cjan
[fixed ?]strange issue - libappindicator3 missing?
Mon Jan 07, 2019 5:09 am
just fresh install from last raspbian img.
but, it ask libappindicator3, which program needed it?
why does it not pre-installed?
ShiftPlusOne
Re: strange issue
Mon Jan 07, 2019 6:59 am
cjan wrote:it ask libappindicator3
What's asking for libappindicator3? Where do you see that?
cjan
Re: strange issue
Mon Jan 07, 2019 7:29 am
no idea, jump up screen with square picture format warning.
PhatFil
Re: strange issue
Mon Jan 07, 2019 10:52 am
try re-downloading the image file and use etcher to write the sd card directly from the zip file.
cjan
Re: strange issue
Mon Jan 14, 2019 3:55 am
its gcin dependency, but not installed when install.
Re: [fixed ?]strange issue - libappindicator3 missing?
Mon Jan 14, 2019 9:50 am
Can you erxplain more fully how you got the error - steps to reproduce, and more detailed description of the error you are seeing.
cjan
Mon Jan 14, 2019 11:58 am
more detail? beyond my english skill.
or, you can install gcin yourself.
ShiftPlusOne
Mon Jan 14, 2019 12:45 pm
Yup, that's enough to reproduce the issue, thanks. I'll add it to the list of things to take a look at.
ShiftPlusOne
Fri Jan 18, 2019 4:37 pm
Looks like the issue is present in Debian as well, so it's just something we've inherited.
You can work around it by installing libappindicator3-1
I tried to look a bit further into why it hadn't been fixed and whether it's a known issue but all the results I am seeing are in Chinese.
cjan
Sat Jan 26, 2019 3:47 am
another one,
when gcin enabled, then all panel's addon icons shift to right corner then disappear, e.g. date/time.
cjan
Tue Jun 25, 2019 1:36 pm
guess what, IT come back again in Buster.
ShiftPlusOne
Wed Jun 26, 2019 3:04 pm
IMHO, the package should be removed from the repo entirely, given how buggy and unmaintained it is. I'd recommend raising the issue with Debian, since it's not something we provide or support.
