JamesPi123
VLC will not open in Raspbian
Sat Dec 29, 2018 11:27 pm
In the latest raspbian (one from November 2018) VLC will not open. I have tried opening it in the terminal as well but no window appears. Here's the output.
james@raspberrypi:~ $ vlc
VLC media player 3.0.3 Vetinari (revision 3.0.3-1-0-gc2bb759264)
[01099b88] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
[0102a938] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
MESA-LOADER: failed to retrieve device information
qt5ct: using qt5ct plugin
load glyph failed err=24 face=0x73d7c9e0, glyph=44
load glyph failed err=24 face=0x73d7c9e0, glyph=81
load glyph failed err=24 face=0x73d7c9e0, glyph=3
load glyph failed err=24 face=0x73d7c9e0, glyph=82
load glyph failed err=24 face=0x73d7c9e0, glyph=85
load glyph failed err=24 face=0x73d7c9e0, glyph=71
load glyph failed err=24 face=0x73d7c9e0, glyph=72
load glyph failed err=24 face=0x73d7c9e0, glyph=87
load glyph failed err=24 face=0x73d7c9e0, glyph=83
load glyph failed err=24 face=0x73d7c9e0, glyph=70
load glyph failed err=24 face=0x73d7c9e0, glyph=92
load glyph failed err=24 face=0x73d7c9e0, glyph=88
load glyph failed err=24 face=0x73d7c9e0, glyph=76
load glyph failed err=24 face=0x73d7c9e0, glyph=89
load glyph failed err=24 face=0x73d7c9e0, glyph=68
load glyph failed err=24 face=0x73d7c9e0, glyph=15
load glyph failed err=24 face=0x73d6c088, glyph=57
load glyph failed err=24 face=0x73d6c088, glyph=47
load glyph failed err=24 face=0x73d6c088, glyph=38
load glyph failed err=24 face=0x73d6c088, glyph=80
load glyph failed err=24 face=0x73d6c088, glyph=72
load glyph failed err=24 face=0x73d6c088, glyph=71
load glyph failed err=24 face=0x73d6c088, glyph=76
load glyph failed err=24 face=0x73d6c088, glyph=68
load glyph failed err=24 face=0x73d6c088, glyph=83
load glyph failed err=24 face=0x73d6c088, glyph=79
load glyph failed err=24 face=0x73d6c088, glyph=92
load glyph failed err=24 face=0x73d6c088, glyph=85
load glyph failed err=24 face=0x73d7c9e0, glyph=86
load glyph failed err=24 face=0x73da4e20, glyph=81
load glyph failed err=24 face=0x73da4e20, glyph=82
load glyph failed err=24 face=0x73da4e20, glyph=87
load glyph failed err=24 face=0x73d7c9e0, glyph=79
load glyph failed err=24 face=0x73d7c9e0, glyph=80
load glyph failed err=24 face=0x73d7c9e0, glyph=75
load glyph failed err=24 face=0x73d7c9e0, glyph=93
load glyph failed err=24 face=0x73d7c9e0, glyph=73
load glyph failed err=24 face=0x73d7c9e0, glyph=17
load glyph failed err=24 face=0x73d7c9e0, glyph=49
load glyph failed err=24 face=0x73d7c9e0, glyph=69
load glyph failed err=24 face=0x73d7c9e0, glyph=16
load glyph failed err=24 face=0x73d7c9e0, glyph=55
load glyph failed err=24 face=0x73d7c9e0, glyph=78
load glyph failed err=24 face=0x73d7c9e0, glyph=38
load glyph failed err=24 face=0x73d7c9e0, glyph=84
load glyph failed err=24 face=0x73d7c9e0, glyph=74
load glyph failed err=24 face=0x73d7c9e0, glyph=871
load glyph failed err=24 face=0x73d7c9e0, glyph=91
load glyph failed err=24 face=0x73d7c9e0, glyph=51
load glyph failed err=24 face=0x73d7c9e0, glyph=90
load glyph failed err=24 face=0x73d7c9e0, glyph=36
load glyph failed err=24 face=0x73da4e20, glyph=51
load glyph failed err=24 face=0x73da4e20, glyph=85
load glyph failed err=24 face=0x73da4e20, glyph=76
load glyph failed err=24 face=0x73da4e20, glyph=89
load glyph failed err=24 face=0x73da4e20, glyph=68
load glyph failed err=24 face=0x73da4e20, glyph=70
load glyph failed err=24 face=0x73da4e20, glyph=92
load glyph failed err=24 face=0x73da4e20, glyph=3
load glyph failed err=24 face=0x73da4e20, glyph=71
load glyph failed err=24 face=0x73da4e20, glyph=49
load glyph failed err=24 face=0x73da4e20, glyph=72
load glyph failed err=24 face=0x73da4e20, glyph=90
load glyph failed err=24 face=0x73da4e20, glyph=78
load glyph failed err=24 face=0x73da4e20, glyph=36
load glyph failed err=24 face=0x73da4e20, glyph=86
load glyph failed err=24 face=0x73da4e20, glyph=79
QWidget::setMinimumSize: (/FirstRun) The largest allowed size is (16777215,16777215)
qt5ct: D-Bus global menu: no
load glyph failed err=24 face=0x73d7c9e0, glyph=18
load glyph failed err=24 face=0x73d7c9e0, glyph=77
load glyph failed err=24 face=0x73d7c9e0, glyph=45
load glyph failed err=24 face=0x73d7c9e0, glyph=60
load glyph failed err=24 face=0x73d7c9e0, glyph=824
load glyph failed err=24 face=0x73d7c9e0, glyph=66
load glyph failed err=24 face=0x73d7c9e0, glyph=48
load glyph failed err=24 face=0x73d7c9e0, glyph=41
load glyph failed err=24 face=0x73d7c9e0, glyph=19
load glyph failed err=24 face=0x73d7c9e0, glyph=50
load glyph failed err=24 face=0x73d7c9e0, glyph=40
load glyph failed err=24 face=0x73d7c9e0, glyph=22
load glyph failed err=24 face=0x73d7c9e0, glyph=39
load glyph failed err=24 face=0x73d7c9e0, glyph=37
load glyph failed err=24 face=0x73d7c9e0, glyph=47
load glyph failed err=24 face=0x73d7c9e0, glyph=42
load glyph failed err=24 face=0x73d7c9e0, glyph=54
QPainter::begin: Paint device returned engine == 0, type: 2
QPainter::save: Painter not active
QPainter::setPen: Painter not active
QPainter::setBrush: Painter not active
QPainter::setRenderHint: Painter must be active to set rendering hints
QPainter::worldTransform: Painter not active
QPainter::setWorldTransform: Painter not active
QPainter::brush: Painter not active
QPainter::pen: Painter not active
QPainter::opacity: Painter not active
QPainter::setOpacity: Painter not active
QPainter::drawPath: Painter not active
QPainter::font: Painter not active
QPainter::setFont: Painter not active
QPainter::restore: Unbalanced save/restore
QPainter::end: Painter not active, aborted
load glyph failed err=24 face=0x73d7c9e0, glyph=20
QPainter::translate: Painter not active
QPainter::scale: Painter not active
QPainter::drawRects: Painter not active
load glyph failed err=24 face=0x73d7c9e0, glyph=29
qt5ct: D-Bus system tray: no
load glyph failed err=24 face=0x73d7c9e0, glyph=57
load glyph failed err=24 face=0x73d7c9e0, glyph=43
[01092868] main playlist: playlist is empty
