RobEisenrich
sudo apt get install mdadm -y fails
Mon Feb 11, 2019 3:59 pm
New to raspberry pi. I am trying to set up a raid using the following tutorial "https://pchelp.ricmedia.com/build-raspb ... -server/2/". I am stuck on the steps to run
sudo apt-get update
sudo apt-get upgrade -y
sudo apt-get install mdadm -y
As I receive errors for "sudo apt-get upgrade -y" and "sudo apt-get install mdadm -y". The error messages I get for both are
Reading package lists...Done
reading state information...Done
you might want to run 'apt--fix-broken install' to correct these.
The following packages have unmet dependencies:
apt-utils : Depends: apt (=1.4.8) but 1.4.9 is to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution)
How do I run 'apt--fix broken install' or roll back apt-utils from 1.4.9 to 1.4.8 ?
Thanks!
DirkS
Re: sudo apt get install mdadm -y fails
Mon Feb 11, 2019 8:00 pm
what about
sudo apt --fix-broken install
as it says in the error msg?
RobEisenrich
Mon Feb 11, 2019 8:16 pm
I have tried this but I get the error message back that it does not recognize the command. Was not sure if there was anything I need to add to the command
DirkS
Mon Feb 11, 2019 8:19 pm
Did you see that the command you wrote at the end of your post is *not* the same as in the error msg?
Try copy/paste of the command I posted and post (also copy/paste) any *full* error msgs. Use code tags when you do that.
RobEisenrich
Mon Feb 11, 2019 10:05 pm
Worked like charm!
Thank you sir
