440 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xcc000000   ( 192 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc04af978   (4767 kB)
[    0.000000]       .init : 0xc04b0000 - 0xc04cf64c   ( 126 kB)
[    0.000000]       .data : 0xc04d0000 - 0xc04fbe00   ( 176 kB)
[    0.000000]        .bss : 0xc04fbe24 - 0xc05a1068   ( 661 kB)
[    0.000000] NR_IRQS:330
[    0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[    0.000000] timer_set_mode: unhandled mode:1
[    0.000000] timer_set_mode: unhandled mode:3
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.000930] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060153] pid_max: default: 32768 minimum: 301
[    0.060636] Mount-cache hash table entries: 512
[    0.061137] Initializing cgroup subsys cpuacct
[    0.061231] Initializing cgroup subsys devices
[    0.061268] Initializing cgroup subsys freezer
[    0.061299] Initializing cgroup subsys blkio
[    0.061442] CPU: Testing write buffer coherency: ok
[    0.061794] hw perfevents: enabled with v6 PMU driver, 3 counters available
[    0.063022] devtmpfs: initialized
[    0.073383] NET: Registered protocol family 16
[    0.074081] bcm2708.uart_clock = 0
[    0.075747] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.075806] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.075844] mailbox: Broadcom VideoCore Mailbox driver
[    0.075951] bcm2708_vcio: mailbox at f200b880
[    0.076059] bcm_power: Broadcom power driver
[    0.076098] bcm_power_open() -> 0
[    0.076124] bcm_power_request(0, 8)
[    0.576803] bcm_mailbox_read -> 00000080, 0
[    0.576842] bcm_power_request -> 0
[    0.576867] Serial: AMBA PL011 UART driver
[    0.577024] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[    0.882631] console [ttyAMA0] enabled
[    0.907578] bio: create slab <bio-0> at 0
[    0.912800] SCSI subsystem initialized
[    0.916792] usbcore: registered new interface driver usbfs
[    0.922423] usbcore: registered new interface driver hub
[    0.928070] usbcore: registered new device driver usb
[    0.934033] Switching to clocksource stc
[    0.938383] FS-Cache: Loaded
[    0.941579] CacheFiles: Loaded
[    0.957762] NET: Registered protocol family 2
[    0.962668] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.970762] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.978281] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.984931] TCP: Hash tables configured (established 8192 bind 8192)
[    0.991338] TCP reno registered
[    0.994507] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.000419] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.007212] NET: Registered protocol family 1
[    1.012400] RPC: Registered named UNIX socket transport module.
[    1.018531] RPC: Registered udp transport module.
[    1.023255] RPC: Registered tcp transport module.
[    1.027970] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.034749] bcm2708_dma: DMA manager at cc808000
[    1.039546] bcm2708_gpio: bcm2708_gpio_probe c04d7a38
[    1.045011] vc-mem: phys_addr:0x00000000 mem_base=0x0c000000 mem_size:0x10000000(256 MiB)
[    1.054301] audit: initializing netlink socket (disabled)
[    1.059854] type=2000 audit(0.750:1): initialized
[    1.177426] VFS: Disk quotas dquot_6.5.2
[    1.181673] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.189219] FS-Cache: Netfs 'nfs' registered for caching
[    1.195492] msgmni has been set to 369
[    1.201361] io scheduler noop registered
[    1.205330] io scheduler deadline registered (default)
[    1.210771] io scheduler cfq registered
[    1.215077] kgdb: Registered I/O driver kgdboc.
[    1.229002] brd: module loaded
[    1.236886] loop: module loaded
[    1.240909] vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
[    1.248429] vcos: [1]: vchiq_init_state: called
[    1.253579] vcos: [1]: vchiq: initialised - version 2 (min 2), device 252.0
[    1.261256] usbcore: registered new interface driver smsc95xx
[    1.267087] cdc_ncm: 04-Aug-2011
[    1.270525] usbcore: registered new interface driver cdc_ncm
[    1.276208] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.487127] Core Release: 2.80a
[    1.490373] Setting default values for core params
[    1.495215] Finished setting default values for core params
[    1.705921] Using Buffer DMA mode
[    1.709288] Periodic Transfer Interrupt Enhancement - disabled
[    1.715139] Multiprocessor Interrupt Enhancement - disabled
[    1.720750] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.725124] Dedicated Tx FIFOs mode
[    1.728800] dwc_otg: Microframe scheduler enabled
[    1.728841] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.733778] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.741126] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    1.746688] Init: Port Power? op_state=1
[    1.750654] Init: Power Port (0)
[    1.753999] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.760849] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.768123] usb usb1: Product: DWC OTG Controller
[    1.772844] usb usb1: Manufacturer: Linux 3.2.27+ dwc_otg_hcd
[    1.778630] usb usb1: SerialNumber: bcm2708_usb
[    1.783941] hub 1-0:1.0: USB hub found
[    1.787742] hub 1-0:1.0: 1 port detected
[    1.792315] dwc_otg: FIQ enabled
[    1.792331] dwc_otg: NAK holdoff enabled
[    1.792352] Module dwc_common_port init
[    1.792680] usbcore: registered new interface driver uas
[    1.798027] Initializing USB Mass Storage driver...
[    1.803181] usbcore: registered new interface driver usb-storage
[    1.809250] USB Mass Storage support registered.
[    1.814033] usbcore: registered new interface driver libusual
[    1.820141] mousedev: PS/2 mouse device common for all mice
[    1.826438] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[    1.832180] bcm2835-cpufreq: switching to governor powersave
[    1.837868] bcm2835-cpufreq: switching to governor powersave
[    1.843622] cpuidle: using governor ladder
[    1.847917] cpuidle: using governor menu
[    1.851955] sdhci: Secure Digital Host Controller Interface driver
[    1.858203] sdhci: Copyright(c) Pierre Ossman
[    1.862658] sdhci: Enable low-latency mode
[    1.866805] bcm_power_open() -> 1
[    1.870395] Registered led device: mmc0::
[    1.871814] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    1.879803] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    1.885740] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.891749] Registered led device: led0
[    1.892116] usbcore: registered new interface driver usbhid
[    1.897714] usbhid: USB HID core driver
[    1.903905] TCP cubic registered
[    1.907161] Initializing XFRM netlink socket
[    1.911524] NET: Registered protocol family 17
[    1.916058] Registering the dns_resolver key type
[    1.920963] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    1.939165] registered taskstats version 1
[    1.945528] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    1.956491] Waiting for root device /dev/mmcblk0p2...
[    1.988238] Indeed it is in host mode hprt0 = 00021501
[    1.993618] mmc0: new high speed SDHC card at address 1234
[    2.008716] mmcblk0: mmc0:1234 SA04G 3.68 GiB
[    2.015156]  mmcblk0: p1 p2
[    2.097591] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.105923] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.123122] devtmpfs: mounted
[    2.126948] Freeing init memory: 124K
[    2.188220] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.194865] Indeed it is in host mode hprt0 = 00001101
[    2.398554] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.405313] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.416087] hub 1-1:1.0: USB hub found
[    2.420079] hub 1-1:1.0: 3 ports detected
[    2.698433] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.818945] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.825879] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.848934] smsc95xx v1.0.4
[    2.913820] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:3a:39:61
[    3.018542] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[    3.139341] usb 1-1.2: New USB device found, idVendor=05e1, idProduct=0408
[    3.146276] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.166334] usb 1-1.2: Product: USB 2.0 Video Capture Controller
[    3.178250] usb 1-1.2: Manufacturer: Syntek Semiconductor
[    3.653295] udevd[137]: starting version 175
[    5.007370] Linux video capture interface: v2.00
[    5.279032] usb 1-1.2: New device Syntek Semiconductor USB 2.0 Video Capture Controller @ 480 Mbps (05e1:0408, interface 0, class 0)
[    5.649236] usb 1-1.2: video interface 0 found
[    6.648408] saa7115 0-0025: saa7113 found (1f7113d0e100000) @ 0x4a (stk1160)
[    8.568432] stk1160: driver ver 0.9.5 successfully loaded
[    8.690120] stk1160: registers to NTSC like standard
[    8.928662] stk1160 1-1.2:1.0: V4L2 device registered as video0
[    8.941160] usbcore: registered new interface driver snd-usb-audio
[    8.958256] usbcore: registered new interface driver stk1160
[   16.181319] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   16.624167] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   17.298599] bcm2835 ALSA card created!
[   17.302552] bcm2835 ALSA chip created!
[   17.306450] bcm2835 ALSA chip created!
[   17.324823] bcm2835 ALSA chip created!
[   17.332370] bcm2835 ALSA chip created!
[   17.336282] bcm2835 ALSA chip created!
[   17.347247] bcm2835 ALSA chip created!
[   17.353300] bcm2835 ALSA chip created!
[   24.821315] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[   26.221572] bcm2835-cpufreq: switching to governor ondemand
[   26.221599] bcm2835-cpufreq: switching to governor ondemand
[   29.767982] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SS
lsusb and lsmod
root@raspberrypi:/home/pi# lsusb
Bus 001 Device 004: ID 05e1:0408 Syntek Semiconductor Co., Ltd STK1160 Video Capture Device
root@raspberrypi:/home/pi# lsmod
snd_bcm2835            12808  1
snd_usb_audio          93354  1
snd_usbmidi_lib        17812  1 snd_usb_audio
snd_hwdep               5730  1 snd_usb_audio
snd_seq_midi            4518  0
snd_seq_midi_event      6513  1 snd_seq_midi
snd_rawmidi            20611  2 snd_seq_midi,snd_usbmidi_lib
snd_pcm                74834  2 snd_usb_audio,snd_bcm2835
snd_page_alloc          4951  1 snd_pcm
snd_seq                52536  2 snd_seq_midi_event,snd_seq_midi
snd_seq_device          6300  3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer              19698  2 snd_seq,snd_pcm
saa7115                13861  1
snd                    52489  13 snd_timer,snd_seq_device,snd_seq,snd_pcm,snd_rawmidi,snd_hwdep,snd_usbmidi_lib,snd_usb_audio,snd_bcm2835
stk1160                18947  0
videobuf2_vmalloc       1965  1 stk1160
videobuf2_memops        2364  1 videobuf2_vmalloc
videobuf2_core         21366  1 stk1160
v4l2_common             9405  2 stk1160,saa7115
videodev               88790  3 v4l2_common,stk1160,saa7115
...and mplayer logs:
[code]
root@raspberrypi:/home/pi# mplayer tv:// -tv driver=v4l2:device=/dev/video0:input=1:norm=NTSC-M
MPlayer svn r34540 (Debian), built with gcc-4.6 (C) 2000-2012 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing tv://.
TV file format detected.
Selected driver: v4l2
 name: Video 4 Linux 2 input
 author: Martin Olschewski <olschewski@zpr.uni-koeln.de>
 comment: first try, more to come ;-)
Selected device: stk1160
 Capabilities:  video capture  read/write  streaming
 supported norms: 0 = NTSC; 1 = NTSC-M; 2 = NTSC-M-JP; 3 = NTSC-M-KR; 4 = NTSC-443; 5 = PAL; 6 = PAL-BG; 7 = PAL-H; 8 = PAL-I; 9 = PAL-DK; 10 = PAL-M; 11 = PAL-N; 12 = PAL-Nc; 13 = PAL-60; 14 = SECAM; 15 = SECAM-B; 16 = SECAM-G; 17 = SECAM-H; 18 = SECAM-DK; 19 = SECAM-L; 20 = SECAM-Lc;
 inputs: 0 = Composite0; 1 = Composite1; 2 = Composite2; 3 = Composite3;
 Current input: 0
 Current format: UYVY
v4l2: ioctl set format failed: Invalid argument
Selected input hasn't got a tuner!
v4l2: ioctl set mute failed: Invalid argument
Xlib:  extension "XFree86-VidModeExtension" missing on display ":1".