QXcbConnection: XCB error: 2 (BadValue), sequence: 409, resource id: 0, major code: 1 (CreateWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 410, resource id: 23068677, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 411, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 412, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 413, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 415, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 416, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 417, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 420, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 424, resource id: 23068677, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 425, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 428, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 429, resource id: 23068677, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 433, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 434, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 438, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 439, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 2 (BadValue), sequence: 441, resource id: 0, major code: 1 (CreateWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 442, resource id: 23068681, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 443, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 444, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 445, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 447, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 448, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 449, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 450, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 454, resource id: 23068681, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 455, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 458, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 459, resource id: 23068681, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 463, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 464, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 466, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 469, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 472, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 473, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 474, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 475, resource id: 23068681, major code: 12 (ConfigureWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 491, resource id: 23068681, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 492, resource id: 23068681, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 493, resource id: 23068681, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 494, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 495, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 496, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 497, resource id: 23068681, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 498, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 499, resource id: 23068681, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 500, resource id: 23068681, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 501, resource id: 23068681, major code: 8 (MapWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 503, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 504, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 2 (BadValue), sequence: 513, resource id: 0, major code: 1 (CreateWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 514, resource id: 23068688, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 515, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 516, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 517, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 519, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 520, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 521, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 522, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 526, resource id: 23068688, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 527, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 530, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 531, resource id: 23068688, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 535, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 536, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 540, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 541, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 542, resource id: 23068688, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 544, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 545, resource id: 23068688, major code: 12 (ConfigureWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 546, resource id: 23068688, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 547, resource id: 23068688, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 548, resource id: 23068688, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 549, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 550, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 551, resource id: 23068688, major code: 19 (DeleteProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 552, resource id: 23068688, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 553, resource id: 23068688, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 554, resource id: 23068688, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 555, resource id: 23068688, major code: 19 (DeleteProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 556, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 557, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 558, resource id: 23068677, major code: 12 (ConfigureWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 559, resource id: 23068677, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 560, resource id: 23068677, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 561, resource id: 23068677, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 562, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 563, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 564, resource id: 23068677, major code: 19 (DeleteProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 565, resource id: 23068677, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 566, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 567, resource id: 23068677, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 568, resource id: 23068677, major code: 19 (DeleteProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 569, resource id: 23068677, major code: 8 (MapWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 571, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 572, resource id: 23068677, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 573, resource id: 23068677, major code: 12 (ConfigureWindow), minor code: 0
I have also tried updating raspbian, removing vlc with apt-get purge and reinstalling it. VLC just wont open.
