jultur
Raspbian stuck on screen with cursor+black screen+yellow lightning during boot
Sun Jan 13, 2019 2:45 pm
I have an issue with my raspberry pi 3 B+ running on Raspbian. Indeed just after trying to set up a 4 inch HDMI LCD screen in the following way :
-Adding these lines in the config.txt
Hdmi_group = 2
Hdmi_mode = 87
Hdmi_cvt 480 800 60 6 0 0 0
Dtoverlay = ads7846 , cs = 1 , penirq = 25 , penirq_pull = 2 , speed = 50000 , keep_vref_on = 0 , swapxy = 0 , pmax = 255 , xohms = 150 , xmin = 200 , xmax = 3900 , ymin = 200 , ymax = 3900
Display_rotate = 3
-git clone https : //github.com/waveshare/LCD-show.git
-and running the file LCD4 - 800x480 - show
At this point the board reboot and since then my problems started :
The boot start correctly until the last line on screen :
Starting Terminate Plymouth Boot Screnn...
After that I'm stuck with that screen :
And the red and green LEDs are blinking.
It's a problem really simillar to this one :
viewtopic.php?t=128307
But no answers are working for me.
Personnaly I think it's a problem with the memory during the installation of the LCD driver but I have no idea how to solve it. I really need to get it working without wiping all the memory, beacause I have really important files for a project inside.
Thank you for the help!
Re: Raspbian stuck on screen with cursor+black screen+yellow lightning during boot
Sun Jan 13, 2019 4:25 pm
Hdmi_group = 2
Hdmi_mode = 87
Display_rotate = 3
The Yellow Warning is under-voltage:
https://www.raspberrypi.org/documentati ... g-icons.md
Use the Official and recommended Power Supply:
https://www.raspberrypi.org/products/ra ... er-supply/
The Waveshare instructions support Raspbian Stretch ?? if it is a genuine Waveshare product then what model ??
https://www.waveshare.com/product/mini- ... splays.htm
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
jultur
Sun Jan 13, 2019 6:22 pm
Thanks for the answer !
I have also read that this lightning logo can appear due to boot problems. The board is powered by my PC and I used the same configuration with an other board and it was working, that why i'm not sure if it's a supply problem.
And for the screen I'm using this one :
https://www.waveshare.com/product/mini- ... mi-lcd.htm
davidcoton
Sun Jan 13, 2019 9:40 pm
Your PC's USB may be limited to 500mA. The Pi3B+ can draw over twice that.
Get a proper 5V-5V2 2A5 PSU (not a repurposed charger), preferably the "official" 5V1 2A5 PSU which is known to be of good quality.
Make sure the cable, if separate, is adequate -- at least 22AWG and preferanbly 18AWG wires (smaller number is thicker).
Signature retired