Xlib:  extension "XVideo" missing on display ":1".
[VO_XV] Sorry, Xv not supported by this X11 version/driver
[VO_XV] ******** Try with  -vo x11  or  -vo sdl  *********
[gl] no GLX support present
Opening video decoder: [raw] RAW Uncompressed Video
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
Movie-Aspect is undefined - no prescaling applied.
[swscaler @ 0xf26ee0] BICUBIC scaler, from uyvy422 to bgra using C
VO: [x11] 720x480 => 720x480 BGRA
Selected video codec: [rawuyvy] vfm: raw (RAW UYVY)
Audio: no sound
Starting playback...
V:   0.0   1/  1 ??% ??% ??,?% 0 0
Frame too small! (602776<691200) Wrong format?
V:   0.0   2/  2 ??% ??% ??,?% 0 0
Frame too small! (602548<691200) Wrong format?
V:   0.0 486/486 ??% ??% ??,?% 0 0
Frame too small! (600634<691200) Wrong format?
V:   0.0 487/487 ??% ??% ??,?% 0 0
Frame too small! (630228<691200) Wrong format?
V:   0.0 488/488 ??% ??% ??,?% 0 0
Frame too small! (599870<691200) Wrong format?
V:   0.0 489/489 ??% ??% ??,?% 0 0
Frame too small! (621652<691200) Wrong format?
V:   0.0 490/490 ??% ??% ??,?% 0 0
Frame too small! (613108<691200) Wrong format?
V:   0.0 492/492 ??% ??% ??,?% 0 0
Frame too small! (645516<691200) Wrong format?
V:   0.0 493/493 ??% ??% ??,?% 0 0
Frame too small! (599964<691200) Wrong format?
V:   0.0 494/494 ??% ??% ??,?% 0 0
Frame too small! (617966<691200) Wrong format?
V:   0.0 495/495 ??% ??% ??,?% 0 0
Frame too small! (621148<691200) Wrong format?
V:   0.0 496/496 ??% ??% ??,?% 0 0
Frame too small! (596276<691200) Wrong format?
V:   0.0 497/497 ??% ??% ??,?% 0 0
Frame too small! (636550<691200) Wrong format?
V:   0.0 498/498 ??% ??% ??,?% 0 0
Frame too small! (589798<691200) Wrong format?
V:   0.0 499/499 ??% ??% ??,?% 0 0
Frame too small! (613974<691200) Wrong format?
V:   0.0 500/500 ??% ??% ??,?% 0 0
Frame too small! (617262<691200) Wrong format?
V:   0.0 501/501 ??% ??% ??,?% 0 0
Frame too small! (596442<691200) Wrong format?
V:   0.0 502/502 ??% ??% ??,?% 0 0
Frame too small! (640384<691200) Wrong format?
V:   0.0 503/503 ??% ??% ??,?% 0 0
Frame too small! (613664<691200) Wrong format?
V:   0.0 504/504 ??% ??% ??,?% 0 0
Frame too small! (614680<691200) Wrong format?
V:   0.0 505/505 ??% ??% ??,?% 0 0
Frame too small! (605952<691200) Wrong format?
V:   0.0 506/506 ??% ??% ??,?% 0 0
Frame too small! (603490<691200) Wrong format?
V:   0.0 507/507 ??% ??% ??,?% 0 0
Frame too small! (620074<691200) Wrong format?
V:   0.0 509/509 ??% ??% ??,?% 0 0
Frame too small! (632880<691200) Wrong format?
V:   0.0 510/510 ??% ??% ??,?% 0 0
Frame too small! (597384<691200) Wrong format?
V:   0.0 511/511 ??% ??% ??,?% 0 0
Frame too small! (594762<691200) Wrong format?
V:   0.0 512/512 ??% ??% ??,?% 0 0
Frame too small! (642402<691200) Wrong format?
V:   0.0 513/513 ??% ??% ??,?% 0 0
Frame too small! (590496<691200) Wrong format?
V:   0.0 514/514 ??% ??% ??,?% 0 0
Frame too small! (624330<691200) Wrong format?
V:   0.0 515/515 ??% ??% ??,?% 0 0
Frame too small! (622266<691200) Wrong format?
V:   0.0 516/516 ??% ??% ??,?% 0 0
Frame too small! (601722<691200) Wrong format?
V:   0.0 517/517 ??% ??% ??,?% 0 0
Frame too small! (635816<691200) Wrong format?
V:   0.0 518/518 ??% ??% ??,?% 0 0
Frame too small! (601962<691200) Wrong format?
V:   0.0 519/519 ??% ??% ??,?% 0 0
Frame too small! (597002<691200) Wrong format?
V:   0.0 520/520 ??% ??% ??,?% 0 0
Frame too small! (610830<691200) Wrong format?
V:   0.0 521/521 ??% ??% ??,?% 0 0
Frame too small! (595336<691200) Wrong format?
V:   0.0 522/522 ??% ??% ??,?% 0 0
Frame too small! (641090<691200) Wrong format?
V:   0.0 523/523 ??% ??% ??,?% 0 0
Frame too small! (599436<691200) Wrong format?
V:   0.0 524/524 ??% ??% ??,?% 0 0
Frame too small! (624236<691200) Wrong format?
V:   0.0 525/525 ??% ??% ??,?% 0 0
Frame too small! (622540<691200) Wrong format?
V:   0.0 526/526 ??% ??% ??,?% 0 0
Frame too small! (601846<691200) Wrong format?
V:   0.0 527/527 ??% ??% ??,?% 0 0
Frame too small! (632442<691200) Wrong format?
V:   0.0 528/528 ??% ??% ??,?% 0 0
Frame too small! (610984<691200) Wrong format?
V:   0.0 529/529 ??% ??% ??,?% 0 0
Frame too small! (598874<691200) Wrong format?
V:   0.0 530/530 ??% ??% ??,?% 0 0
Frame too small! (645080<691200) Wrong format?
V:   0.0 531/531 ??% ??% ??,?% 0 0
Frame too small! (593684<691200) Wrong format?
V:   0.0 532/532 ??% ??% ??,?% 0 0
Frame too small! (608410<691200) Wrong format?
V:   0.0 533/533 ??% ??% ??,?% 0 0
Frame too small! (607996<691200) Wrong format?
V:   0.0 534/534 ??% ??% ??,?% 0 0
Frame too small! (597418<691200) Wrong format?
V:   0.0 535/535 ??% ??% ??,?% 0 0
Frame too small! (630980<691200) Wrong format?
V:   0.0 536/536 ??% ??% ??,?% 0 0
Frame too small! (601674<691200) Wrong format?
V:   0.0 537/537 ??% ??% ??,?% 0 0
Frame too small! (620818<691200) Wrong format?
V:   0.0 538/538 ??% ??% ??,?% 0 0
Frame too small! (617326<691200) Wrong format?
V:   0.0 539/539 ??% ??% ??,?% 0 0
Frame too small! (585846<691200) Wrong format?
V:   0.0 540/540 ??% ??% ??,?% 0 0
Frame too small! (642192<691200) Wrong format?
V:   0.0 541/541 ??% ??% ??,?% 0 0
Frame too small! (600448<691200) Wrong format?
V:   0.0 542/542 ??% ??% ??,?% 0 0
Frame too small! (623960<691200) Wrong format?
V:   0.0 543/543 ??% ??% ??,?% 0 0
Frame too small! (618056<691200) Wrong format?
V:   0.0 544/544 ??% ??% ??,?% 0 0
Frame too small! (599944<691200) Wrong format?
V:   0.0 545/545 ??% ??% ??,?% 0 0
Frame too small! (636720<691200) Wrong format?
V:   0.0 547/547 ??% ??% ??,?% 0 0
Frame too small! (597632<691200) Wrong format?
V:   0.0 548/548 ??% ??% ??,?% 0 0
Frame too small! (620430<691200) Wrong format?
V:   0.0 549/549 ??% ??% ??,?% 0 0
Frame too small! (596914<691200) Wrong format?
V:   0.0 550/550 ??% ??% ??,?% 0 0
Frame too small! (629026<691200) Wrong format?
V:   0.0 551/551 ??% ??% ??,?% 0 0
Frame too small! (594646<691200) Wrong format?
V:   0.0 552/552 ??% ??% ??,?% 0 0
Frame too small! (604362<691200) Wrong format?
V:   0.0 553/553 ??% ??% ??,?% 0 0
Frame too small! (615764<691200) Wrong format?
V:   0.0 554/554 ??% ??% ??,?% 0 0
Frame too small! (600342<691200) Wrong format?
V:   0.0 555/555 ??% ??% ??,?% 0 0
Frame too small! (633870<691200) Wrong format?
V:   0.0 556/556 ??% ??% ??,?% 0 0
Frame too small! (609218<691200) Wrong format?
V:   0.0 557/557 ??% ??% ??,?% 0 0
Frame too small! (599364<691200) Wrong format?
V:   0.0 558/558 ??% ??% ??,?% 0 0
Frame too small! (633450<691200) Wrong format?
V:   0.0 559/559 ??% ??% ??,?% 0 0
Frame too small! (593666<691200) Wrong format?
V:   0.0 560/560 ??% ??% ??,?% 0 0
Frame too small! (624572<691200) Wrong format?
V:   0.0 561/561 ??% ??% ??,?% 0 0
Frame too small! (611198<691200) Wrong format?
V:   0.0 562/562 ??% ??% ??,?% 0 0
Frame too small! (593944<691200) Wrong format?
V:   0.0 563/563 ??% ??% ??,?% 0 0
Frame too small! (633980<691200) Wrong format?
V:   0.0 564/564 ??% ??% ??,?% 0 0
Frame too small! (582978<691200) Wrong format?
V:   0.0 565/565 ??% ??% ??,?% 0 0
Frame too small! (618460<691200) Wrong format?
V:   0.0 566/566 ??% ??% ??,?% 0 0
Frame too small! (610568<691200) Wrong format?
V:   0.0 567/567 ??% ??% ??,?% 0 0
Frame too small! (599742<691200) Wrong format?
V:   0.0 568/568 ??% ??% ??,?% 0 0
Frame too small! (635266<691200) Wrong format?
V:   0.0 569/569 ??% ??% ??,?% 0 0
Frame too small! (596404<691200) Wrong format?
V:   0.0 570/570 ??% ??% ??,?% 0 0
Frame too small! (620496<691200) Wrong format?
V:   0.0 571/571 ??% ??% ??,?% 0 0
Frame too small! (622468<691200) Wrong format?
V:   0.0 572/572 ??% ??% ??,?% 0 0
Frame too small! (600422<691200) Wrong format?
V:   0.0 573/573 ??% ??% ??,?% 0 0
Frame too small! (631854<691200) Wrong format?
V:   0.0 574/574 ??% ??% ??,?% 0 0
Frame too small! (612338<691200) Wrong format?
V:   0.0 575/575 ??% ??% ??,?% 0 0
Frame too small! (595282<691200) Wrong format?
V:   0.0 576/576 ??% ??% ??,?% 0 0
Frame too small! (633548<691200) Wrong format?
V:   0.0 577/577 ??% ??% ??,?% 0 0
Frame too small! (598456<691200) Wrong format?
V:   0.0 578/578 ??% ??% ??,?% 0 0
Frame too small! (623066<691200) Wrong format?
V:   0.0 579/579 ??% ??% ??,?% 0 0
Frame too small! (614792<691200) Wrong format?
V:   0.0 580/580 ??% ??% ??,?% 0 0
Frame too small! (596610<691200) Wrong format?
V:   0.0 581/581 ??% ??% ??,?% 0 0
Frame too small! (634198<691200) Wrong format?
V:   0.0 583/583 ??% ??% ??,?% 0 0
Frame too small! (613570<691200) Wrong format?