gkreidl
Re: VLC will not open in Raspbian
Sat Dec 29, 2018 11:33 pm
delete the file vlc-qt-interface.conf in ./config/vlc
Minimal Kiosk Browser (kweb)
JamesPi123
Sun Dec 30, 2018 6:34 am
@gkreidl
Unfortunately that didn't work
Here's the output
james@raspberrypi:~ $ rm ~/.config/vlc/vlc-qt-interface.conf
james@raspberrypi.:~ $ vlc
[00b8cb88] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
[00b1d938] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
load glyph failed err=24 face=0x73d9dbf0, glyph=44
load glyph failed err=24 face=0x73d9dbf0, glyph=81
load glyph failed err=24 face=0x73d9dbf0, glyph=3
load glyph failed err=24 face=0x73d9dbf0, glyph=82
load glyph failed err=24 face=0x73d9dbf0, glyph=85
load glyph failed err=24 face=0x73d9dbf0, glyph=71
load glyph failed err=24 face=0x73d9dbf0, glyph=72
load glyph failed err=24 face=0x73d9dbf0, glyph=87
load glyph failed err=24 face=0x73d9dbf0, glyph=83
load glyph failed err=24 face=0x73d9dbf0, glyph=70
load glyph failed err=24 face=0x73d9dbf0, glyph=92
load glyph failed err=24 face=0x73d9dbf0, glyph=88
load glyph failed err=24 face=0x73d9dbf0, glyph=76
load glyph failed err=24 face=0x73d9dbf0, glyph=89
load glyph failed err=24 face=0x73d9dbf0, glyph=68
load glyph failed err=24 face=0x73d9dbf0, glyph=15
load glyph failed err=24 face=0x6d7e0d10, glyph=57
load glyph failed err=24 face=0x6d7e0d10, glyph=47
load glyph failed err=24 face=0x6d7e0d10, glyph=38
load glyph failed err=24 face=0x6d7e0d10, glyph=80
load glyph failed err=24 face=0x6d7e0d10, glyph=72
load glyph failed err=24 face=0x6d7e0d10, glyph=71
load glyph failed err=24 face=0x6d7e0d10, glyph=76
load glyph failed err=24 face=0x6d7e0d10, glyph=68
load glyph failed err=24 face=0x6d7e0d10, glyph=83
load glyph failed err=24 face=0x6d7e0d10, glyph=79
load glyph failed err=24 face=0x6d7e0d10, glyph=92
load glyph failed err=24 face=0x6d7e0d10, glyph=85
load glyph failed err=24 face=0x73d9dbf0, glyph=86
load glyph failed err=24 face=0x73d5f910, glyph=81
load glyph failed err=24 face=0x73d5f910, glyph=82
load glyph failed err=24 face=0x73d5f910, glyph=87
load glyph failed err=24 face=0x73d9dbf0, glyph=79
load glyph failed err=24 face=0x73d9dbf0, glyph=80
load glyph failed err=24 face=0x73d9dbf0, glyph=75
load glyph failed err=24 face=0x73d9dbf0, glyph=93
load glyph failed err=24 face=0x73d9dbf0, glyph=73
load glyph failed err=24 face=0x73d9dbf0, glyph=17
load glyph failed err=24 face=0x73d9dbf0, glyph=49
load glyph failed err=24 face=0x73d9dbf0, glyph=69
load glyph failed err=24 face=0x73d9dbf0, glyph=16
load glyph failed err=24 face=0x73d9dbf0, glyph=55
load glyph failed err=24 face=0x73d9dbf0, glyph=78
load glyph failed err=24 face=0x73d9dbf0, glyph=38
load glyph failed err=24 face=0x73d9dbf0, glyph=84
load glyph failed err=24 face=0x73d9dbf0, glyph=74
load glyph failed err=24 face=0x73d9dbf0, glyph=871
load glyph failed err=24 face=0x73d9dbf0, glyph=91
load glyph failed err=24 face=0x73d9dbf0, glyph=51
load glyph failed err=24 face=0x73d9dbf0, glyph=90
load glyph failed err=24 face=0x73d9dbf0, glyph=36
load glyph failed err=24 face=0x73d5f910, glyph=51
load glyph failed err=24 face=0x73d5f910, glyph=85
load glyph failed err=24 face=0x73d5f910, glyph=76
load glyph failed err=24 face=0x73d5f910, glyph=89
load glyph failed err=24 face=0x73d5f910, glyph=68
load glyph failed err=24 face=0x73d5f910, glyph=70
load glyph failed err=24 face=0x73d5f910, glyph=92
load glyph failed err=24 face=0x73d5f910, glyph=3
load glyph failed err=24 face=0x73d5f910, glyph=71
load glyph failed err=24 face=0x73d5f910, glyph=49
load glyph failed err=24 face=0x73d5f910, glyph=72
load glyph failed err=24 face=0x73d5f910, glyph=90
load glyph failed err=24 face=0x73d5f910, glyph=78
load glyph failed err=24 face=0x73d5f910, glyph=36
load glyph failed err=24 face=0x73d5f910, glyph=86
load glyph failed err=24 face=0x73d5f910, glyph=79
load glyph failed err=24 face=0x73d9dbf0, glyph=20
load glyph failed err=24 face=0x73d9dbf0, glyph=19
load glyph failed err=24 face=0x73d9dbf0, glyph=29
load glyph failed err=24 face=0x73d9dbf0, glyph=18
load glyph failed err=24 face=0x73d9dbf0, glyph=48
load glyph failed err=24 face=0x73d9dbf0, glyph=57
load glyph failed err=24 face=0x73d9dbf0, glyph=54
load glyph failed err=24 face=0x73d9dbf0, glyph=43
[00b85868] main playlist: playlist is empty
QXcbConnection: XCB error: 3 (BadWindow), sequence: 410, resource id: 31457285, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 411, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 412, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 413, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 415, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 416, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 417, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 420, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 424, resource id: 31457285, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 425, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 428, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 429, resource id: 31457285, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 433, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 434, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 438, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 439, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 442, resource id: 31457289, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 443, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 444, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 445, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 447, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 448, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 449, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 450, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 454, resource id: 31457289, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 455, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 458, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 459, resource id: 31457289, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 463, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 464, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 466, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 469, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 472, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 473, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 474, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 491, resource id: 31457289, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 492, resource id: 31457289, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 493, resource id: 31457289, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 494, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 495, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 496, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 497, resource id: 31457289, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 498, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 499, resource id: 31457289, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 500, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 501, resource id: 31457289, major code: 8 (MapWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 503, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 504, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 514, resource id: 31457296, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 515, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 516, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 517, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 519, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 520, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 521, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 522, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 526, resource id: 31457296, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 527, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 530, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 531, resource id: 31457296, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 535, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 536, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 540, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 541, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 542, resource id: 31457296, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 544, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 545, resource id: 31457296, major code: 12 (ConfigureWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 546, resource id: 31457296, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 547, resource id: 31457296, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 548, resource id: 31457296, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 549, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 550, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 551, resource id: 31457296, major code: 19 (DeleteProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 552, resource id: 31457296, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 553, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 554, resource id: 31457296, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 555, resource id: 31457296, major code: 19 (DeleteProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 556, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 557, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 558, resource id: 31457285, major code: 12 (ConfigureWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 559, resource id: 31457285, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 560, resource id: 31457285, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 561, resource id: 31457285, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 562, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 563, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 564, resource id: 31457285, major code: 19 (DeleteProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 565, resource id: 31457285, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 566, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 567, resource id: 31457285, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 568, resource id: 31457285, major code: 19 (DeleteProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 569, resource id: 31457285, major code: 8 (MapWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 571, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
gkreidl
Sun Dec 30, 2018 9:38 am
Did you enable the experimental OpenGL driver?
If so, disable it and try again.
JamesPi123
Sun Dec 30, 2018 8:56 pm
@gkreidl
Thanks! That worked really well.
