scrishton
Re: USB redux
Thu Jan 10, 2013 7:55 pm
Thanks very much for your help M33P.
Is it possible to set the USB serial device to work without interrupts? My remote devices never send data spontaneously, only in response to commands or requests from the host. And the number of bytes in the response packet are shown in the header, so the host always knows how many bytes to look for and when. So my software either sends commands to a port and looks for the response before moving to the next port, or more often sends a command to a group of ports then looks for responses on all of them.
On ports which are idle it slowly polls around the ports sending a device ID request to see what if anything is connected. If it gets an ID response it then requests the device status. If there is no response to the ID request the port is set to time out after about 10ms - the protocol says machines should reply within 9ms. This part of the program runs as a daemon thread so it doesn't hold up the rest of the program waiting for timeouts.
Adding delays between serial writes to slow down interrupts doesn't seem to help.
pythag
Re: USB redux
Fri Jan 11, 2013 10:17 am
M33P wrote:Pi USB users:
https://github.com/raspberrypi/linux/co ... 58719fe9b3
I found a subtle but quite nasty bug in the dwc_otg driver, and posted a patch to github. New kernel is available via rpi_update.
Thank you M33P! This has made a huge difference to my setup.
I'm running MD based raid5 on drives attached to 5 USB->SATA converters (4 connected to a hub and 1 connected directly). Prior to this patch I would see hundreds of USB device reset messages in the kernel log (just during a raid rebuild operation). If I did intensive reading from the array then usually a drive would disappear after 6 hours or so (several resets followed by a USB Disconnect), however writing seemed to be effected less (although I never managed more than 24 hours of intensive writing before either a crash or loss of a drive).
With the patch in place it's so far been running 24 hours and not a single USB reset message!
I can't imagine how you tracked that bug down - that driver is humongous! It would take me months to figure out how it's even meant to work, let alone find something as subtle as that.
Re: USB redux
Sat Jan 12, 2013 8:00 am
And there, in a nutshell, is why it's taking a while to sort it out.
scrishton
Re: USB redux
Sat Jan 12, 2013 11:35 pm
Still trying to get more than one FTDI serial port open whilst still being able to use the keyboard. I tried two different USB keyboards. One just stops responding with no errors reported in dmesg once more than one port is opened. The other one, an A4TECH KL-5, repeatedly disconnects and reconnects in the dmesg log, with pretty much the same result. Then there's a Logitech K260 wireless keyboard. Stops responding, no dmesg.
I noticed that the FTDIs are listed as high-speed devices and the USB keyboards low-speed. So I tried an Apple wired USB2 keyboard. Much the same problem, and it too lists as a low-speed device.
I installed a Bluetooth dongle and paired an Apple wireless keyboard. This stayed connected and working with all three FTDI cards and all worked as expected. Getting somewhere.
So I tried adding the Contour Shuttle USB control wheel. It would work fine with just one FTDI card, but stopped responding with more than one FTDI open. With the FTDIs plugged in but not open it works fine, but as soon as I open the serial ports the Shuttle device stops responding. This controller also lists in dmesg as a low-speed device, but no errors are reported.
So it looks as if there is a problem with mixing low speed devices with more than one high speed device.
M33P
Re: USB redux
Sun Jan 13, 2013 2:53 am
scrishton wrote:Still trying to get more than one FTDI serial port open whilst still being able to use the keyboard. I tried two different USB keyboards. One just stops responding with no errors reported in dmesg once more than one port is opened. The other one, an A4TECH KL-5, repeatedly disconnects and reconnects in the dmesg log, with pretty much the same result. Then there's a Logitech K260 wireless keyboard. Stops responding, no dmesg.
Could you post lsusb -v with your entire setup connected and post it within
 tags? I don't think I've seen a 4-port serial card before. I wonder if the driver has :D
In answer to your question about interrupts - it seems that USB serial converters have completely random implementations of UART over USB. This is transmitting all the info like parity errors, break conditions, flow control pins, data in FIFO etc. The PL2303 adapters use an interrupt endpoint to relay only out-of-band data periodically, disabling it (by removing it from the driver) merely turns it into a dumb FIFO.
Other chips will use it in a more involved sense. It gets really complicated when they use the control messages to set up baudrate, signal both FIFO level and out-of-band data with interrupt and use bulk for actual data transfer.
The FTDI chips use only control and bulk - control to set the device up and each bulk in/out packet has a special header detailing the state. Thus the bulk packet can be returned with no data but a header detailing a state change - this leads to lots of Bulk IN requests in a big queue if you have lots of FTDI devices open at once.
