steffo
Connection refused after reboot
Tue Feb 12, 2019 4:41 pm
I am running a RPi and booting from an SSD.
Everytime i ask it to reboot from command prompt is says "connection refused" when i try to reconnect.
I need to disconnect to power to be able to connect.
It feels like the same problem I hade with a HDD that did not spin up..
any suggestions?
epoch1970
Re: Connection refused after reboot
Tue Feb 12, 2019 10:00 pm
SSH will say that when the server is indeed dead. It failed or it wasn't started (boot failed?)
Do any other service work?
Can you hook a monitor, and see what goes on?
Andyroo
Tue Feb 12, 2019 10:39 pm
You could try
ssh -v <ipaddress>
to get more info out of ssh
Need Pi spray - these things are breeding in my house...