V:   0.0 584/584 ??% ??% ??,?% 0 0
Frame too small! (616996<691200) Wrong format?
V:   0.0 585/585 ??% ??% ??,?% 0 0
Frame too small! (599930<691200) Wrong format?
V:   0.0 586/586 ??% ??% ??,?% 0 0
Frame too small! (643640<691200) Wrong format?
V:   0.0 587/587 ??% ??% ??,?% 0 0
Frame too small! (592118<691200) Wrong format?
V:   0.0 588/588 ??% ??% ??,?% 0 0
Frame too small! (610822<691200) Wrong format?
V:   0.0 589/589 ??% ??% ??,?% 0 0
Frame too small! (631258<691200) Wrong format?
V:   0.0 590/590 ??% ??% ??,?% 0 0
Frame too small! (592760<691200) Wrong format?
V:   0.0 591/591 ??% ??% ??,?% 0 0
Frame too small! (624362<691200) Wrong format?
V:   0.0 592/592 ??% ??% ??,?% 0 0
Frame too small! (615668<691200) Wrong format?
V:   0.0 593/593 ??% ??% ??,?% 0 0
Frame too small! (597004<691200) Wrong format?
V:   0.0 594/594 ??% ??% ??,?% 0 0
Frame too small! (613070<691200) Wrong format?
V:   0.0 595/595 ??% ??% ??,?% 0 0
Frame too small! (597226<691200) Wrong format?
V:   0.0 596/596 ??% ??% ??,?% 0 0
Frame too small! (634296<691200) Wrong format?
V:   0.0 597/597 ??% ??% ??,?% 0 0
Frame too small! (598484<691200) Wrong format?
V:   0.0 598/598 ??% ??% ??,?% 0 0
Frame too small! (598934<691200) Wrong format?
V:   0.0 599/599 ??% ??% ??,?% 0 0
Frame too small! (638824<691200) Wrong format?
V:   0.0 600/600 ??% ??% ??,?% 0 0
Frame too small! (596644<691200) Wrong format?
V:   0.0 601/601 ??% ??% ??,?% 0 0
Frame too small! (624380<691200) Wrong format?
V:   0.0 602/602 ??% ??% ??,?% 0 0
Frame too small! (616422<691200) Wrong format?
V:   0.0 603/603 ??% ??% ??,?% 0 0
Frame too small! (595222<691200) Wrong format?
V:   0.0 604/604 ??% ??% ??,?% 0 0
Frame too small! (637356<691200) Wrong format?
V:   0.0 605/605 ??% ??% ??,?% 0 0
Frame too small! (602300<691200) Wrong format?
V:   0.0 606/606 ??% ??% ??,?% 0 0
Frame too small! (602000<691200) Wrong format?
V:   0.0 607/607 ??% ??% ??,?% 0 0
Frame too small! (632758<691200) Wrong format?
V:   0.0 608/608 ??% ??% ??,?% 0 0
Frame too small! (597288<691200) Wrong format?
V:   0.0 609/609 ??% ??% ??,?% 0 0
Frame too small! (625504<691200) Wrong format?
V:   0.0 610/610 ??% ??% ??,?% 0 0
Frame too small! (598596<691200) Wrong format?
V:   0.0 611/611 ??% ??% ??,?% 0 0
Frame too small! (591226<691200) Wrong format?
V:   0.0 612/612 ??% ??% ??,?% 0 0
Frame too small! (637632<691200) Wrong format?
V:   0.0 613/613 ??% ??% ??,?% 0 0
Frame too small! (597580<691200) Wrong format?
V:   0.0 614/614 ??% ??% ??,?% 0 0
Frame too small! (621730<691200) Wrong format?
V:   0.0 615/615 ??% ??% ??,?% 0 0
Frame too small! (617218<691200) Wrong format?
V:   0.0 616/616 ??% ??% ??,?% 0 0
Frame too small! (598082<691200) Wrong format?
V:   0.0 617/617 ??% ??% ??,?% 0 0
Frame too small! (642332<691200) Wrong format?
V:   0.0 618/618 ??% ??% ??,?% 0 0
Frame too small! (599704<691200) Wrong format?
V:   0.0 619/619 ??% ??% ??,?% 0 0
Frame too small! (604728<691200) Wrong format?
V:   0.0 620/620 ??% ??% ??,?% 0 0
Frame too small! (638548<691200) Wrong format?
V:   0.0 621/621 ??% ??% ??,?% 0 0
Frame too small! (584192<691200) Wrong format?
V:   0.0 622/622 ??% ??% ??,?% 0 0
Frame too small! (633254<691200) Wrong format?
V:   0.0 623/623 ??% ??% ??,?% 0 0
Frame too small! (597430<691200) Wrong format?
V:   0.0 624/624 ??% ??% ??,?% 0 0
Frame too small! (604366<691200) Wrong format?
V:   0.0 625/625 ??% ??% ??,?% 0 0
Frame too small! (623106<691200) Wrong format?
V:   0.0 626/626 ??% ??% ??,?% 0 0
Frame too small! (593916<691200) Wrong format?
V:   0.0 627/627 ??% ??% ??,?% 0 0
Frame too small! (631176<691200) Wrong format?
V:   0.0 628/628 ??% ??% ??,?% 0 0
Frame too small! (598700<691200) Wrong format?
V:   0.0 629/629 ??% ??% ??,?% 0 0
Frame too small! (597214<691200) Wrong format?
V:   0.0 630/630 ??% ??% ??,?% 0 0
Frame too small! (637464<691200) Wrong format?
V:   0.0 631/631 ??% ??% ??,?% 0 0
Frame too small! (597280<691200) Wrong format?
V:   0.0 632/632 ??% ??% ??,?% 0 0
Frame too small! (619470<691200) Wrong format?
V:   0.0 633/633 ??% ??% ??,?% 0 0
Frame too small! (619096<691200) Wrong format?
V:   0.0 634/634 ??% ??% ??,?% 0 0
Frame too small! (596066<691200) Wrong format?
V:   0.0 635/635 ??% ??% ??,?% 0 0
Frame too small! (639734<691200) Wrong format?
V:   0.0 636/636 ??% ??% ??,?% 0 0
Frame too small! (589112<691200) Wrong format?
V:   0.0 637/637 ??% ??% ??,?% 0 0
Frame too small! (624864<691200) Wrong format?
V:   0.0 638/638 ??% ??% ??,?% 0 0
Frame too small! (619612<691200) Wrong format?
V:   0.0 639/639 ??% ??% ??,?% 0 0
Frame too small! (591372<691200) Wrong format?
V:   0.0 640/640 ??% ??% ??,?% 0 0
Frame too small! (639512<691200) Wrong format?
V:   0.0 641/641 ??% ??% ??,?% 0 0
Frame too small! (594244<691200) Wrong format?
V:   0.0 642/642 ??% ??% ??,?% 0 0
Frame too small! (611958<691200) Wrong format?
V:   0.0 643/643 ??% ??% ??,?% 0 0
Frame too small! (616264<691200) Wrong format?
V:   0.0 644/644 ??% ??% ??,?% 0 0
V:   0.0 645/645 ??% ??% ??,?% 0 0
Frame too small! (620884<691200) Wrong format?
V:   0.0 647/647 ??% ??% ??,?% 0 0
Frame too small! (627740<691200) Wrong format?
V:   0.0 648/648 ??% ??% ??,?% 0 0
Frame too small! (610408<691200) Wrong format?
V:   0.0 649/649 ??% ??% ??,?% 0 0
Frame too small! (594962<691200) Wrong format?
V:   0.0 650/650 ??% ??% ??,?% 0 0
Frame too small! (642628<691200) Wrong format?
V:   0.0 651/651 ??% ??% ??,?% 0 0
Frame too small! (595310<691200) Wrong format?
V:   0.0 652/652 ??% ??% ??,?% 0 0
Frame too small! (624684<691200) Wrong format?
V:   0.0 653/653 ??% ??% ??,?% 0 0
Frame too small! (618114<691200) Wrong format?
V:   0.0 654/654 ??% ??% ??,?% 0 0
Frame too small! (591576<691200) Wrong format?
V:   0.0 655/655 ??% ??% ??,?% 0 0
Frame too small! (638598<691200) Wrong format?
V:   0.0 656/656 ??% ??% ??,?% 0 0
Frame too small! (596408<691200) Wrong format?
V:   0.0 657/657 ??% ??% ??,?% 0 0
Frame too small! (609170<691200) Wrong format?
V:   0.0 658/658 ??% ??% ??,?% 0 0
Frame too small! (609064<691200) Wrong format?
V:   0.0 659/659 ??% ??% ??,?% 0 0
Frame too small! (587688<691200) Wrong format?
V:   0.0 660/660 ??% ??% ??,?% 0 0
Frame too small! (644312<691200) Wrong format?
V:   0.0 661/661 ??% ??% ??,?% 0 0
Frame too small! (601234<691200) Wrong format?
V:   0.0 662/662 ??% ??% ??,?% 0 0
Frame too small! (618262<691200) Wrong format?
V:   0.0 664/664 ??% ??% ??,?% 0 0
Frame too small! (586764<691200) Wrong format?
V:   0.0 665/665 ??% ??% ??,?% 0 0
Frame too small! (637342<691200) Wrong format?
V:   0.0 666/666 ??% ??% ??,?% 0 0
Frame too small! (596026<691200) Wrong format?
V:   0.0 668/668 ??% ??% ??,?% 0 0
Frame too small! (634772<691200) Wrong format?
V:   0.0 669/669 ??% ??% ??,?% 0 0
Frame too small! (591338<691200) Wrong format?
V:   0.0 670/670 ??% ??% ??,?% 0 0
Frame too small! (625660<691200) Wrong format?
V:   0.0 671/671 ??% ??% ??,?% 0 0
Frame too small! (610064<691200) Wrong format?
V:   0.0 672/672 ??% ??% ??,?% 0 0
Frame too small! (597246<691200) Wrong format?
V:   0.0 673/673 ??% ??% ??,?% 0 0
Frame too small! (635338<691200) Wrong format?
V:   0.0 674/674 ??% ??% ??,?% 0 0
Frame too small! (600372<691200) Wrong format?
V:   0.0 675/675 ??% ??% ??,?% 0 0
Frame too small! (649274<691200) Wrong format?
V:   0.0 676/676 ??% ??% ??,?% 0 0
Frame too small! (598758<691200) Wrong format?
V:   0.0 677/677 ??% ??% ??,?% 0 0
Frame too small! (617772<691200) Wrong format?
V:   0.0 678/678 ??% ??% ??,?% 0 0
Frame too small! (628706<691200) Wrong format?
V:   0.0 679/679 ??% ??% ??,?% 0 0
Frame too small! (632490<691200) Wrong format?
V:   0.0 680/680 ??% ??% ??,?% 0 0
Frame too small! (600396<691200) Wrong format?
V:   0.0 681/681 ??% ??% ??,?% 0 0
Frame too small! (594666<691200) Wrong format?
V:   0.0 682/682 ??% ??% ??,?% 0 0
Frame too small! (617282<691200) Wrong format?
V:   0.0 683/683 ??% ??% ??,?% 0 0
Frame too small! (596334<691200) Wrong format?
V:   0.0 684/684 ??% ??% ??,?% 0 0
Frame too small! (630310<691200) Wrong format?
V:   0.0 685/685 ??% ??% ??,?% 0 0
Frame too small! (611318<691200) Wrong format?
V:   0.0 686/686 ??% ??% ??,?% 0 0
Frame too small! (599034<691200) Wrong format?
V:   0.0 687/687 ??% ??% ??,?% 0 0
Frame too small! (644410<691200) Wrong format?
V:   0.0 688/688 ??% ??% ??,?% 0 0
Frame too small! (600340<691200) Wrong format?
V:   0.0 689/689 ??% ??% ??,?% 0 0
Frame too small! (621204<691200) Wrong format?