I think this is the root of your problem - the Pi only has 8 "host channels" which can only have 1 transfer on the go at a time. If a bulk channel comes along with a misuse of the intended purpose (i.e. let it sit and wait in the queue until external events dictate when some data arrives) then it hogs one of these. More than one port? More than one hog. If there are no channels available then no more USB transactions can be done (at all).
gsh
Re: USB redux
Sun Jan 13, 2013 8:26 am
I believe your problem is likely to be a mixture between different problems in the driver. First there is a known (and software unfixable) problem with each serial port taking 10K interrupts per second. We can reduce this to a more manageable level but the serial performance will be reduced, I've not bothered fixing this yet since I've had so many other things to do.
The second is possibly a downstream high speed or low speed hub behind a full speed hub (i.e. the 9512 on the board). I've had this before with some keyboards that have integrated hubs, be aware these are crappy rubbish hubs that can only handle low / high speed communications so don't plug anything full speed into it!
I won't bore you with the details but the driver doesn't take into account that it is trying to talk to two different devices in the same frame over a usb1 connection.
As M33P say's if you do a lsusb -t this will give us an idea of the topology of your usb hierarchy
Cheers
Gordon
Gordon Hollingworth PhD
scrishton
Re: USB redux
Sun Jan 13, 2013 1:29 pm
OK, I'll try to put the LSUSB results up. The devices use the FTDI FT4232H chip. I have just tried changing the cards to work in D2XX Direct mode instead of Virtual Com Port mode, but can see no difference in behaviour. I'm wondering if it's worth trying to change the port latency with FT_SetLatency_Timer, but not sure how to do this.
Anyway, here is the lsusb -v...
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idVendor           0x0424 Standard Microsystems Corp.
  idProduct          0x9512
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      1 Single TT
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            3.06
  iManufacturer           3
  iProduct                2
  iSerial                 1
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Bus 001 Device 008: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0403 Future Technology Devices International, Ltd
  idProduct          0x6011 FT4232H Quad HS USB-UART/FIFO IC
  bcdDevice            8.00
  iManufacturer           1
  iProduct                2
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength          101
    bNumInterfaces          4
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              200mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol    255 Vendor Specific Protocol
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x04  EP 4 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x85  EP 5 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x06  EP 6 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x87  EP 7 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x08  EP 8 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Bus 001 Device 009: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  bcdDevice            8.00
  iManufacturer           1
  iProduct                2
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength          101
    bNumInterfaces          4
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              200mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Bus 001 Device 010: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  bcdDevice            8.00
  iManufacturer           1
  iProduct                2
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength          101
    bNumInterfaces          4
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              200mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idProduct          0xec00
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               4
Bus 001 Device 004: ID 1c4f:0026 SiGma Micro
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x1c4f SiGma Micro
  idProduct          0x0026
  bcdDevice            1.10
  iManufacturer           1
  iProduct                2
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           59
    bNumInterfaces          2
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               98mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      1 Keyboard
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      54
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceSubClass      0 No Subclass
      bInterfaceProtocol      0 None
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength      50
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0003  1x 3 bytes
        bInterval              10
Bus 001 Device 005: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idVendor           0x05e3 Genesys Logic, Inc.
  idProduct          0x0610 4-port hub
  bcdDevice           77.32
  iManufacturer           0
  iProduct                1
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Bus 001 Device 006: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice           77.32
  iManufacturer           0
  iProduct                1
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Bus 001 Device 007: ID 0b33:0020 Contour Design, Inc. ShuttleXpress
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x0b33 Contour Design, Inc.
  idProduct          0x0020 ShuttleXpress
  bcdDevice            1.17
  iManufacturer           1
  iProduct                2
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    iConfiguration          4
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength      75
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
One of the devices has had it's name changed, but is exactly the same otherwise.
Here is the tree view...
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=hub, Driver=hub/3p, 480M
        |__ Port 1: Dev 3, If 0, Class=vend., Driver=smsc95xx, 480M
        |__ Port 2: Dev 4, If 0, Class=HID, Driver=usbhid, 1.5M
        |__ Port 2: Dev 4, If 1, Class=HID, Driver=usbhid, 1.5M
        |__ Port 3: Dev 5, If 0, Class=hub, Driver=hub/4p, 480M
            |__ Port 1: Dev 6, If 0, Class=hub, Driver=hub/4p, 480M
                |__ Port 1: Dev 8, If 0, Class=vend., Driver=ftdi_sio, 480M
                |__ Port 1: Dev 8, If 1, Class=vend., Driver=ftdi_sio, 480M
                |__ Port 1: Dev 8, If 2, Class=vend., Driver=ftdi_sio, 480M
                |__ Port 1: Dev 8, If 3, Class=vend., Driver=ftdi_sio, 480M
                |__ Port 2: Dev 9, If 0, Class=vend., Driver=ftdi_sio, 480M
                |__ Port 2: Dev 9, If 1, Class=vend., Driver=ftdi_sio, 480M
                |__ Port 2: Dev 9, If 2, Class=vend., Driver=ftdi_sio, 480M
                |__ Port 2: Dev 9, If 3, Class=vend., Driver=ftdi_sio, 480M
                |__ Port 3: Dev 10, If 0, Class=vend., Driver=ftdi_sio, 480M
                |__ Port 3: Dev 10, If 1, Class=vend., Driver=ftdi_sio, 480M
                |__ Port 3: Dev 10, If 2, Class=vend., Driver=ftdi_sio, 480M
                |__ Port 3: Dev 10, If 3, Class=vend., Driver=ftdi_sio, 480M
            |__ Port 2: Dev 7, If 0, Class=HID, Driver=usbhid, 1.5M
It doesn't seem to make any difference swapping the order of the ports on the hub, but I usually try to keep the FTDIs on one hub device and everything else on another. The keyboard is usually plugged straight into the Pi so I can unplug everything else easily to recover from a crash.
