Faruk
Rasbberry pi hang on reboot
Sat Jan 05, 2019 11:11 am
Hello guys. When I reboot my raspberry pi, sometimes my raspberry pi hang. And screen this:
[ OK ] Stopped Login Service.
[ OK ] Started Show Plymouth Reboot Screen.
[ OK ] Stopped Permit User Session.
[ OK ] Deactivated swap /var/swap.
[ OK ] Stopped LSB: Autogenerate and use a swap file.
[ OK ] Stopped target Remote File Systems.
[ OK ] Stopped target Remote File Systems (Pre).
[ OK ] Stopped target NFS client services.
What is wrong in here? How fix this error?
vinaypundith
Location: Lexington Park, MD, USA, North America, Earth
Re: Rasbberry pi hang on reboot
Mon Jan 07, 2019 12:25 pm
Please give more detail, like what had been done just before shutdown.
I'm setting up a webpage and email server on a Pi 3B+ running Ubuntu Mate 18.10.
Please read the Unanswered topics section and help with whatever you can!
Faruk
Tue Jan 08, 2019 5:58 am
I tried again now. ı started raspberry pi. Usb flash, wireless dongle and keyboard dongle attached to my Rpi. Also I used vnc server and kitty. Kitty connected with ssh to my Rpi. Usually I use vnc server. I used python idle 3, I did some try codes run. When I saw your post, I tried again and Raspberry show to me this:
 [ OK ] Started Show Plymouth Power Off Screen
Just I did these.
vinaypundith
Tue Jan 08, 2019 10:26 am
That seems normal. Try booting it now. Does it hang on every reboot or just sometimes?
HawaiianPi
Tue Jan 08, 2019 10:37 am
Which model Pi?
What operating system (and version)?
What are you using for a power supply?
Are you booting from SD card or USB?
Faruk
Tue Jan 08, 2019 11:09 am
Just sometimes
Faruk
Tue Jan 08, 2019 11:30 am
Which model Pi?
rpi compute module 3 2015 version 1.0
Operating system is stretch version 4.14.90-v7+
Power supply is 5V 1,5A
I booting from SD card
HawaiianPi
Tue Jan 08, 2019 1:40 pm
1.5A could be a bit low, depending on what else you have attached to the CM3.
Run the system for a while, then before rebooting try the command:
vcgencmd get_throttled
If you get a non-zero result, post it here.
Have you run sudo rpi-update on the system? Because that installs the possibly buggy and unstable testing branch kernel and firmware.
dominic03
Tue Jan 08, 2019 1:53 pm
Which model Pi?
Power supply should be 5V 2.5A for best results. Try running a cpu-itensive app and see if it gives an undervoltage warning. (Get your CPU to 100%. Even if it seems ok at a moderate level, 100% will often kill it if it is undervolted.)
Raspberry Pi 4B running Raspbian Buster v3.1 (via PINN)
Kingston 32 GB C10 (U1) microSD
Sceptre E225W 22" 75hz 1080p monitor
Flash drive for backups and swap
-or-
pi-top 3 running Raspbian with drivers and pi-topHUB 2.0 / 16GB SanDisk C10 microSD
Faruk
Tue Jan 08, 2019 2:19 pm
result is 0x0. Yes I did rpi-update. Can I fix this or should I use new system?
Tue Jan 08, 2019 2:23 pm
Power supply should be 5V 2.5 A
Not necessarily for a CM3. It depends what it is being used for.