V:   0.0 690/690 ??% ??% ??,?% 0 0
Frame too small! (619716<691200) Wrong format?
V:   0.0 691/691 ??% ??% ??,?% 0 0
Frame too small! (592774<691200) Wrong format?
V:   0.0 692/692 ??% ??% ??,?% 0 0
Frame too small! (638530<691200) Wrong format?
V:   0.0 693/693 ??% ??% ??,?% 0 0
Frame too small! (585152<691200) Wrong format?
V:   0.0 694/694 ??% ??% ??,?% 0 0
Frame too small! (626212<691200) Wrong format?
V:   0.0 695/695 ??% ??% ??,?% 0 0
Frame too small! (608798<691200) Wrong format?
V:   0.0 696/696 ??% ??% ??,?% 0 0
Frame too small! (590398<691200) Wrong format?
V:   0.0 697/697 ??% ??% ??,?% 0 0
Frame too small! (626602<691200) Wrong format?
V:   0.0 698/698 ??% ??% ??,?% 0 0
Frame too small! (597562<691200) Wrong format?
V:   0.0 699/699 ??% ??% ??,?% 0 0
Frame too small! (624960<691200) Wrong format?
V:   0.0 700/700 ??% ??% ??,?% 0 0
Frame too small! (620894<691200) Wrong format?
V:   0.0 701/701 ??% ??% ??,?% 0 0
Frame too small! (600076<691200) Wrong format?
V:   0.0 702/702 ??% ??% ??,?% 0 0
Frame too small! (641616<691200) Wrong format?
V:   0.0 703/703 ??% ??% ??,?% 0 0
Frame too small! (599946<691200) Wrong format?
V:   0.0 706/706 ??% ??% ??,?% 0 0
Frame too small! (596296<691200) Wrong format?
V:   0.0 707/707 ??% ??% ??,?% 0 0
Frame too small! (628310<691200) Wrong format?
V:   0.0 708/708 ??% ??% ??,?% 0 0
Frame too small! (607892<691200) Wrong format?
V:   0.0 709/709 ??% ??% ??,?% 0 0
Frame too small! (597486<691200) Wrong format?
V:   0.0 710/710 ??% ??% ??,?% 0 0
Frame too small! (635420<691200) Wrong format?
V:   0.0 711/711 ??% ??% ??,?% 0 0
Frame too small! (588840<691200) Wrong format?
V:   0.0 712/712 ??% ??% ??,?% 0 0
Frame too small! (615438<691200) Wrong format?
V:   0.0 713/713 ??% ??% ??,?% 0 0
Frame too small! (614566<691200) Wrong format?
V:   0.0 714/714 ??% ??% ??,?% 0 0
Frame too small! (600504<691200) Wrong format?
V:   0.0 715/715 ??% ??% ??,?% 0 0
Frame too small! (642844<691200) Wrong format?
V:   0.0 716/716 ??% ??% ??,?% 0 0
Frame too small! (617348<691200) Wrong format?
V:   0.0 717/717 ??% ??% ??,?% 0 0
Frame too small! (642324<691200) Wrong format?
V:   0.0 718/718 ??% ??% ??,?% 0 0
Frame too small! (594340<691200) Wrong format?
V:   0.0 719/719 ??% ??% ??,?% 0 0
Frame too small! (617814<691200) Wrong format?
V:   0.0 720/720 ??% ??% ??,?% 0 0
Frame too small! (612960<691200) Wrong format?
V:   0.0 721/721 ??% ??% ??,?% 0 0
Frame too small! (599138<691200) Wrong format?
V:   0.0 722/722 ??% ??% ??,?% 0 0
Frame too small! (643748<691200) Wrong format?
V:   0.0 723/723 ??% ??% ??,?% 0 0
Frame too small! (604026<691200) Wrong format?
V:   0.0 724/724 ??% ??% ??,?% 0 0
Frame too small! (600240<691200) Wrong format?
V:   0.0 725/725 ??% ??% ??,?% 0 0
Frame too small! (646738<691200) Wrong format?
V:   0.0 728/728 ??% ??% ??,?% 0 0
Frame too small! (614466<691200) Wrong format?
V:   0.0 729/729 ??% ??% ??,?% 0 0
Frame too small! (598660<691200) Wrong format?
V:   0.0 730/730 ??% ??% ??,?% 0 0
Frame too small! (637834<691200) Wrong format?
V:   0.0 731/731 ??% ??% ??,?% 0 0
Frame too small! (596724<691200) Wrong format?
V:   0.0 732/732 ??% ??% ??,?% 0 0
Frame too small! (608154<691200) Wrong format?
V:   0.0 733/733 ??% ??% ??,?% 0 0
Frame too small! (625792<691200) Wrong format?
V:   0.0 734/734 ??% ??% ??,?% 0 0
Frame too small! (595000<691200) Wrong format?
V:   0.0 735/735 ??% ??% ??,?% 0 0
Frame too small! (631932<691200) Wrong format?
V:   0.0 736/736 ??% ??% ??,?% 0 0
Frame too small! (593478<691200) Wrong format?
V:   0.0 737/737 ??% ??% ??,?% 0 0
Frame too small! (599226<691200) Wrong format?
V:   0.0 738/738 ??% ??% ??,?% 0 0
Frame too small! (626912<691200) Wrong format?
V:   0.0 739/739 ??% ??% ??,?% 0 0
Frame too small! (612444<691200) Wrong format?
V:   0.0 740/740 ??% ??% ??,?% 0 0
Frame too small! (623116<691200) Wrong format?
V:   0.0 741/741 ??% ??% ??,?% 0 0
Frame too small! (620392<691200) Wrong format?
V:   0.0 742/742 ??% ??% ??,?% 0 0
Frame too small! (600116<691200) Wrong format?
V:   0.0 743/743 ??% ??% ??,?% 0 0
Frame too small! (643368<691200) Wrong format?
V:   0.0 744/744 ??% ??% ??,?% 0 0
Frame too small! (599612<691200) Wrong format?
V:   0.0 745/745 ??% ??% ??,?% 0 0
Frame too small! (595808<691200) Wrong format?
V:   0.0 746/746 ??% ??% ??,?% 0 0
Frame too small! (632034<691200) Wrong format?
V:   0.0 747/747 ??% ??% ??,?% 0 0
Frame too small! (592868<691200) Wrong format?
V:   0.0 748/748 ??% ??% ??,?% 0 0
Frame too small! (626312<691200) Wrong format?
V:   0.0 749/749 ??% ??% ??,?% 0 0
Frame too small! (603442<691200) Wrong format?
V:   0.0 750/750 ??% ??% ??,?% 0 0
Frame too small! (593076<691200) Wrong format?
V:   0.0 751/751 ??% ??% ??,?% 0 0
Frame too small! (622302<691200) Wrong format?
V:   0.0 754/754 ??% ??% ??,?% 0 0
Frame too small! (613298<691200) Wrong format?
V:   0.0 755/755 ??% ??% ??,?% 0 0
Frame too small! (598748<691200) Wrong format?
V:   0.0 756/756 ??% ??% ??,?% 0 0
Frame too small! (641104<691200) Wrong format?
V:   0.0 757/757 ??% ??% ??,?% 0 0
Frame too small! (602302<691200) Wrong format?
V:   0.0 758/758 ??% ??% ??,?% 0 0
Frame too small! (610824<691200) Wrong format?
V:   0.0 759/759 ??% ??% ??,?% 0 0
Frame too small! (631336<691200) Wrong format?
V:   0.0 760/760 ??% ??% ??,?% 0 0
Frame too small! (599644<691200) Wrong format?
V:   0.0 761/761 ??% ??% ??,?% 0 0
Frame too small! (624914<691200) Wrong format?
V:   0.0 762/762 ??% ??% ??,?% 0 0
Frame too small! (621672<691200) Wrong format?
V:   0.0 763/763 ??% ??% ??,?% 0 0
V:   0.0 764/764 ??% ??% ??,?% 0 0
Frame too small! (637978<691200) Wrong format?
V:   0.0 765/765 ??% ??% ??,?% 0 0
Frame too small! (590282<691200) Wrong format?
V:   0.0 766/766 ??% ??% ??,?% 0 0
Frame too small! (613948<691200) Wrong format?
V:   0.0 767/767 ??% ??% ??,?% 0 0
Frame too small! (613310<691200) Wrong format?
V:   0.0 768/768 ??% ??% ??,?% 0 0
Frame too small! (586330<691200) Wrong format?
V:   0.0 769/769 ??% ??% ??,?% 0 0
Frame too small! (643444<691200) Wrong format?
V:   0.0 770/770 ??% ??% ??,?% 0 0
Frame too small! (592018<691200) Wrong format?
V:   0.0 771/771 ??% ??% ??,?% 0 0
Frame too small! (611592<691200) Wrong format?
V:   0.0 772/772 ??% ??% ??,?% 0 0
Frame too small! (627984<691200) Wrong format?
V:   0.0 773/773 ??% ??% ??,?% 0 0
Frame too small! (596600<691200) Wrong format?
V:   0.0 775/775 ??% ??% ??,?% 0 0
Frame too small! (611276<691200) Wrong format?
V:   0.0 776/776 ??% ??% ??,?% 0 0
Frame too small! (599282<691200) Wrong format?
V:   0.0 777/777 ??% ??% ??,?% 0 0
Frame too small! (643706<691200) Wrong format?
V:   0.0 778/778 ??% ??% ??,?% 0 0
Frame too small! (597394<691200) Wrong format?
V:   0.0 779/779 ??% ??% ??,?% 0 0
Frame too small! (606338<691200) Wrong format?
V:   0.0 780/780 ??% ??% ??,?% 0 0
Frame too small! (623312<691200) Wrong format?
V:   0.0 782/782 ??% ??% ??,?% 0 0
Frame too small! (633796<691200) Wrong format?
V:   0.0 783/783 ??% ??% ??,?% 0 0
Frame too small! (594390<691200) Wrong format?
V:   0.0 784/784 ??% ??% ??,?% 0 0
Frame too small! (606432<691200) Wrong format?
V:   0.0 785/785 ??% ??% ??,?% 0 0
Frame too small! (617834<691200) Wrong format?
V:   0.0 786/786 ??% ??% ??,?% 0 0
Frame too small! (595848<691200) Wrong format?
V:   0.0 787/787 ??% ??% ??,?% 0 0
Frame too small! (635690<691200) Wrong format?
V:   0.0 788/788 ??% ??% ??,?% 0 0
Frame too small! (606780<691200) Wrong format?
V:   0.0 789/789 ??% ??% ??,?% 0 0
Frame too small! (599306<691200) Wrong format?
V:   0.0 790/790 ??% ??% ??,?% 0 0
Frame too small! (645344<691200) Wrong format?
V:   0.0 791/791 ??% ??% ??,?% 0 0
Frame too small! (600612<691200) Wrong format?
V:   0.0 792/792 ??% ??% ??,?% 0 0
Frame too small! (615002<691200) Wrong format?
V:   0.0 793/793 ??% ??% ??,?% 0 0
Frame too small! (628614<691200) Wrong format?
V:   0.0 794/794 ??% ??% ??,?% 0 0
Frame too small! (600226<691200) Wrong format?
V:   0.0 795/795 ??% ??% ??,?% 0 0
Frame too small! (622272<691200) Wrong format?
V:   0.0 796/796 ??% ??% ??,?% 0 0
Frame too small! (612798<691200) Wrong format?
V:   0.0 797/797 ??% ??% ??,?% 0 0
Frame too small! (594238<691200) Wrong format?
V:   0.0 800/800 ??% ??% ??,?% 0 0
Frame too small! (615368<691200) Wrong format?
V:   0.0 801/801 ??% ??% ??,?% 0 0
Frame too small! (615930<691200) Wrong format?