Simon R.
spiliot
Re: USB redux
Tue Jan 15, 2013 11:18 pm
I hope this is the correct place to post about another USB problem that is probably related to the host driver.
After trying to echo test > /dev/usb/lp0 on a thermal printer connected via USB, the pi hangs immediately. One out of three times of each hang I get a corrupted SD card that I need to rebuild.
On other linux systems I am able to print raw to /dev/usb/lp0 or via cups to usb::/Unknown/Printer (as this is how this printer is identified) to the same printer.
I have tested the setup on three v2 Pi's at hand, having either 2012-12 debian or 2012-09 arch, with or without latest firmware/kernel from rpi-config and even compiled a kernel of my own with USB Print support enabled. Power is coming from a bench PSU and tested with or without a powered hub, all with same results (pi hanging immediately on access to the port).
After enabling dmesg to send kernel debug messages on the console, I can see a never ending queue of messages that read something like (I'm not perfectly sure because the messages run so fast that I had to use a camera on fast shutter to be able to read them!):
ERROR::handle_hc_chhltd_intr_dma:2131: handle_hc_chhltd_intr_dma: Channel 1, DMA Mode -- ChHltd set, but reason for halting is unknown, hcint 0x000000402, intsts 0x06200001
An HP laser printer identified as /dev/usb/lp0 seems to work fine.
The thermal printer is identified as
Bus 001 Device 004: ID 0416:5011 Winbond Electronics Corp.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0416 Winbond Electronics Corp.
  idProduct          0x5011
  bcdDevice            2.02
  iManufacturer           1 IEEE-1284 Controlle
  iProduct                2 IEEE-1284 Controlle
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           78
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         7 Printer
      bInterfaceSubClass      1 Printer
      bInterfaceProtocol      1 Unidirectional
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           2
      bInterfaceProtocol      2 Bidirectional
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       2
      bNumEndpoints           3
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               1
Device Status:     0x0000
  (Bus Powered)
I'm hitting an end to my (already minimal) knowledge of debugging and I would appreciate any help to solve this.
castalla
Re: USB redux
Wed Jan 16, 2013 7:17 am
USB + Bluetooth + ethernet ?
Sorry if this is OT.
I'm clutching at straws here after days of experimentation with bluetooth.
Basically, if the bt device is switched off then the Pi crashes/locks up on ethernet.
The only way to avoid this is to issue the command:
bluez-test-device disconnect [device address]
then switch the device off.
This makes using bt headsets and speakers almost useless.
I suspect it's a usb device issue, and hope somebody here can advise.
I've posted across many bluetooth threads on various forums but gotten no response.
