frozenboy11
No wifi Interface Found
Fri Jan 18, 2019 10:08 am
HI i am using raspberry Pi Zero w camera, i am unable to connect to wifi for some reason, thanks in advance^_^
when i run
sudo nano /etc/network/interfaces
 #interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
allow-hotplug wlan1
when i run
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
country=SG
update config=1
network={
        ssid="_____________"
        psk="_____________"
        key_mgmt=WPA-PSK
drgeoff
Re: No wifi Interface Found
Fri Jan 18, 2019 10:59 am
Are you sure you have a ZeroW and not a Zero? Click on the pictures at https://www.raspberrypi.org/products/ and check against your RPi.
frozenboy11
Fri Jan 18, 2019 1:17 pm
opps its raspberry pi zero W
frozenboy11
Sat Jan 19, 2019 6:48 pm
In additional, when i run
pi@raspberrypi:~ $ sudo iwlist wlan0 scan
Scan completed :
          Cell 01 - Address: F4:17:B8:01:5F:1E
                    Channel:1
                    Frequency:2.412 GHz (Channel 1)
                    Quality=47/70  Signal level=-63 dBm
                    Encryption key:on
                    ESSID:"AirTies4920_9SK3"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
                              24 Mb/s; 36 Mb/s; 54 Mb/s
                    Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
                    Mode:Master
                    Extra:tsf=0000000000000000
                    Extra: Last beacon: 60ms ago
                    IE: Unknown: 001041697254696573343932305F39534B33
                    IE: Unknown: 010882848B962430486C
                    IE: Unknown: 030101
                    IE: Unknown: 050400010000
                    IE: Unknown: 0706534720010D16
                    IE: Unknown: 2A0100
                    IE: Unknown: 2F0100
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                        Authentication Suites (1) : PSK
                    IE: Unknown: 32040C121860
                    IE: Unknown: 2D1ABC1917FFFF000000000000000000000000000000000000000000
                    IE: Unknown: 3D1601080000000000000000000000000000000000000000
                    IE: Unknown: 4A0E14000A002C01C800140005001900
                    IE: Unknown: 7F080500000000000040
                    IE: Unknown: DD570050F204104A00011010440001021047001013DBFF01B0847EDA3FA8363CA9BE3439103C0001011049000600372A00012010490022007FC5100018665618569F33DE5A4A2717D843DC2567303030303030303130000101
                    IE: Unknown: DD090010180200000C0000
                    IE: Unknown: DD180050F2020101040003A4000027A4000042435E0062322F00
                    IE: Unknown: 46057208010000
          Cell 02 - Address: 00:26:75:87:DB:AC
                    Channel:3
                    Frequency:2.422 GHz (Channel 3)
                    Quality=48/70  Signal level=-62 dBm
                    Encryption key:on
                    ESSID:"WK Personal Wifi "
                    Mode:Master
                    IE: Unknown: 0011574B20506572736F6E616C205769666920
                    IE: Unknown: 030103
                    IE: Unknown: 2A0100
                    IE: Unknown: 2F0100
                        Group Cipher : TKIP
                        Pairwise Ciphers (2) : CCMP TKIP
                    IE: Unknown: 0B0501001F0000
                    IE: Unknown: 2D1A3C181BFFFF000000000000000000000000000000000000000000
                    IE: Unknown: 3D1603001500000000000000000000000000000000000000
                    IE: Unknown: 7F03000008
                    IE: Unknown: DD800050F204104A0001101044000102103B00010310470010E64259BD30D2128EE6664C84C212D64C1021000842726F6164636F6D1023000842726F6164636F6D1024000631323334353610420004313233341054000800060050F20400011011000A42726F6164636F6D415010080002200C103C0001011049000600372A000120
                    IE: Unknown: DD090010180201000C0000
                    IE: WPA Version 1
                        Group Cipher : TKIP
                    IE: Unknown: DD180050F2020101800003A4000027A4000042435E0062322F00
          Cell 03 - Address: E0:8E:3C:20:5F:81
                    Channel:3
                    Quality=31/70  Signal level=-79 dBm
                    Encryption key:on
                    ESSID:"SINGTEL-5F80"
                    Mode:Master
                    IE: Unknown: 000C53494E4754454C2D35463830
                    IE: Unknown: 030103
                    IE: Unknown: 050400010020
                    IE: Unknown: 2A0104
                    IE: Unknown: 2F0104
                        Group Cipher : TKIP
                    IE: Unknown: 0B050400DA0000
                    IE: Unknown: 3D1603000400000000000000000000000000000000000000
                    IE: Unknown: DD180050F204104A00011010440001021049000600372A000120
                    IE: Unknown: DD090010180204000C0000
                    IE: WPA Version 1
                        Group Cipher : TKIP
No Wireless interface.png (119.45 KiB) Viewed 131417 times
frozenboy11
Mon Jan 21, 2019 8:31 pm
Hello all this is important to me, any help is appreciated :)
ShiftPlusOne
Tue Jan 22, 2019 8:32 am
The desktop applet is designed to use dhcpcd. You're using ifupdown.
Tue Jan 22, 2019 2:07 pm
Are you using the default "pi" user? If not, did you add the new user to the same groups as "pi". I believe the netdev group is essential for the network config to work.
frozenboy11
Wed Jan 23, 2019 6:12 am
what do u mean? hmm..?
frozenboy11
Wed Jan 23, 2019 6:13 am
hi there, i am using the default "pi" user, this is the first time i encounter this problem.
ShiftPlusOne
Wed Jan 23, 2019 9:08 am
The /etc/network/interfaces file you're using is not what we ship by default. I don't know if it's the cause of your problem, but at the very least it makes me suspicious.
Here's what it's meant to look like:
# interfaces(5) file used by ifup(8) and ifdown(8)
Yours contains lines which start wpa_supplicant, which is normally the job of dhcpcd (the network manager we actually use). Given that you have those changes there, I suspect there could also be other changes. It would be good to check the latest, clean, unmodified stretch image and see if you still get the same problem. It should just work out of the box.
RaTTuS
Mon Mar 18, 2019 9:42 am
I's start a new thread and stop shouting.
but also I'd try with a new stretch image
don't bother upgrading jessie
see if a fresh image works first
Covfefe