V:   0.0 802/802 ??% ??% ??,?% 0 0
Frame too small! (590506<691200) Wrong format?
V:   0.0 803/803 ??% ??% ??,?% 0 0
Frame too small! (645674<691200) Wrong format?
V:   0.0 804/804 ??% ??% ??,?% 0 0
Frame too small! (593618<691200) Wrong format?
V:   0.0 805/805 ??% ??% ??,?% 0 0
Frame too small! (616072<691200) Wrong format?
V:   0.0 806/806 ??% ??% ??,?% 0 0
Frame too small! (628368<691200) Wrong format?
V:   0.0 807/807 ??% ??% ??,?% 0 0
Frame too small! (594710<691200) Wrong format?
V:   0.0 808/808 ??% ??% ??,?% 0 0
Frame too small! (629192<691200) Wrong format?
V:   0.0 809/809 ??% ??% ??,?% 0 0
Frame too small! (614740<691200) Wrong format?
V:   0.0 810/810 ??% ??% ??,?% 0 0
Frame too small! (599924<691200) Wrong format?
V:   0.0 811/811 ??% ??% ??,?% 0 0
Frame too small! (644682<691200) Wrong format?
V:   0.0 812/812 ??% ??% ??,?% 0 0
Frame too small! (596456<691200) Wrong format?
V:   0.0 813/813 ??% ??% ??,?% 0 0
Frame too small! (621226<691200) Wrong format?
V:   0.0 814/814 ??% ??% ??,?% 0 0
Frame too small! (620158<691200) Wrong format?
V:   0.0 815/815 ??% ??% ??,?% 0 0
Frame too small! (588660<691200) Wrong format?
V:   0.0 818/818 ??% ??% ??,?% 0 0
Frame too small! (612968<691200) Wrong format?
V:   0.0 819/819 ??% ??% ??,?% 0 0
Frame too small! (618534<691200) Wrong format?
V:   0.0 820/820 ??% ??% ??,?% 0 0
Frame too small! (596202<691200) Wrong format?
V:   0.0 821/821 ??% ??% ??,?% 0 0
Frame too small! (638554<691200) Wrong format?
V:   0.0 822/822 ??% ??% ??,?% 0 0
Frame too small! (597952<691200) Wrong format?
V:   0.0 823/823 ??% ??% ??,?% 0 0
Frame too small! (614062<691200) Wrong format?
V:   0.0 824/824 ??% ??% ??,?% 0 0
Frame too small! (623552<691200) Wrong format?
V:   0.0 825/825 ??% ??% ??,?% 0 0
Frame too small! (595708<691200) Wrong format?
V:   0.0 826/826 ??% ??% ??,?% 0 0
Frame too small! (627284<691200) Wrong format?
V:   0.0 827/827 ??% ??% ??,?% 0 0
Frame too small! (613422<691200) Wrong format?
V:   0.0 828/828 ??% ??% ??,?% 0 0
Frame too small! (581542<691200) Wrong format?
V:   0.0 830/830 ??% ??% ??,?% 0 0
Frame too small! (593202<691200) Wrong format?
V:   0.0 831/831 ??% ??% ??,?% 0 0
Frame too small! (634002<691200) Wrong format?
V:   0.0 832/832 ??% ??% ??,?% 0 0
Frame too small! (592026<691200) Wrong format?
V:   0.0 833/833 ??% ??% ??,?% 0 0
Frame too small! (611946<691200) Wrong format?
V:   0.0 834/834 ??% ??% ??,?% 0 0
Frame too small! (622658<691200) Wrong format?
V:   0.0 835/835 ??% ??% ??,?% 0 0
Frame too small! (592292<691200) Wrong format?
V:   0.0 836/836 ??% ??% ??,?% 0 0
Frame too small! (624260<691200) Wrong format?
V:   0.0 837/837 ??% ??% ??,?% 0 0
Frame too small! (608402<691200) Wrong format?
V:   0.0 838/838 ??% ??% ??,?% 0 0
Frame too small! (596854<691200) Wrong format?
V:   0.0 839/839 ??% ??% ??,?% 0 0
Frame too small! (645374<691200) Wrong format?
V:   0.0 840/840 ??% ??% ??,?% 0 0
Frame too small! (600094<691200) Wrong format?
V:   0.0 841/841 ??% ??% ??,?% 0 0
Frame too small! (620852<691200) Wrong format?
V:   0.0 842/842 ??% ??% ??,?% 0 0
v4l2: 845 frames successfully processed, 131 frames dropped.
Exiting... (Quit)
print screen:
Raspberry Pi, model B, revision 2, 256MB RAM; Raspbian; Huawei E3131 modem (it works :-) ); EasyCap 4CH USB DVR (it works, but very slow)
I'm sorry for my English.
piotr-e
Re: USB redux
Tue Dec 11, 2012 9:45 am
Then for turbo mode. Dmesg after system starts:
[    0.060152] pid_max: default: 32768 minimum: 301
[    0.061133] Initializing cgroup subsys cpuacct
[    0.061227] Initializing cgroup subsys devices
[    0.061264] Initializing cgroup subsys freezer
[    0.061295] Initializing cgroup subsys blkio
[    0.061437] CPU: Testing write buffer coherency: ok
[    0.061789] hw perfevents: enabled with v6 PMU driver, 3 counters available
[    0.063013] devtmpfs: initialized
[    0.073392] NET: Registered protocol family 16
[    0.074089] bcm2708.uart_clock = 0
[    0.075755] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.075814] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.075852] mailbox: Broadcom VideoCore Mailbox driver
[    0.075958] bcm2708_vcio: mailbox at f200b880
[    0.076066] bcm_power: Broadcom power driver
[    0.076105] bcm_power_open() -> 0
[    0.076130] bcm_power_request(0, 8)
[    0.576808] bcm_mailbox_read -> 00000080, 0
[    0.576849] bcm_power_request -> 0
[    0.576875] Serial: AMBA PL011 UART driver
[    0.577032] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[    0.882639] console [ttyAMA0] enabled
[    0.907607] bio: create slab <bio-0> at 0
[    0.912827] SCSI subsystem initialized
[    0.916817] usbcore: registered new interface driver usbfs
[    0.922449] usbcore: registered new interface driver hub
[    0.928094] usbcore: registered new device driver usb
[    0.934067] Switching to clocksource stc
[    0.938416] FS-Cache: Loaded
[    0.941612] CacheFiles: Loaded
[    0.957807] NET: Registered protocol family 2
[    0.962714] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.970805] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.978326] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.984977] TCP: Hash tables configured (established 8192 bind 8192)
[    0.991384] TCP reno registered
[    0.994554] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.000463] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.007258] NET: Registered protocol family 1
[    1.012441] RPC: Registered named UNIX socket transport module.
[    1.018571] RPC: Registered udp transport module.
[    1.023295] RPC: Registered tcp transport module.
[    1.028009] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.034788] bcm2708_dma: DMA manager at cc808000
[    1.039587] bcm2708_gpio: bcm2708_gpio_probe c04d7a38
[    1.045053] vc-mem: phys_addr:0x00000000 mem_base=0x0c000000 mem_size:0x10000000(256 MiB)
[    1.054349] audit: initializing netlink socket (disabled)
[    1.059900] type=2000 audit(0.750:1): initialized
[    1.177495] VFS: Disk quotas dquot_6.5.2
[    1.181741] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.189290] FS-Cache: Netfs 'nfs' registered for caching
[    1.195565] msgmni has been set to 369
[    1.201417] io scheduler noop registered
[    1.205386] io scheduler deadline registered (default)
[    1.210832] io scheduler cfq registered
[    1.215142] kgdb: Registered I/O driver kgdboc.
[    1.229068] brd: module loaded
[    1.236959] loop: module loaded
[    1.240990] vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
[    1.248513] vcos: [1]: vchiq_init_state: called
[    1.253662] vcos: [1]: vchiq: initialised - version 2 (min 2), device 252.0
[    1.261335] usbcore: registered new interface driver smsc95xx
[    1.267168] cdc_ncm: 04-Aug-2011
[    1.270600] usbcore: registered new interface driver cdc_ncm
[    1.276285] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.487207] Core Release: 2.80a
[    1.490453] Setting default values for core params
[    1.495295] Finished setting default values for core params
[    1.706000] Using Buffer DMA mode
[    1.709365] Periodic Transfer Interrupt Enhancement - disabled
[    1.715215] Multiprocessor Interrupt Enhancement - disabled
[    1.720826] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.725201] Dedicated Tx FIFOs mode
[    1.728877] dwc_otg: Microframe scheduler enabled
[    1.728918] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.733856] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.741200] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    1.746763] Init: Port Power? op_state=1
[    1.750730] Init: Power Port (0)
[    1.754076] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.760926] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.768202] usb usb1: Product: DWC OTG Controller
[    1.772923] usb usb1: Manufacturer: Linux 3.2.27+ dwc_otg_hcd
[    1.778710] usb usb1: SerialNumber: bcm2708_usb
[    1.784021] hub 1-0:1.0: USB hub found
[    1.787823] hub 1-0:1.0: 1 port detected
[    1.792398] dwc_otg: FIQ enabled
[    1.792414] dwc_otg: NAK holdoff enabled
[    1.792435] Module dwc_common_port init
[    1.792765] usbcore: registered new interface driver uas
[    1.798111] Initializing USB Mass Storage driver...
[    1.803264] usbcore: registered new interface driver usb-storage
[    1.809332] USB Mass Storage support registered.
[    1.814114] usbcore: registered new interface driver libusual
[    1.820221] mousedev: PS/2 mouse device common for all mice
[    1.826522] bcm2835-cpufreq: min=700000 max=1000000 cur=700000
[    1.832351] bcm2835-cpufreq: switching to governor powersave
[    1.838041] bcm2835-cpufreq: switching to governor powersave
[    1.843798] cpuidle: using governor ladder
[    1.848091] cpuidle: using governor menu
[    1.852127] sdhci: Secure Digital Host Controller Interface driver
[    1.858375] sdhci: Copyright(c) Pierre Ossman
[    1.862829] sdhci: Enable low-latency mode
[    1.866974] bcm_power_open() -> 1
[    1.870564] Registered led device: mmc0::
[    1.871983] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    1.879972] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    1.885907] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.891916] Registered led device: led0
[    1.892283] usbcore: registered new interface driver usbhid
[    1.897882] usbhid: USB HID core driver
[    1.904077] TCP cubic registered
[    1.907333] Initializing XFRM netlink socket
[    1.911697] NET: Registered protocol family 17
[    1.916229] Registering the dns_resolver key type
[    1.921134] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    1.939363] registered taskstats version 1
[    1.945729] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    1.956702] Waiting for root device /dev/mmcblk0p2...
[    1.988272] Indeed it is in host mode hprt0 = 00021501
[    1.993656] mmc0: new high speed SDHC card at address 1234
[    2.008748] mmcblk0: mmc0:1234 SA04G 3.68 GiB
[    2.015200]  mmcblk0: p1 p2
[    2.095632] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.103964] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.120977] devtmpfs: mounted
[    2.124797] Freeing init memory: 124K
[    2.188266] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.195328] Indeed it is in host mode hprt0 = 00001101
[    2.398571] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.405330] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.415317] hub 1-1:1.0: USB hub found
[    2.419301] hub 1-1:1.0: 3 ports detected
[    2.698469] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.818962] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.825895] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.851367] smsc95xx v1.0.4
[    2.923609] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:3a:39:61
[    3.038393] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[    3.159364] usb 1-1.2: New USB device found, idVendor=05e1, idProduct=0408
[    3.166297] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.188260] usb 1-1.2: Product: USB 2.0 Video Capture Controller
[    3.194324] usb 1-1.2: Manufacturer: Syntek Semiconductor
[    3.653247] udevd[137]: starting version 175
[    5.002991] Linux video capture interface: v2.00
[    5.287739] usb 1-1.2: New device Syntek Semiconductor USB 2.0 Video Capture Controller @ 480 Mbps (05e1:0408, interface 0, class 0)
[    5.661265] usb 1-1.2: video interface 0 found
[    6.748413] saa7115 0-0025: saa7113 found (1f7113d0e100000) @ 0x4a (stk1160)
[    8.668333] stk1160: driver ver 0.9.5 successfully loaded
[    8.790160] stk1160: registers to NTSC like standard
[    9.028974] stk1160 1-1.2:1.0: V4L2 device registered as video0
[    9.038490] usbcore: registered new interface driver snd-usb-audio
[    9.056188] usbcore: registered new interface driver stk1160
[   16.540830] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   16.985263] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   17.650603] bcm2835 ALSA card created!