castalla
Re: USB redux
Wed Jan 16, 2013 9:34 am
Concerning the bluetooth network issue (above), here's the dmesg file (I have no idea if this gives any useful info):
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.2.27+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #250 PREEMPT Thu Oct 18 19:03:02 BST 2012
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 61440
[ 0.000000] free_area_init_node: node 0, pgdat c050db28, node_mem_map c05b6000
[ 0.000000] Normal zone: 480 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 60960 pages, LIFO batch:15
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 60960
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x4 bcm2708.serial=0x8f9c86fb smsc95xx.macaddr=B8:27:EB:9C:86:FB sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0xf000000 vc_mem.mem_size=0x10000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p3 rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 240MB = 240MB total
[ 0.000000] Memory: 237744k/237744k available, 8016k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xcf800000 - 0xe8000000 ( 392 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xcf000000 ( 240 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc04c0e78 (4836 kB)
[ 0.000000] .init : 0xc04c1000 - 0xc04e0b10 ( 127 kB)
[ 0.000000] .data : 0xc04e2000 - 0xc050e1c0 ( 177 kB)
[ 0.000000] .bss : 0xc050e1e4 - 0xc05b5128 ( 668 kB)
[ 0.000000] NR_IRQS:330
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] timer_set_mode: unhandled mode:1
[ 0.000000] timer_set_mode: unhandled mode:3
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.000941] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.060149] pid_max: default: 32768 minimum: 301
[ 0.060627] Mount-cache hash table entries: 512
[ 0.061115] Initializing cgroup subsys cpuacct
[ 0.061205] Initializing cgroup subsys devices
[ 0.061240] Initializing cgroup subsys freezer
[ 0.061270] Initializing cgroup subsys blkio
[ 0.061414] CPU: Testing write buffer coherency: ok
[ 0.061767] hw perfevents: enabled with v6 PMU driver, 3 counters available
[ 0.062984] devtmpfs: initialized
[ 0.073404] NET: Registered protocol family 16
[ 0.074098] bcm2708.uart_clock = 0
[ 0.075723] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.075782] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.075821] mailbox: Broadcom VideoCore Mailbox driver
[ 0.075929] bcm2708_vcio: mailbox at f200b880
[ 0.076033] bcm_power: Broadcom power driver
[ 0.076071] bcm_power_open() -> 0
[ 0.076096] bcm_power_request(0, 8)
[ 0.576773] bcm_mailbox_read -> 00000080, 0
[ 0.576811] bcm_power_request -> 0
[ 0.576837] Serial: AMBA PL011 UART driver
[ 0.576994] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 0.885113] console [ttyAMA0] enabled
[ 0.910627] bio: create slab <bio-0> at 0
[ 0.915852] SCSI subsystem initialized
[ 0.919846] usbcore: registered new interface driver usbfs
[ 0.925574] usbcore: registered new interface driver hub
[ 0.931161] usbcore: registered new device driver usb
[ 0.937211] Switching to clocksource stc
[ 0.941457] FS-Cache: Loaded
[ 0.944638] CacheFiles: Loaded
[ 0.961340] NET: Registered protocol family 2
[ 0.966175] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.974248] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.981747] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.988391] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.994813] TCP reno registered
[ 0.997981] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.003896] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.010683] NET: Registered protocol family 1
[ 1.015868] RPC: Registered named UNIX socket transport module.
[ 1.021995] RPC: Registered udp transport module.
[ 1.026719] RPC: Registered tcp transport module.
[ 1.031468] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.038213] bcm2708_dma: DMA manager at cf808000
[ 1.043012] bcm2708_gpio: bcm2708_gpio_probe c04e9c18
[ 1.048471] vc-mem: phys_addr:0x00000000 mem_base=0x0f000000 mem_size:0x10000000(256 MiB)
[ 1.057775] audit: initializing netlink socket (disabled)
[ 1.063326] type=2000 audit(0.750:1): initialized
[ 1.179815] VFS: Disk quotas dquot_6.5.2
[ 1.184061] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.191615] FS-Cache: Netfs 'nfs' registered for caching
[ 1.197878] msgmni has been set to 464
[ 1.203746] io scheduler noop registered
[ 1.207715] io scheduler deadline registered
[ 1.212290] io scheduler cfq registered (default)
[ 1.239707] Console: switching to colour frame buffer device 82x26
[ 1.252131] kgdb: Registered I/O driver kgdboc.
[ 1.268485] brd: module loaded
[ 1.278836] loop: module loaded
[ 1.284996] vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
[ 1.294730] vcos: [1]: vchiq_init_state: called
[ 1.302421] vcos: [1]: vchiq: initialised - version 2 (min 2), device 252.0
[ 1.312399] usbcore: registered new interface driver smsc95xx
[ 1.320408] cdc_ncm: 04-Aug-2011
[ 1.326025] usbcore: registered new interface driver cdc_ncm
[ 1.333970] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.547082] Core Release: 2.80a
[ 1.552503] Setting default values for core params
[ 1.559428] Finished setting default values for core params
[ 1.772327] Using Buffer DMA mode
[ 1.777735] Periodic Transfer Interrupt Enhancement - disabled
[ 1.785729] Multiprocessor Interrupt Enhancement - disabled
[ 1.793457] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.799936] Dedicated Tx FIFOs mode
[ 1.805817] dwc_otg: Microframe scheduler enabled
[ 1.805870] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.813194] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.822774] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.830467] Init: Port Power? op_state=1
[ 1.836582] Init: Power Port (0)
[ 1.842113] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.851103] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.860564] usb usb1: Product: DWC OTG Controller
[ 1.867519] usb usb1: Manufacturer: Linux 3.2.27+ dwc_otg_hcd
[ 1.875468] usb usb1: SerialNumber: bcm2708_usb
[ 1.883071] hub 1-0:1.0: USB hub found
[ 1.888974] hub 1-0:1.0: 1 port detected
[ 1.895744] dwc_otg: FIQ enabled
[ 1.895762] dwc_otg: NAK holdoff enabled
[ 1.895783] Module dwc_common_port init
[ 1.896129] usbcore: registered new interface driver uas
[ 1.903636] Initializing USB Mass Storage driver...
