georgekok97
Unable to enumerate USB on port X
Thu Nov 22, 2012 3:49 pm
hi..!
i have a RT5370 chipset wifi and when i plug it in it shows me nothing....
it can't be found on command lsusb and on command dmesg shows "Unable to enumerate USB on port 2" ..
How can i solve it ?? thanks
gsh
Re: Unable to enumerate USB on port X
Thu Nov 22, 2012 6:58 pm
If it cannot even enumerate then it must either be faulty hardware or a power issue...
Do you have an older version of the board or the new 512M version?
Have you tried using a powered hub?
Does your network interface work correctly?
Gordon Hollingworth PhD
georgekok97
Fri Nov 23, 2012 11:54 am
i have the 256mb rev.1 and i havent now a powered hub....
my internet connection stops for 1(or less) seconds and then is back .....
RaTTuS
Fri Nov 23, 2012 12:19 pm
you are going to need a powered hub for any wireless adapter [IME]
the basic RPi will not be able to provide enough power .
Covfefe
georgekok97
Fri Nov 23, 2012 12:26 pm
a cheap hub ???
the cheapest i can find is this https://www.modmypi.com/shop/raspberry- ... s-Adaptor)