[   17.654559] bcm2835 ALSA chip created!
[   17.669079] bcm2835 ALSA chip created!
[   17.673004] bcm2835 ALSA chip created!
[   17.676888] bcm2835 ALSA chip created!
[   17.693334] bcm2835 ALSA chip created!
[   17.697244] bcm2835 ALSA chip created!
[   17.708446] bcm2835 ALSA chip created!
[   26.027232] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[   26.242459] bcm2835-cpufreq: switching to governor ondemand
[   26.242488] bcm2835-cpufreq: switching to governor ondemand
[   30.081468] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SS
lsusb and lsmod:
snd_bcm2835            12808  1
snd_seq_midi            4518  0
saa7115                13861  1
stk1160                18947  0
and mplayer logs:
[code]
root@raspberrypi:/home/pi# mplayer tv:// -tv driver=v4l2:device=/dev/video0:input=0:norm=NTSC-M
Playing tv://.
 Current input: 0
[swscaler @ 0x1f1bee0] BICUBIC scaler, from uyvy422 to bgra using C
Audio: no sound
Frame too small! (632614<691200) Wrong format?
Frame too small! (614812<691200) Wrong format?
V:   0.0   3/  3 ??% ??% ??,?% 0 0
Frame too small! (621628<691200) Wrong format?
V:   0.0   4/  4 ??% ??% ??,?% 0 0
Frame too small! (608020<691200) Wrong format?
V:   0.0   5/  5 ??% ??% ??,?% 0 0
Frame too small! (622250<691200) Wrong format?
V:   0.0   6/  6 ??% ??% ??,?% 0 0
Frame too small! (629464<691200) Wrong format?
V:   0.0   8/  8 ??% ??% ??,?% 0 0
Frame too small! (654776<691200) Wrong format?
V:   0.0   9/  9 ??% ??% ??,?% 0 0
Frame too small! (655308<691200) Wrong format?
V:   0.0  10/ 10 ??% ??% ??,?% 0 0
Frame too small! (646164<691200) Wrong format?
V:   0.0  11/ 11 ??% ??% ??,?% 0 0
Frame too small! (657632<691200) Wrong format?
V:   0.0  12/ 12 ??% ??% ??,?% 0 0
Frame too small! (641026<691200) Wrong format?
V:   0.0  13/ 13 ??% ??% ??,?% 0 0
Frame too small! (636252<691200) Wrong format?
V:   0.0  14/ 14 ??% ??% ??,?% 0 0
Frame too small! (653144<691200) Wrong format?
V:   0.0  15/ 15 ??% ??% ??,?% 0 0
Frame too small! (646390<691200) Wrong format?
V:   0.0  16/ 16 ??% ??% ??,?% 0 0
Frame too small! (646702<691200) Wrong format?
V:   0.0  17/ 17 ??% ??% ??,?% 0 0
Frame too small! (655140<691200) Wrong format?
V:   0.0  18/ 18 ??% ??% ??,?% 0 0
Frame too small! (637172<691200) Wrong format?
V:   0.0  19/ 19 ??% ??% ??,?% 0 0
Frame too small! (657036<691200) Wrong format?
V:   0.0  20/ 20 ??% ??% ??,?% 0 0
Frame too small! (621714<691200) Wrong format?
V:   0.0  21/ 21 ??% ??% ??,?% 0 0
Frame too small! (606582<691200) Wrong format?
V:   0.0  22/ 22 ??% ??% ??,?% 0 0
Frame too small! (632932<691200) Wrong format?
V:   0.0  23/ 23 ??% ??% ??,?% 0 0
Frame too small! (618368<691200) Wrong format?
V:   0.0  24/ 24 ??% ??% ??,?% 0 0
Frame too small! (638626<691200) Wrong format?
V:   0.0  25/ 25 ??% ??% ??,?% 0 0
Frame too small! (612572<691200) Wrong format?
V:   0.0  26/ 26 ??% ??% ??,?% 0 0
Frame too small! (632218<691200) Wrong format?
V:   0.0  27/ 27 ??% ??% ??,?% 0 0
Frame too small! (617418<691200) Wrong format?
V:   0.0  28/ 28 ??% ??% ??,?% 0 0
Frame too small! (633504<691200) Wrong format?
V:   0.0  29/ 29 ??% ??% ??,?% 0 0
Frame too small! (641866<691200) Wrong format?
V:   0.0  32/ 32 ??% ??% ??,?% 0 0
Frame too small! (635938<691200) Wrong format?
V:   0.0  33/ 33 ??% ??% ??,?% 0 0
Frame too small! (643120<691200) Wrong format?
V:   0.0  34/ 34 ??% ??% ??,?% 0 0
Frame too small! (641880<691200) Wrong format?
V:   0.0  36/ 36 ??% ??% ??,?% 0 0
Frame too small! (650774<691200) Wrong format?
V:   0.0  37/ 37 ??% ??% ??,?% 0 0
Frame too small! (635226<691200) Wrong format?
V:   0.0  38/ 38 ??% ??% ??,?% 0 0
Frame too small! (642196<691200) Wrong format?
V:   0.0  39/ 39 ??% ??% ??,?% 0 0
Frame too small! (649090<691200) Wrong format?
V:   0.0  40/ 40 ??% ??% ??,?% 0 0
Frame too small! (639630<691200) Wrong format?
V:   0.0  41/ 41 ??% ??% ??,?% 0 0
Frame too small! (643982<691200) Wrong format?
V:   0.0  42/ 42 ??% ??% ??,?% 0 0
Frame too small! (637964<691200) Wrong format?
V:   0.0  43/ 43 ??% ??% ??,?% 0 0
Frame too small! (619188<691200) Wrong format?
V:   0.0  44/ 44 ??% ??% ??,?% 0 0
Frame too small! (614618<691200) Wrong format?
V:   0.0  45/ 45 ??% ??% ??,?% 0 0
Frame too small! (593628<691200) Wrong format?
V:   0.0  46/ 46 ??% ??% ??,?% 0 0
Frame too small! (623956<691200) Wrong format?
V:   0.0  47/ 47 ??% ??% ??,?% 0 0
Frame too small! (637358<691200) Wrong format?
V:   0.0  48/ 48 ??% ??% ??,?% 0 0
Frame too small! (600060<691200) Wrong format?
V:   0.0  49/ 49 ??% ??% ??,?% 0 0
Frame too small! (606244<691200) Wrong format?
V:   0.0  50/ 50 ??% ??% ??,?% 0 0
Frame too small! (613576<691200) Wrong format?
V:   0.0  51/ 51 ??% ??% ??,?% 0 0
Frame too small! (604222<691200) Wrong format?
V:   0.0  52/ 52 ??% ??% ??,?% 0 0
Frame too small! (642204<691200) Wrong format?
V:   0.0  53/ 53 ??% ??% ??,?% 0 0
Frame too small! (590396<691200) Wrong format?
V:   0.0  54/ 54 ??% ??% ??,?% 0 0
Frame too small! (614514<691200) Wrong format?
V:   0.0  55/ 55 ??% ??% ??,?% 0 0
Frame too small! (617494<691200) Wrong format?
V:   0.0  57/ 57 ??% ??% ??,?% 0 0
Frame too small! (627282<691200) Wrong format?
V:   0.0  58/ 58 ??% ??% ??,?% 0 0
Frame too small! (601302<691200) Wrong format?
V:   0.0  59/ 59 ??% ??% ??,?% 0 0
Frame too small! (621838<691200) Wrong format?
V:   0.0  60/ 60 ??% ??% ??,?% 0 0
Frame too small! (640672<691200) Wrong format?
V:   0.0  61/ 61 ??% ??% ??,?% 0 0
Frame too small! (651498<691200) Wrong format?
V:   0.0  62/ 62 ??% ??% ??,?% 0 0
Frame too small! (645370<691200) Wrong format?
V:   0.0  63/ 63 ??% ??% ??,?% 0 0
Frame too small! (648044<691200) Wrong format?
V:   0.0  64/ 64 ??% ??% ??,?% 0 0
Frame too small! (654526<691200) Wrong format?
V:   0.0  65/ 65 ??% ??% ??,?% 0 0
Frame too small! (639286<691200) Wrong format?
V:   0.0  68/ 68 ??% ??% ??,?% 0 0
Frame too small! (640752<691200) Wrong format?
V:   0.0  69/ 69 ??% ??% ??,?% 0 0
Frame too small! (654632<691200) Wrong format?
V:   0.0  70/ 70 ??% ??% ??,?% 0 0
Frame too small! (637160<691200) Wrong format?
V:   0.0  71/ 71 ??% ??% ??,?% 0 0
Frame too small! (646218<691200) Wrong format?
V:   0.0  72/ 72 ??% ??% ??,?% 0 0
Frame too small! (650944<691200) Wrong format?
V:   0.0  73/ 73 ??% ??% ??,?% 0 0
Frame too small! (636666<691200) Wrong format?
V:   0.0  74/ 74 ??% ??% ??,?% 0 0
Frame too small! (637232<691200) Wrong format?
V:   0.0  75/ 75 ??% ??% ??,?% 0 0
Frame too small! (642366<691200) Wrong format?
V:   0.0  76/ 76 ??% ??% ??,?% 0 0
Frame too small! (624198<691200) Wrong format?
V:   0.0  77/ 77 ??% ??% ??,?% 0 0
Frame too small! (650468<691200) Wrong format?
V:   0.0  78/ 78 ??% ??% ??,?% 0 0
Frame too small! (636998<691200) Wrong format?
V:   0.0  79/ 79 ??% ??% ??,?% 0 0
Frame too small! (608246<691200) Wrong format?
V:   0.0  80/ 80 ??% ??% ??,?% 0 0
Frame too small! (633322<691200) Wrong format?
V:   0.0  81/ 81 ??% ??% ??,?% 0 0
Frame too small! (606340<691200) Wrong format?
V:   0.0  82/ 82 ??% ??% ??,?% 0 0
Frame too small! (617018<691200) Wrong format?
V:   0.0  83/ 83 ??% ??% ??,?% 0 0
Frame too small! (629850<691200) Wrong format?
V:   0.0  84/ 84 ??% ??% ??,?% 0 0
Frame too small! (615866<691200) Wrong format?
V:   0.0  85/ 85 ??% ??% ??,?% 0 0
Frame too small! (624658<691200) Wrong format?
V:   0.0  86/ 86 ??% ??% ??,?% 0 0
Frame too small! (615730<691200) Wrong format?
V:   0.0  87/ 87 ??% ??% ??,?% 0 0
Frame too small! (628634<691200) Wrong format?
V:   0.0  88/ 88 ??% ??% ??,?% 0 0
Frame too small! (620996<691200) Wrong format?
V:   0.0  89/ 89 ??% ??% ??,?% 0 0
Frame too small! (632238<691200) Wrong format?
V:   0.0  90/ 90 ??% ??% ??,?% 0 0
Frame too small! (619974<691200) Wrong format?
V:   0.0  91/ 91 ??% ??% ??,?% 0 0
Frame too small! (630686<691200) Wrong format?