[ 1.910808] usbcore: registered new interface driver usb-storage
[ 1.918993] USB Mass Storage support registered.
[ 1.925974] usbcore: registered new interface driver libusual
[ 1.934293] mousedev: PS/2 mouse device common for all mice
[ 1.942902] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 1.948759] bcm2835-cpufreq: switching to governor powersave
[ 1.956589] bcm2835-cpufreq: switching to governor powersave
[ 1.964473] cpuidle: using governor ladder
[ 1.972646] cpuidle: using governor menu
[ 1.978599] sdhci: Secure Digital Host Controller Interface driver
[ 1.986802] sdhci: Copyright(c) Pierre Ossman
[ 1.993427] sdhci: Enable low-latency mode
[ 1.999491] bcm_power_open() -> 1
[ 2.005037] Registered led device: mmc0::
[ 2.006504] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.018436] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.026502] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.035719] Registered led device: led0
[ 2.036115] usbcore: registered new interface driver usbhid
[ 2.043904] usbhid: USB HID core driver
[ 2.051071] TCP cubic registered
[ 2.056577] Initializing XFRM netlink socket
[ 2.065203] NET: Registered protocol family 17
[ 2.075051] Registering the dns_resolver key type
[ 2.084159] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 2.098307] Indeed it is in host mode hprt0 = 00021501
[ 2.110932] registered taskstats version 1
[ 2.131391] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 2.151821] Waiting for root device /dev/mmcblk0p3...
[ 2.217840] mmc0: problem reading SD Status register.
[ 2.232613] mmc0: new high speed SDHC card at address b5f2
[ 2.241126] mmcblk0: mmc0:b5f2 SD08G 7.42 GiB
[ 2.249743] mmcblk0: p1 p3
[ 2.311310] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.320855] Indeed it is in host mode hprt0 = 00001101
[ 2.551519] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.560503] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.570856] hub 1-1:1.0: USB hub found
[ 2.577056] hub 1-1:1.0: 3 ports detected
[ 2.861371] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.971782] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.980987] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.993814] smsc95xx v1.0.4
[ 3.056576] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:9c:86:fb
[ 3.151426] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 3.273462] usb 1-1.2: New USB device found, idVendor=0a12, idProduct=0001
[ 3.282848] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.580929] EXT4-fs (mmcblk0p3): recovery complete
[ 3.598530] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 3.611628] VFS: Mounted root (ext4 filesystem) on device 179:3.
[ 3.623530] devtmpfs: mounted
[ 3.629963] Freeing init memory: 124K
[ 4.997910] udevd[138]: starting version 175
[ 5.908936] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100k)
[ 6.125077] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 6.193638] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100k)
[ 6.480981] Bluetooth: Core ver 2.16
[ 6.811878] NET: Registered protocol family 31
[ 6.818796] Bluetooth: HCI device and connection manager initialized
[ 7.063168] Bluetooth: HCI socket layer initialized
[ 7.070488] Bluetooth: L2CAP socket layer initialized
[ 7.172691] Bluetooth: SCO socket layer initialized
[ 7.180998] Bluetooth: Generic Bluetooth USB driver ver 0.6
[ 7.216449] usbcore: registered new interface driver btusb
[ 8.261259] Bluetooth: hci0 command tx timeout
[ 9.261262] Bluetooth: hci0 command tx timeout
[ 10.261264] Bluetooth: hci0 command tx timeout
[ 11.337727] EXT4-fs (mmcblk0p3): re-mounted. Opts: (null)
[ 11.895570] EXT4-fs (mmcblk0p3): re-mounted. Opts: errors=remount-ro
[ 12.830829] bcm2835 ALSA card created!
[ 12.844733] bcm2835 ALSA chip created!
[ 12.850936] bcm2835 ALSA chip created!
[ 12.869656] bcm2835 ALSA chip created!
[ 12.881577] bcm2835 ALSA chip created!
[ 12.887548] bcm2835 ALSA chip created!
[ 12.902461] bcm2835 ALSA chip created!
[ 12.911344] bcm2835 ALSA chip created!
[ 22.085765] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 29.579033] CIFS VFS: default security mechanism requested. The default security mechanism will be upgraded from ntlm to ntlmv2 in kernel release 3.3
[ 31.449051] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 37.337504] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 37.355202] Bluetooth: BNEP filters: protocol multicast
[ 37.421666] Bluetooth: RFCOMM TTY layer initialized
[ 37.429197] Bluetooth: RFCOMM socket layer initialized
[ 37.445683] Bluetooth: RFCOMM ver 1.11
[ 124.760116] input: 10:B7:F6:00:46:40 as /devices/virtual/input/input0
spiliot
Re: USB redux
Fri Jan 18, 2013 3:30 pm
I just submitted a pull request for a blind fix of the driver which in my case solved the problem of raspberry halting, explained a couple of messages before.
https://github.com/raspberrypi/linux/pull/195
I have no knowledge of how the USB driver works so this needs review cause it might have further implications that I'm unaware of.
