taylorkh
Any reason why a Pi 3 will not run from a 64 GB card?
Sat Jan 19, 2019 12:24 am
I am running several Pi's from 16 GB MicroSD cards. I am trying to set one up with a 64 GB card so I can include my mp3 collection on the card. I have tried cloning a working Ubuntu installation from a 16 GB card by a number of methods which I have used successfully to clone cards. I am finding a lot of corruption on the 64 GB card. I have even started over with the Ubuntu Mate 16.04 image which I transferred to the 64 GB card with dd. It booted and resized then rebooted. I entered the information to complete the installation. Upon reboot it did an fsck, fixed a bunch of stuff, rebooted, did another fsck, fixed some more stuff and then came up to the logon window with no USB connectivity to the mouse and keyboard.
I think the card is defective. I can create a partition, create a file system on it and then fsck will find a LOT of errors. I have been on chat with Sandisk for about 40 minutes so far. They have no clue.
If in fact I should be able to use a 64 GB card I think I will just try another one.
TIA,
Ken
mikronauts
Re: Any reason why a Pi 3 will not run from a 64 GB card?
Sat Jan 19, 2019 1:29 am
See if you can store 64Gb of data on it on a pc (formatted on a pc)
As you say, it could be a defective card, or possibly a counterfeit card that has no where near 64Gb
TIA,
Ken
http://Mikronauts.com - home of EZasPi, RoboPi, Pi Rtc Dio and Pi Jumper @Mikronauts on Twitter
Advanced Robotics, I/O expansion and prototyping boards for the Raspberry Pi
taylorkh
Sat Jan 19, 2019 2:14 am
Thanks mikronauts,
As I posted, the card reports errors unrelated to its use in the Pi. As long as a Pi will work with a 64 GB card I will try another. I am hoping someone can provide some experience good or bad.
Ken
W. H. Heydt
Sat Jan 19, 2019 2:27 am
Thanks mikronauts,
Yes. Pis will work with 64GB cards. I have two that way at the moment. A Pi2Bv1.1 and a Pi3A+.
HawaiianPi
Sat Jan 19, 2019 3:28 am
The Pi supports the SDXC standard, which is cards up to 2TB (although none that large exist yet). I have tested my Pi with cards up to 128GB and it worked fine. The main issue people run into with cards larger than 32GB is with NOOBS installation, but you are using Ubuntu images, so that's not your problem.
If it's a popular brand card (especially SanDisk or Samsung), then it could be a fake (lots of counterfeits out there). There are some programs that test the integrity of flash storage media. For Windows there is h2testw and for Linux there is F3 (Fight Fake Flash), which I have heard can be built from source on Mac OS.
It also could be your card reader. I had one that seemed to work perfectly when reading/writing files (never had a problem), but it frequently failed to verify when writing images with Etcher. I tossed that one in the recycle bin and use a different card reader now.
Oh, and one more thing. If you have a new 3B+ model, the Ubuntu Mate 16.04 image is not compatible. The 3B+ model needs new firmware and a new kernel, and that Ubuntu image is too old. I believe there is an Ubuntu 18 image that is 3B+ compatible now (and of course, the latest Raspbian is compatible with all Raspberry Pi models).
jahboater
Sat Jan 19, 2019 7:55 am
Yes, the Pi works fine on larger cards (the ext4 file system it uses supports any disk size for the foreseeable future).
I use 64GB and 128GB cards all the time, now the price has dropped.
The sandisk A2 class cards are available up to 400GB, I am contemplating getting one for my media collection, I have no doubt it will work fine on any Pi.
k-pi
Sat Jan 19, 2019 10:59 am
My RPi3B & RPi3B+ work with 16/32/64GB SDHC/SDXC microSD cards, no problems for me. 8-)
taylorkh
Sat Jan 19, 2019 11:24 am
Thank you to all for your replies. I will try another 64 GB card. I will also try one of the fake card detector programs. I had read about the issue with USB "thumb" drives which would appear to be some number of GB but would only hold a small amount of that data. I did format the thing as FAT and copied 50+ GB of data to it. I have not check the card yet. I will do that this morning.
Thanks again,
Ken
p.s. This may be a self inflicted problem. I am breaking my long standing (since my Osborne computer in 1982) rule of ALWAYS separating the operating system from the data :oops: On the other hand this application is more like an appliance than a general purpose computer.
DarkPlatinum
Contact: Website YouTube
Sat Jan 19, 2019 11:30 am
Reasons why it may not work:
1. The SD card is fake
2. It is formatted as ExFAT, needs to be formatted as FAT32
3. Your Raspberry Pi may have an issue with reading SD cards
4. For best results use Etcher
5. Try a different operating system such as NOOBS
6. The Raspbian Download might be corrupted
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): https://html.dynu.net
Sat Jan 19, 2019 11:34 am
5) NoobS, like PiNN, is an installer /chooser not an Operating System.
Retired disgracefully.....
darkbibble
Sat Jan 19, 2019 12:10 pm
i had the same issue recently, sd copier and other cloneing methods failed, i ended up writing a freshly downloaded clean image of raspbian and wrote it to the card and reinstalled from that
Q; How many Windows users does it take to fix a Linux problem??
A; Whats a Linux problem
HawaiianPi
Sat Jan 19, 2019 12:25 pm
Only relevant for NOOBS install (OP is using Ubuntu image). Writing images works regardless of any previous format (the image contains the filesystem).
Botspot
Sat Jan 19, 2019 3:56 pm
I've ran my Raspberry Pi 3 on a genuine Sandisk 64GB card for a year now.
It has never corrupted on me.
I bought it from Walmart to avoid any possible counterfeit.
https://www.walmart.com/ip/SanDisk-64GB ... r/55141020
My doctor told me my brain is as useful as a Raspberry Pi. Is that a compliment?
jahboater
Sat Jan 19, 2019 4:09 pm
Yes, I have never had any problems with any Sandisk or Samsung cards.
The A1 or A2 app class are designed for the fast random 4k reads - ideal for the Pi. Older cards were designed for cameras and media where fast sequential performance is required.
These have just appeared on the market (the extreme plus):-
https://www.amazon.co.uk/SanDisk-Extrem ... isk+a2+app
Just ordered a 128GB one ....
DarkPlatinum
Sat Jan 19, 2019 8:06 pm
I see. Did not know this.
taylorkh
Wed Jan 23, 2019 12:12 am
I just obtained a replacement 64 GB replacement card. It works fine.
Ken