V:   0.0  92/ 92 ??% ??% ??,?% 0 0
Frame too small! (621762<691200) Wrong format?
V:   0.0  95/ 95 ??% ??% ??,?% 0 0
Frame too small! (646272<691200) Wrong format?
V:   0.0  96/ 96 ??% ??% ??,?% 0 0
Frame too small! (652390<691200) Wrong format?
V:   0.0  97/ 97 ??% ??% ??,?% 0 0
Frame too small! (639292<691200) Wrong format?
V:   0.0  98/ 98 ??% ??% ??,?% 0 0
Frame too small! (637310<691200) Wrong format?
V:   0.0  99/ 99 ??% ??% ??,?% 0 0
Frame too small! (648876<691200) Wrong format?
V:   0.0 100/100 ??% ??% ??,?% 0 0
Frame too small! (644398<691200) Wrong format?
V:   0.0 101/101 ??% ??% ??,?% 0 0
Frame too small! (645554<691200) Wrong format?
V:   0.0 102/102 ??% ??% ??,?% 0 0
Frame too small! (644672<691200) Wrong format?
V:   0.0 103/103 ??% ??% ??,?% 0 0
Frame too small! (647514<691200) Wrong format?
V:   0.0 104/104 ??% ??% ??,?% 0 0
Frame too small! (654708<691200) Wrong format?
V:   0.0 105/105 ??% ??% ??,?% 0 0
Frame too small! (637650<691200) Wrong format?
V:   0.0 106/106 ??% ??% ??,?% 0 0
Frame too small! (634826<691200) Wrong format?
V:   0.0 107/107 ??% ??% ??,?% 0 0
Frame too small! (608262<691200) Wrong format?
V:   0.0 108/108 ??% ??% ??,?% 0 0
Frame too small! (625396<691200) Wrong format?
V:   0.0 109/109 ??% ??% ??,?% 0 0
Frame too small! (622376<691200) Wrong format?
V:   0.0 110/110 ??% ??% ??,?% 0 0
Frame too small! (611396<691200) Wrong format?
V:   0.0 111/111 ??% ??% ??,?% 0 0
Frame too small! (608832<691200) Wrong format?
V:   0.0 112/112 ??% ??% ??,?% 0 0
Frame too small! (618274<691200) Wrong format?
V:   0.0 115/115 ??% ??% ??,?% 0 0
Frame too small! (636040<691200) Wrong format?
V:   0.0 116/116 ??% ??% ??,?% 0 0
Frame too small! (634542<691200) Wrong format?
V:   0.0 117/117 ??% ??% ??,?% 0 0
Frame too small! (647292<691200) Wrong format?
V:   0.0 119/119 ??% ??% ??,?% 0 0
Frame too small! (654744<691200) Wrong format?
V:   0.0 120/120 ??% ??% ??,?% 0 0
Frame too small! (639458<691200) Wrong format?
V:   0.0 121/121 ??% ??% ??,?% 0 0
Frame too small! (636884<691200) Wrong format?
V:   0.0 122/122 ??% ??% ??,?% 0 0
Frame too small! (650574<691200) Wrong format?
V:   0.0 123/123 ??% ??% ??,?% 0 0
Frame too small! (636702<691200) Wrong format?
V:   0.0 124/124 ??% ??% ??,?% 0 0
Frame too small! (638884<691200) Wrong format?
V:   0.0 125/125 ??% ??% ??,?% 0 0
Frame too small! (649114<691200) Wrong format?
V:   0.0 126/126 ??% ??% ??,?% 0 0
Frame too small! (648178<691200) Wrong format?
V:   0.0 127/127 ??% ??% ??,?% 0 0
Frame too small! (610476<691200) Wrong format?
V:   0.0 128/128 ??% ??% ??,?% 0 0
Frame too small! (623828<691200) Wrong format?
V:   0.0 129/129 ??% ??% ??,?% 0 0
Frame too small! (614728<691200) Wrong format?
V:   0.0 130/130 ??% ??% ??,?% 0 0
Frame too small! (620424<691200) Wrong format?
V:   0.0 131/131 ??% ??% ??,?% 0 0
Frame too small! (621230<691200) Wrong format?
V:   0.0 132/132 ??% ??% ??,?% 0 0
Frame too small! (607600<691200) Wrong format?
V:   0.0 133/133 ??% ??% ??,?% 0 0
Frame too small! (625674<691200) Wrong format?
V:   0.0 134/134 ??% ??% ??,?% 0 0
Frame too small! (605644<691200) Wrong format?
V:   0.0 135/135 ??% ??% ??,?% 0 0
Frame too small! (614742<691200) Wrong format?
V:   0.0 136/136 ??% ??% ??,?% 0 0
Frame too small! (613294<691200) Wrong format?
V:   0.0 137/137 ??% ??% ??,?% 0 0
Frame too small! (609516<691200) Wrong format?
V:   0.0 138/138 ??% ??% ??,?% 0 0
Frame too small! (625292<691200) Wrong format?
V:   0.0 139/139 ??% ??% ??,?% 0 0
Frame too small! (603724<691200) Wrong format?
V:   0.0 140/140 ??% ??% ??,?% 0 0
Frame too small! (596418<691200) Wrong format?
V:   0.0 141/141 ??% ??% ??,?% 0 0
Frame too small! (617354<691200) Wrong format?
V:   0.0 142/142 ??% ??% ??,?% 0 0
Frame too small! (610442<691200) Wrong format?
V:   0.0 145/145 ??% ??% ??,?% 0 0
Frame too small! (640124<691200) Wrong format?
V:   0.0 146/146 ??% ??% ??,?% 0 0
Frame too small! (650894<691200) Wrong format?
V:   0.0 147/147 ??% ??% ??,?% 0 0
Frame too small! (642060<691200) Wrong format?
V:   0.0 148/148 ??% ??% ??,?% 0 0
Frame too small! (633610<691200) Wrong format?
V:   0.0 149/149 ??% ??% ??,?% 0 0
Frame too small! (643100<691200) Wrong format?
V:   0.0 150/150 ??% ??% ??,?% 0 0
Frame too small! (644158<691200) Wrong format?
V:   0.0 151/151 ??% ??% ??,?% 0 0
Frame too small! (654182<691200) Wrong format?
V:   0.0 153/153 ??% ??% ??,?% 0 0
Frame too small! (643664<691200) Wrong format?
V:   0.0 154/154 ??% ??% ??,?% 0 0
Frame too small! (651232<691200) Wrong format?
V:   0.0 155/155 ??% ??% ??,?% 0 0
Frame too small! (638202<691200) Wrong format?
V:   0.0 156/156 ??% ??% ??,?% 0 0
Frame too small! (639294<691200) Wrong format?
V:   0.0 157/157 ??% ??% ??,?% 0 0
Frame too small! (641764<691200) Wrong format?
V:   0.0 158/158 ??% ??% ??,?% 0 0
Frame too small! (609374<691200) Wrong format?
V:   0.0 159/159 ??% ??% ??,?% 0 0
Frame too small! (620732<691200) Wrong format?
V:   0.0 160/160 ??% ??% ??,?% 0 0
Frame too small! (608878<691200) Wrong format?
V:   0.0 161/161 ??% ??% ??,?% 0 0
Frame too small! (593540<691200) Wrong format?
V:   0.0 162/162 ??% ??% ??,?% 0 0
V:   0.0 163/163 ??% ??% ??,?% 0 0
Frame too small! (592836<691200) Wrong format?
V:   0.0 164/164 ??% ??% ??,?% 0 0
Frame too small! (619458<691200) Wrong format?
V:   0.0 165/165 ??% ??% ??,?% 0 0
Frame too small! (634670<691200) Wrong format?
V:   0.0 166/166 ??% ??% ??,?% 0 0
Frame too small! (618480<691200) Wrong format?
V:   0.0 167/167 ??% ??% ??,?% 0 0
Frame too small! (624896<691200) Wrong format?
V:   0.0 169/169 ??% ??% ??,?% 0 0
Frame too small! (619738<691200) Wrong format?
V:   0.0 170/170 ??% ??% ??,?% 0 0
Frame too small! (625108<691200) Wrong format?
V:   0.0 171/171 ??% ??% ??,?% 0 0
Frame too small! (650538<691200) Wrong format?
V:   0.0 172/172 ??% ??% ??,?% 0 0
Frame too small! (641878<691200) Wrong format?
V:   0.0 173/173 ??% ??% ??,?% 0 0
Frame too small! (645614<691200) Wrong format?
V:   0.0 175/175 ??% ??% ??,?% 0 0
Frame too small! (639280<691200) Wrong format?
V:   0.0 176/176 ??% ??% ??,?% 0 0
Frame too small! (643942<691200) Wrong format?
V:   0.0 177/177 ??% ??% ??,?% 0 0
Frame too small! (635446<691200) Wrong format?
V:   0.0 178/178 ??% ??% ??,?% 0 0
Frame too small! (645748<691200) Wrong format?
V:   0.0 179/179 ??% ??% ??,?% 0 0
Frame too small! (650898<691200) Wrong format?
V:   0.0 180/180 ??% ??% ??,?% 0 0
Frame too small! (640880<691200) Wrong format?
V:   0.0 181/181 ??% ??% ??,?% 0 0
Frame too small! (647886<691200) Wrong format?
V:   0.0 182/182 ??% ??% ??,?% 0 0
Frame too small! (650506<691200) Wrong format?
V:   0.0 183/183 ??% ??% ??,?% 0 0
Frame too small! (638826<691200) Wrong format?
V:   0.0 184/184 ??% ??% ??,?% 0 0
Frame too small! (635134<691200) Wrong format?
V:   0.0 185/185 ??% ??% ??,?% 0 0
Frame too small! (649388<691200) Wrong format?
V:   0.0 186/186 ??% ??% ??,?% 0 0
Frame too small! (648508<691200) Wrong format?
V:   0.0 187/187 ??% ??% ??,?% 0 0
Frame too small! (650606<691200) Wrong format?
V:   0.0 190/190 ??% ??% ??,?% 0 0
Frame too small! (642440<691200) Wrong format?
V:   0.0 191/191 ??% ??% ??,?% 0 0
Frame too small! (635792<691200) Wrong format?
V:   0.0 192/192 ??% ??% ??,?% 0 0
Frame too small! (650906<691200) Wrong format?
V:   0.0 193/193 ??% ??% ??,?% 0 0
Frame too small! (645414<691200) Wrong format?
V:   0.0 194/194 ??% ??% ??,?% 0 0
Frame too small! (645528<691200) Wrong format?
V:   0.0 195/195 ??% ??% ??,?% 0 0
Frame too small! (654166<691200) Wrong format?
V:   0.0 196/196 ??% ??% ??,?% 0 0
Frame too small! (641418<691200) Wrong format?
V:   0.0 197/197 ??% ??% ??,?% 0 0
Frame too small! (642268<691200) Wrong format?
V:   0.0 199/199 ??% ??% ??,?% 0 0
Frame too small! (637782<691200) Wrong format?
V:   0.0 200/200 ??% ??% ??,?% 0 0
Frame too small! (647200<691200) Wrong format?
V:   0.0 201/201 ??% ??% ??,?% 0 0
Frame too small! (615892<691200) Wrong format?
V:   0.0 202/202 ??% ??% ??,?% 0 0
Frame too small! (619904<691200) Wrong format?
V:   0.0 203/203 ??% ??% ??,?% 0 0
Frame too small! (607664<691200) Wrong format?
V:   0.0 204/204 ??% ??% ??,?% 0 0
Frame too small! (632978<691200) Wrong format?
V:   0.0 205/205 ??% ??% ??,?% 0 0
v4l2: 208 frames successfully processed, 167 frames dropped.