I'm also including a compiled (3.6.11) kernel containing the fix, in case someone wants to try it without compiling. Download it from here http://ubuntuone.com/2LFgcHKL49ozryWB1gSSoq place it in /boot/ and load it from config.txt with kernel=kernel-3.6.11-usb-fix.img
castalla
Re: USB redux
Fri Jan 18, 2013 4:05 pm
Tried your fix - killed my distro!
probably my noobie skills!
spiliot
Re: USB redux
Fri Jan 18, 2013 4:37 pm
Although you don't explain what exactly "killed my distro" means, I guess it doesn't boot because it can't find the modules for the kernel where it expects them to be. Since adding a new kernel directive isn't destructive by any means, you should be able to revert the changes simply by deleting or commenting out the kernel=<whatever> command in config.txt. No need to reinstall anything.
To be able to use the "fixed" kernel you need to be on the latest kernel (3.6.11) and firmware, which should easily be done by updating your system with rpi-update (instructions are to be found in the forum). First rpi-update then change the kernel - as rpi-update will pull the 3.6.11+ modules the kernel needs.
My apologies for not mentioning this earlier.
castalla
Re: USB redux
Fri Jan 18, 2013 4:42 pm
yep - it won't boot .... so no way to edit the config.txt?
The kernel I had was from 13 jan 2013 - I've forgotten what version number was.
dom
Re: USB redux
Fri Jan 18, 2013 4:44 pm
castalla wrote:yep - it won't boot .... so no way to edit the config.txt?
Put the sdcard into a windows (or mac/linux) machine and edit config.txt with notepad.
castalla
Re: USB redux
Fri Jan 18, 2013 5:00 pm
Thanks! Learned something new!
Here's uname -a
Linux squeezeplug 3.6.11+ #358 PREEMPT Tue Jan 15 00:45:33 GMT 2013 armv6l GNU/Linux
castalla
Re: USB redux
Fri Jan 18, 2013 6:20 pm
Applied patched kernel - sadly doesn't fix my bluetooth problem.
Worth a try - thanks.
with ice cream
Re: USB redux
Sun Jan 27, 2013 7:22 am
Using 3.6.11+ #362 PREEMPT Tue Jan 22 14:52:21 GMT 2013 and my 320 x 240 LCD display still crashes when bigger chunks of data get pushed to it (eg. when loading the lcd4linux splash screen or bigger images). My 128 x 128 display woks.
The error message says "bulk write: Resource temporarily unavailable". I know I can avoid the splash screen by starting lcd4linux with the "-q" option but then the screen doesn't start with a black background and it looks ugly. Loading a black image as background layer causes a crash again (as may be expected). Crippling the bus to USB 1 speed also helps but then everything else (USB wifi, USB sound card, webcam) becomes unusable.
Is there any hope that this can be fixed or is it a hardware problem? I may have written this before but would disabling LAN free up resources?
obcd
Re: USB redux
Sun Jan 27, 2013 8:53 am
There was a description how to disable the lan in the motorola lapdock thread. Older kernels had a problem with a limited number of rotating endpoints. (Not sure if I have this term right), but on the more recent kernels this should be fixed. I don't think it will help much to disable the wired lan.
Is anybody following the development twitters about this?
Someone is fulltime working on the rewrite of the driver, but what's the status at the moment?
Is this the full rewrite on Arm that will later be impemented on the vector graphics processor?
Re: USB redux
Sun Jan 27, 2013 9:11 am
obcd wrote:There was a description how to disable the lan in the motorola lapdock thread. Older kernels had a problem with a limited number of rotating endpoints. (Not sure if I have this term right), but on the more recent kernels this should be fixed. I don't think it will help much to disable the wired lan.
It's not a rewrite of the whole driver- just moving some parts of it in to a FIQ. Not sure we will push anything on to the GPU at this stage.
obcd
Re: USB redux
Sun Jan 27, 2013 10:22 am
Moving some parts in to a FIQ will fix the "low speed usb device split transaction issues" as there is a better latency control.
How will it affect streaming usb devices like webcams and usb audio adapters?
Re: USB redux
Sun Jan 27, 2013 10:35 am
obcd wrote:Moving some parts in to a FIQ will fix the "low speed usb device split transaction issues" as there is a better latency control.
Gordon's the expert, but I believe that is a different problem. I guess he will get on to that once the FIQ stuff is done. Unless someone else comes in and helps too.
obcd
Re: USB redux
Sun Jan 27, 2013 11:02 am
In order to fix an issue, you need to know what's causing it.
I know the driver is open source, but it's giant and not very well documented.
