Gachto
RPI can't access internet
Sat Feb 09, 2019 12:49 pm
I am a beginner with RPi 3 and recently I discovered that i can't access to the internet (curl, apt-get update doesn't work) could you help me out with this issue ? I use a router to connect (with ethernet cables) my raspberry and my laptop (using Linux with an USB stick Ubuntu 18.04)
Here some informations :
ping -c3 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 0 received, 100% packet loss, time 2005ms
ping google.com
ping: unknown host google.com
my router local adress :
ping 192.168.0.1
PING 192.168.0.1 (192.168.0.1) 56(84) bytes of data.
64 bytes from 192.168.0.1: icmp_seq=1 ttl=64 time=14.6 ms
64 bytes from 192.168.0.1: icmp_seq=2 ttl=64 time=0.814 ms
64 bytes from 192.168.0.1: icmp_seq=3 ttl=64 time=0.673 ms
64 bytes from 192.168.0.1: icmp_seq=4 ttl=64 time=0.681 ms
^C
--- 192.168.0.1 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3005ms
rtt min/avg/max/mdev = 0.673/4.196/14.619/6.018 ms
my laptop local adress :
ping 192.168.18
PING 192.168.18 (192.168.0.18) 56(84) bytes of data.
64 bytes from 192.168.0.18: icmp_seq=1 ttl=64 time=0.575 ms
64 bytes from 192.168.0.18: icmp_seq=2 ttl=64 time=0.580 ms
64 bytes from 192.168.0.18: icmp_seq=3 ttl=64 time=0.579 ms
64 bytes from 192.168.0.18: icmp_seq=4 ttl=64 time=0.488 ms
64 bytes from 192.168.0.18: icmp_seq=5 ttl=64 time=0.588 ms
cat /etc/resolv.conf
# Generated by resolvconf
nameserver 192.168.0.1
about this one, i tried to add nameserver 8.8.8.8 manually but it keeps on getting back to this original code
cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
cat /etc/hosts
127.0.0.1	localhost
::1		localhost ip6-localhost ip6-loopback
ff02::1		ip6-allnodes
ff02::2		ip6-allrouters
127.0.1.1	myPi
cat /etc/wpa_supplicant/wpa_supplicant.conf
country=GB
update_config=1
network={
    ssid="mySSID"
    psk="myPSWD"
Thank you for reading me
P.S. : Sorry for any mistakes, English it's not my first language
rpdom
Re: RPI can't access internet
Sat Feb 09, 2019 1:06 pm
Ok, so your local network connection to the router is working.
But you can't connect to external systems (ping 8.8.8.8 failed).
This suggests that it is a routing issue - your Pi doesn't know that it needs to go via your router to get to external systems or the router is refusing to route data.
This is unusual, because normally the router will tell the Pi which gateway to use when it issues the IP address.
Can you show us the output of ip route?
Don't worry about the nameserver for now. It is common for routers to act as a nameserver for the local network and forward on any requests they can't handle themselves.
Signature is on holiday.
Gachto
Sat Feb 09, 2019 3:50 pm
Thank you for your answer!
Here for the ip route:
ip route
default via 192.168.0.1 dev eth0  metric 202
192.168.0.0/24 dev eth0  proto kernel  scope link  src 192.168.0.17  metric 202
rpdom
Sat Feb 09, 2019 4:20 pm
That looks like the settings on your Pi are correct too. It seems your router isn't allowing internet access from the Pi for some reason.
Gachto
Sun Feb 10, 2019 9:21 am
Ok thank you,
I will try to change the router and see how it goes!
pcmanbob
Sun Feb 10, 2019 11:23 am
before doing that try powering every thing off , the pi and the router and any PC's , leave everything off for a minute or so then power the router allow it to complete its start up cycle and only then power the pi and any PC's.
you may find every thing will work correctly after doing this.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
Gachto
Wed Feb 13, 2019 3:19 pm
Ok, i finally had internet !
The issue was indeed the router; it doesn't allow the internet connexion.... In order to have internet connexion without it I just used a Wifi dongle and my PC and the pi are directly connected.
Thank you again!