Exiting... (Quit)
and print screen
piotr-e
Re: USB redux
Tue Dec 11, 2012 9:52 am
So, green strip on the bottom of each print screen has different width. For 1GHz green strip is narrower than for 700MHz.
@gsh, how can I help you in solving this problem?
gsh
Re: USB redux
Tue Dec 11, 2012 4:08 pm
So from what I can see here, you are using mplayer to output the video to the screen, this means you are trying to do software decode on the ARM.
I don't believe (but please correct me if I'm wrong) that mplayer is pushing video across onto the GPU to do the right thing... It looks like you getting raw video meaning that the ARM is having to pump through the data.
The ARM is not efficient in this respect copying data to a frame buffer...
Have you tried streaming the encoded stream to a file and then playing it back using omxplayer?
Gordon
Gordon Hollingworth PhD
whitewizard
Re: USB redux
Wed Dec 12, 2012 7:03 pm
I have been having USB controller issues like many others with the latest raspbian and stock 3.2.27+ kernel. Usually my USB keyboard, mouse and ethernet would all stop working within a few minutes to an hour of normal usage (light web browsing, ssh, occasional apt-get upgrade).
Last night I compiled the latest kernel (3.6.10+) from https://github.com/raspberrypi/linux/tree/rpi-3.6.y.
So far my 512mb Pi has lasted all night long and I am posting from it right now... so it may appear that my USB problems have significantly improved (if not gone away).
I was not aware of a pre-compiled version of this kernel, but if anyone would like to try out the one I have compiled, you can grab it here: (hopefully it is ok to post this)
http://www.fiveforty.net/rpi-3.6.10-ker ... odules.tgz
Hope this helps.
dom
Re: USB redux
Wed Dec 12, 2012 7:08 pm
whitewizard wrote:Hi,
Hope this helps.
Good to head 3.6.10 was successful for you.
sudo rpi-update 788cddf57e1c9650f34b2cdea8c74410626805a9
will get this kernel (and more importantly the firmware that goes with it).
See:
http://www.raspberrypi.org/phpBB3/viewt ... 29&t=19334
whitewizard
Re: USB redux
Wed Dec 12, 2012 8:10 pm
Hope this helps.
See:
Scratch that, 3.6.10 is still not the answer. My USB devices just stopped working finally.
Any other ideas? I'm updated to the latest firmware (as of a few days ago) also.
piotr-e
Re: USB redux
Wed Dec 12, 2012 10:26 pm
gsh wrote:So from what I can see here, you are using mplayer to output the video to the screen, this means you are trying to do software decode on the ARM.
Gordon
I would like to use easycap for monitoring with motion or zoneminder and one or two tv cams.
In mplayer, I can crop or scale screen, but I have the same problem. I can reduce of fps, but I also have the same problem.
What program can you suggest for testing easycap vs RPi?
piotr-e
Re: USB redux
Fri Dec 14, 2012 3:39 pm
@gsh, can you prepare USB driver, which it will control by GPU(through few cores of GPU) :?: :?: It will be faster.
P.S.
Can you prepare SDK for programing GPU similar to CUDA :?:
Re: USB redux
Fri Dec 14, 2012 4:10 pm
piotr-e wrote:@gsh, can you prepare USB driver, which it will control by GPU(through few cores of GPU) :?: :?: It will be faster.
P.S.
Probably No, and No.
Both require a LOT of work, CUDA especially.
piotr-e
Re: USB redux
Fri Dec 14, 2012 5:56 pm
jamesh wrote: Probably No, and No.
Will in future X11 interface support by GPU :?:
ghans
Re: USB redux
Fri Dec 14, 2012 8:09 pm
teh_orph is working on it AFAIK.
ghans
piotr-e
Re: USB redux
Sat Dec 15, 2012 9:22 am
ghans wrote:teh_orph is working on it AFAIK.
ghans
English is my second language, can you explain it in other words...
drgeoff
Re: USB redux
Sat Dec 15, 2012 12:34 pm
ghans
AFAIK = As far as I know (= I believe)
teh_orp is the nickname of some person. ghans believes that person is working on getting the GPU to accelerate X.
ghans
Re: USB redux
Sat Dec 15, 2012 12:37 pm
The forum member teh_orph is actively working on
a GPU- accelerated version of the X11 Windowing System for the Pi.
As far as i know (AFAIK).
ghans
piotr-e
Re: USB redux
Sat Dec 15, 2012 1:49 pm
ghans wrote:The forum member teh_orph is actively working on
ghans
Thanks for the explanation.
Is teh_orph an employee of Foundation :?:
Re: USB redux
Sat Dec 15, 2012 4:46 pm
ghans
No. The Foundation has only one employee I think, and it's not him.
piotr-e
Re: USB redux
Sat Dec 15, 2012 7:42 pm
Only gsh :?:
@jamesh, do you know The Foundation plans about improvements of Raspbian? e.g. support GPU for X11.
Re: USB redux
Sun Dec 16, 2012 9:07 am
piotr-e wrote:
Only gsh :?:
No, GSH works for Broadcom and volunteers time for the Foundation.
Yes, I do know some of the plans, and no I'm not allowed to talk about them!
piotr-e
Re: USB redux
Sun Dec 16, 2012 10:28 am
:cry:
tmpp
Re: USB redux
Sun Dec 16, 2012 6:13 pm
I am new to Rpi, Nov, 2012 purchased 2 RP rev2 512's from Newark/Element_14. I hope this post contains words of encouragement.
My linux is as a commandline user and novice coder of Debian variants. I have slowly been suffering with Rpi as I come up to speed. First, I have read all the power supply and USB threads start to finish. My initial installation was the stock wheezy image (2012-10-28-wheezy-raspbian.img) on a 2GB SD card, and the troubles began. The updates through the familiar Debian package manager 'aptitude' did little to increase the random time-to-freeze of 1 min to best 24 min(idle).
 apt-get update && apt-get upgrade
I now have several SD cards dedicated to versions, I believe the version at the beginning is as follows:
root@raspberrypi:/dev# uname -a
Linux raspberrypi 3.2.27+ #250 PREEMPT Thu Oct 18 19:03:02 BST 2012 armv6l GNU/Linux
I praise all the regulars who put up with the chatter. I have experienced most if not all of the freeze/hangs discussed here. The USB kbd/mouse
 pi@raspberrypi ~ $ lsusb
Bus 005 Device 003: ID 413c:2002 Dell Computer Corp. SK-8125 Keyboard
Bus 001 Device 098: ID 046d:c00e Logitech, Inc. M-BJ58/M-BJ69 Optical Wheel Mouse
, and four other sets of HW, gave skips and repeats, etc. and drove me to adopt a headless SSH usage, until things settled down. Even then uptime is measured in minutes, not hours.
My background is a RF electrical engineer of 32 yrs, at a major cellular manufacturer, so hardware is most familiar. Yes, the power supply matters. Beginners, don't suffer this one, get a good one. I now have a 2A switcher supply spliced into the micro-usb-connector, that has a voltage on the header (or TP1/TP2) of 5.22V idle/hung and 5.06V full out CPU&USB. A poor supply which had 4.85 & 4.75V, respectively, and doubled the problems seen.
There are various power aspects still problematic which I attribute to either board design or circuitry or more likely, grounding interconnect. Simply attaching after boot, the RCA-video or 3.5mm audio plug may cause the rpi to lockup. I suggest this is the lack of non-mutually grounded supplies of the amplified speakers, or the flat-panel Dell display. That aside, I now, do not have power problems. ( proven later by reverting to various combinations of setup.)
Skipping ahead, get the latest firmware, and updated OS, for the rock solid performance I now observe. Using 'rpi-update' in concert with 'aptitude' to be at the latest is the quick ticket to success. Given the poor uptime, even headless, it was many restarts or resume downloads before a final card image was achieved. My version is now:
Linux raspberrypi 3.2.27+ #307 PREEMPT Mon Nov 26 23:22:29 GMT 2012 armv6l GNU/Linux
Given the solid performance achievement, I decided to stress test my setup.
1) headless; 2) 3.5 mm audio playing 'pianobar' on Pandora, Waylon and Willie; 3) 10BT half duplex wired network 4) several SSH shells to a desktop, (htop, and other scripts on performance) 5) USB/SD card adapter. 6) scp "local-read" ab@192.168.2.111:/home/ab/ (1GB file)
So lets listen to music, dup the newest SD card image in the USB adapter from the boot card using 'dd', watch the rpi cpu/memory stats in SSH shells, transfer a 1GB file back and forth to a desktop host. Pure JOY seeing the CPU pegged at 100% and Willie singing the chorus.
pi@raspberrypi ~ $ lsusb -s 1:4 -v
Bus 001 Device 004: ID 05e3:0723 Genesys Logic, Inc. GL827L SD/MMC/MS Flash Card Reader
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x05e3 Genesys Logic, Inc.
  idProduct          0x0723 GL827L SD/MMC/MS Flash Card Reader
  bcdDevice           94.51
  iManufacturer           3
  iProduct                4
  iSerial                 2
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         8 Mass Storage
      bInterfaceSubClass      6 SCSI
      bInterfaceProtocol     80 Bulk-Only
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
pi@raspberrypi ~ $
 root@raspberrypi:/home/pi# hdparm -tT /dev/mmcblk0
/dev/mmcblk0:
 Timing cached reads:   316 MB in  2.01 seconds = 157.46 MB/sec
 Timing buffered disk reads:  60 MB in  3.02 seconds =  19.90 MB/sec
I intend to use these Rpi's headless, but for the sake of this community, on to adding back theUSB kbd/ mouse/hub stuff.
Currently, seems to be solid for many minutes, but now hours will tell the satisfaction rather than minutes.
tmpp
Re: USB redux
Mon Dec 17, 2012 4:52 am
Good news toward getting a repeatable fix/flaw for the USB KBD problem.
I can repeat a bad keyboard, and then a perfect keyboard, then a bad keyboard all night if necessary. Now, I just need someone to tell me what to log during the cases so that the answer will be revealed !!!
First the setup, read the prior post to get the keyboard and mouse details which are directly attached to the Rpi, again the USB/SD adapter is present filling the second slot. Differences are that I can use either HDMI or composite without variance in the behaviour.
The steps to create a bad, no TERRIBLE kbd experience, are related to the prior shutdon having been simply pulling the power and not properly shutting down, a second power-up will recover the bad experience to a good/perfect one.
A good next boot can be done either at the terminal or Xterm. shutdown -h now. Then pull the power plug to extinguish the red LED. The next up will be flawless.
I did the 'good' to 'good' three times in succession with typing a paragraph for assurance each time.
I did the 'bad' three times for a toggle result bad,good,bad,bood etc.
What log capture will be helpful to send up?
Goodnight, won't be able to help until after work tomorrow, I'm afraid, in Chicago. GMT -6
poing
Re: USB redux
Tue Dec 18, 2012 2:08 pm
Some USB ideas:
I do find a difference between the behaviour of 4- and 7-port hubs. The 4-port gives no trouble while with the 7-port I see strange things happening, like a USB stick unmounting and mounting again immediately or WiFI dongles not working in a specific port where a keyboard has no problems but working just fine in another port of the same hub.
This specific 7-port hub (Sitecom) is several years old and has been used in many configurations including to couple three WD hard drives to a single USB port of a Synology (Linux-based) Nas box. I've always regarded it as ultra-reliable.
As you see always 4- or 7-port hubs on the market it's not rocket science to guess that one USB input can be forked to 4 USB ports with some specific standard hardware. A 7-port hub then obviously has two of such pieces of hardware where one fork of the first 4 is used as input of the second four for a total of 2*4-1=7.
In this line of thinking something goes wrong with the Pi and the second piece of hardware in a 7-port hub giving three dependable USB ports and four funky ones.
Just my €0.02
MaxK1
Re: USB redux
Tue Dec 18, 2012 2:48 pm
Or 7 funky ones...
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