So, supose someone is willing to help, what would be a start?
Is there an irc channel that can be used to exchange ideas about it?
I can understand Gordon isn't having time to explain in detail what he is doing so far, as most (likely including me) wouldn't understand the details.
I also know I can check github, but that is only showing finished work, nothing about the work in progress.
castalla
Re: USB redux
Sun Jan 27, 2013 11:34 am
As an ordinary noobie user, I'd just like some kind of announcement somewhere which tells us to do an rpi-update when something is fixed! Or am I missing something everybody knows about?
redhawk
Re: USB redux
Sun Jan 27, 2013 11:09 pm
I have a number of USB devices that are not working properly with Raspbian (just update/upgrade tonight).
My first problem device is a Bluetooth dongle from Poundland I can start the Pi with it already attached and even lsusb shows it's detected:
Bus 001 Device 004: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
but...
root@raspberrypi:~# hcitool scan
Device is not available: No such device
I have to physically remote the dongle from the USB port and reinsert it to get it working.
I'm not sure if this is a USB driver issue but it's really annoying nevertheless.
Is there a way to force a USB device to reset without physically moving it??
As for other devices I have a few webcams that still don't work well on the Pi:
- Creative notebook cam - PD1170
very dark images and corrupted jpgs
USB 1.1 only device
- Trust webcam "eMPIA Technology, Inc. M035 Compact Web Cam"
cannot capture 640x480 always corrupted images
capture at 352x288 usually error free.
device is USB 2.0, (will not work in USB 1.1 mode)
So far only my Logitech Pro 5000 seems to capture reliable 640x480 images however if I use a USB hub then I get occasional corruption.
My main post concerns another cam I'm having trouble with (original post) http://www.raspberrypi.org/phpBB3/viewt ... 63#p271263
It's a keychain video recorder / webcam also known as a "Camera 808 #3" based on the SPCA1527A/SPCA1528 chipset and fully compatible with Linux.
The first time I tried in the Pi it was working well then after further connections and reboots the device would never detect anymore.
If I connect and disconnect the USB leads several times then sometimes lsusb would show it's detected but after 2 seconds and I run lsusb again it's gone.
The voltage at the USB port is around 4.85v and should be plenty enough to power my webcam especially considering I have bridged the USB polyfuses.
The USB cable is about 40cm long and thus it shouldn't be suffering from any signal losses.
Using the same USB cable I have tested the webcam in my PC running in USB 2.0 and USB 1.1 mode without any issues.
To add to this mystery if I connect the webcam via a USB 1.1 hub (powered via Pi) then the webcam detects no problem however captures are only at USB 1.1 speeds.
I tried booting the Pi with the webcam plugged in and this is what dmseg looks like:
[ 3.833156] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 3.926934] udevd[137]: starting version 175
[ 4.115010] usb 1-1.3: New USB device found, idVendor=04fc, idProduct=0171
[ 4.142882] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.173951] usb 1-1.3: Product: General Image Devic
[ 4.182014] usb 1-1.3: Manufacturer: Sunplus Co Ltd
[ 4.222959] usb 1-1.3: SerialNumber: 01.00.00
[ 4.259660] scsi0 : usb-storage 1-1.3:1.0
[ 5.137773] usb 1-1.3: USB disconnect, device number 4
[ 5.393100] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 5.673432] usb 1-1.3: New USB device found, idVendor=04fc, idProduct=0171
[ 5.692926] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.712927] usb 1-1.3: Product: General Image Devic
[ 5.730793] usb 1-1.3: Manufacturer: Sunplus Co Ltd
[ 5.747192] usb 1-1.3: SerialNumber: 01.00.00
[ 5.768864] scsi1 : usb-storage 1-1.3:1.0
[ 6.417943] usb 1-1.3: USB disconnect, device number 5
[ 6.673137] usb 1-1.3: new high-speed USB device number 6 using dwc_otg
[ 6.953360] usb 1-1.3: New USB device found, idVendor=04fc, idProduct=0171
[ 6.977773] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.992905] usb 1-1.3: Product: General Image Devic
[ 7.000751] usb 1-1.3: Manufacturer: Sunplus Co Ltd
[ 7.028107] usb 1-1.3: SerialNumber: 01.00.00
[ 7.051820] usb 1-1.3: can't set config #1, error -71
[ 7.186026] usb 1-1.3: USB disconnect, device number 6
