tadryanom
Over voltage on my RPi
Fri Jan 11, 2019 2:11 pm
Hello everyone!
I was using my Rpi 3 when some strange defect appeared in the power supply causing the power input components to burn. I would like to know if it is still possible to use my RPi 3 by removing the damaged components and powering via 5V GPIO pins?
Follow the beautiful photos of a mess.
Tulio Adriano Muniz
pcmanbob
Re: Over voltage on my RPi
Fri Jan 11, 2019 4:33 pm
It looks to me like you have destroyed the chip that converts the 5v in to 3.3v required to run your pi, with this chip destroyed your pi will not work , nor will it work with it removed.
You may also have damaged other parts of the pi so your best option is to replace it and the faulty power supply.
