Bill_J
Another question about RPi and the DHT11
Fri Feb 15, 2019 11:47 pm
HI. I have a DHT11 working okay to a 16x2 display and the python script includes the math to get °F. Update speed is not an issue. A DHT22 has been purchased and will arrive in a few days.
My temperature was set at 99.6° with a circuit unrelated to the RPI and DHT11. Built around an LM34 I can set the temp fairly accurately but the circulation of the air is slow relatively speaking in system response time.
The DHT11 is mounted above the center of a lazy susan very slowly rolling eggs. The DHT11 was reading 98.6°F constantly at 3.3v. I thought perhaps it wouldn't read higher. I switched the DHT11 to 5v. No change in the temperature reading. I adjusted my Set to 100.0°F. Due to the slow air rotation there's a temperature overshoot even with almost no hysteresis. So, my reading from the LM34 show the circulating temperature to reach 100.4° and lo and behold the DHT11 sees 100.4° briefly then back to 98.6°.
Took a while to figure out but that jump from 98.6° to 100.4° is 1°C. I had thought the accuracy might be +/-1°C but not its output no finer than 1°C. That jump is rather large. I tried adjusting in the .py script to :0.05f from :0.1F but all that got me was 98.60000*F.
Is this 1°C set immutably in the module? It seems a rather gross jump in °F.
Thanks for reading.
Bill_J
danjperron
Re: Another question about RPi and the DHT11
Sat Feb 16, 2019 12:08 am
DHT11 is +/- 2 Celsius.
You should have used another type of sensor for that purpose. At least the DS18B20 will have more resolution.
Bill_J
Sat Feb 16, 2019 12:30 am
Wow. Nice device. Wish I had known. Will possibly use it next time I run the incubator, 5 years from now or so.
Bill_J
Sat Feb 16, 2019 12:57 am
I don't suppose the DS18B20 can be swapped in for the DHT11 and respond to the script if the proper module is loaded?
Oh, that's right, the DS18B20 doesn't have humidity.
Sat Feb 16, 2019 6:51 am
Maybe use something like a BME280 which is an i2c pressure, temperature and humidity sensor?
Signature is on holiday.