[ 7.442951] usb 1-1.3: new high-speed USB device number 7 using dwc_otg
[ 7.703087] usb 1-1.3: New USB device found, idVendor=04fc, idProduct=0171
[ 7.714893] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7.725286] usb 1-1.3: Product: General Image Devic
[ 7.733208] usb 1-1.3: Manufacturer: Sunplus Co Ltd
[ 7.741041] usb 1-1.3: SerialNumber: 01.00.00
[ 7.753149] usb 1-1.3: can't set config #1, error -71
[ 7.773506] usb 1-1.3: USB disconnect, device number 7
[ 8.023032] usb 1-1.3: new high-speed USB device number 8 using dwc_otg
[ 8.254917] usb 1-1.3: New USB device found, idVendor=04fc, idProduct=0171
[ 8.272094] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.312871] usb 1-1.3: can't set config #1, error -71
[ 8.466060] usb 1-1.3: USB disconnect, device number 8
[ 8.723135] usb 1-1.3: new high-speed USB device number 9 using dwc_otg
[ 9.293083] usb 1-1.3: new high-speed USB device number 10 using dwc_otg
[ 9.573113] usb 1-1.3: new high-speed USB device number 11 using dwc_otg
[ 10.233088] usb 1-1.3: new high-speed USB device number 12 using dwc_otg
[ 10.753031] usb 1-1.3: new high-speed USB device number 13 using dwc_otg
[ 11.512957] usb 1-1.3: new high-speed USB device number 14 using dwc_otg
[ 12.033055] usb 1-1.3: new high-speed USB device number 15 using dwc_otg
[ 12.793027] usb 1-1.3: new high-speed USB device number 16 using dwc_otg
[ 13.562952] usb 1-1.3: new high-speed USB device number 17 using dwc_otg
[ 14.332911] usb 1-1.3: new high-speed USB device number 18 using dwc_otg
[ 14.361555] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 14.843137] usb 1-1.3: new high-speed USB device number 19 using dwc_otg
[ 15.300188] bcm2835 ALSA card created!
[ 15.314486] bcm2835 ALSA chip created!
[ 15.320825] bcm2835 ALSA chip created!
[ 15.343101] bcm2835 ALSA chip created!
[ 15.349335] bcm2835 ALSA chip created!
[ 15.363898] bcm2835 ALSA chip created!
[ 15.369964] bcm2835 ALSA chip created!
[ 15.389375] bcm2835 ALSA chip created!
[ 15.613314] usb 1-1.3: new high-speed USB device number 20 using dwc_otg
[ 16.123174] usb 1-1.3: new high-speed USB device number 21 using dwc_otg
[ 16.433094] usb 1-1.3: new high-speed USB device number 22 using dwc_otg
[ 16.773125] usb 1-1.3: new high-speed USB device number 23 using dwc_otg
[ 17.663114] usb 1-1.3: new high-speed USB device number 24 using dwc_otg
[ 17.943146] usb 1-1.3: new high-speed USB device number 25 using dwc_otg
[ 18.253188] usb 1-1.3: new high-speed USB device number 26 using dwc_otg
[ 18.753125] usb 1-1.3: new high-speed USB device number 27 using dwc_otg
[ 19.063160] usb 1-1.3: new high-speed USB device number 28 using dwc_otg
[ 19.712960] usb 1-1.3: new high-speed USB device number 29 using dwc_otg
[ 20.223179] usb 1-1.3: new high-speed USB device number 30 using dwc_otg
[ 20.993034] usb 1-1.3: new high-speed USB device number 31 using dwc_otg
[ 21.267420] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 21.278496] mmc0: DMA IRQ 6 ignored - results were reset
[ 21.763114] usb 1-1.3: new high-speed USB device number 32 using dwc_otg
[ 22.273178] usb 1-1.3: new high-speed USB device number 33 using dwc_otg
[ 23.043030] usb 1-1.3: new high-speed USB device number 34 using dwc_otg
[ 23.803135] usb 1-1.3: new high-speed USB device number 35 using dwc_otg
[ 24.573108] usb 1-1.3: new high-speed USB device number 36 using dwc_otg
[ 24.799252] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 25.083028] usb 1-1.3: new high-speed USB device number 37 using dwc_otg
[ 25.853131] usb 1-1.3: new high-speed USB device number 38 using dwc_otg
[ 26.363055] usb 1-1.3: new high-speed USB device number 39 using dwc_otg
[ 27.133014] usb 1-1.3: new high-speed USB device number 40 using dwc_otg
[ 27.902981] usb 1-1.3: new high-speed USB device number 41 using dwc_otg
[ 28.413070] usb 1-1.3: new high-speed USB device number 42 using dwc_otg
[ 29.183019] usb 1-1.3: new high-speed USB device number 43 using dwc_otg
[ 29.953117] usb 1-1.3: new high-speed USB device number 44 using dwc_otg
[ 30.213172] usb 1-1.3: new high-speed USB device number 45 using dwc_otg
Any idea why the Pi is having trouble identify my webcam??
Btw: I also tried adding dwc_otg.speed=1 to my boot options but it didn't help and in fact made it impossible to capture any images with my Logitech Pro 5000 webcam nor the camera 808 #3.
Any other suggestions to try out??
Richard S.
