kenwatt1
obconf issue following upgrade to Stretch 4.14.79-v7+
Wed Dec 19, 2018 1:56 pm
Folks,
Experiencing issues with opconf and LxDE (system details below). When invoked through the desktop menu, opconf appears to run initially (but fails to display its screen), then dies. Via the cli, it reports “Segmentation fault”. Adding –f to the cli command, the screen displays as expected but abends with the error “Unable to extract the file “-f”, followed by a list of errors related to tar (child) etc.
I have several RPI 3s which now have this issue, following an update/upgrade to 4.14.79-v7+
All the PI3s run the same Stretch version:
Stretch Lite: Linux version 4.14.79-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1159 SMP Sun Nov 4 17:50:20 GMT 2018
LxDE. Installed as follows:
sudo apt-get install --no-install-recommends xserver-xorg
sudo apt-get install --no-install-recommends xinit
sudo apt-get install lxde-core lxappearance
reboot
openbox installed as follows:
sudo apt install openbox obconf
sources.list:
deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
deb https://download.webmin.com/download/repository sarge contrib
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
All PI3s were updated as follows:
Apt update > apt upgrade > apt dist-upgrade, followed by a reboot.
I note that the release notes for 2018-11-13-raspbian-stretch-lite update state:
* Modifications to LXDE components to enable local configuration to override global
configuration correctly
* Modifications to Appearance Settings to support above configuration changes
* Modifications to various initial config defaults and relevant package to support above
* Selecting default option in Appearance Settings now deletes relevant local configuration files
I am assuming the 2018-11-13 release updates to 4.14.79-v7+ and addresses the above issue after a dist-upgrade?
I have attempted several reinstalls with purge and autoclean with no luck. Would appreciate any pointers.
Cheers
Ken
GavinW
Re: obconf issue following upgrade to Stretch 4.14.79-v7+
Wed Dec 19, 2018 10:59 pm
I too have just done a sudo apt-get dist-upgrade and uname -a says Linux Raspberrypi 4.14.79-v7+. As for you, obconf does not seem to work, nor does lxappearance. That command brings up the error Failed to load module "atk-bridge".
otium negare negotium vanum
klricks
Thu Dec 20, 2018 1:17 am
+1
Using an updated standard full Raspbian Desktop install.
obconf gives Segmentation fault.
I use obconf to configure multiple desktops.
n67
Thu Dec 20, 2018 5:59 am
Yes. This is true. I noticed this a few days ago.
BTW, you can enable multiple desktop functionality with the wmctrl program, which is in the repo.
I find that this does most of what I need, so the loss of obconf is not a biggie. The one thing you can't do with wmctrl is to "name" the desktops. This is annoying, but tolerable.
"L'enfer, c'est les autres"
Epmu Sn!
kenwatt1
Thu Dec 20, 2018 2:50 pm
Thank you all for the prompt replies and confirmation of the issue. Thank you n67 for the suggestion to try out wmctrl ; will do this evening. It's unlikely, but perhaps there was a failure in the update/dist-upgrade process, or my sources.list is incorrect. I'll re-install the latest version of Stretch-Lite (2018-11-13) on my sandbox, and determine whether it does address the obconf issue as per the release notes. I'll post the results here as soon as I can.
Cheers
Ken
JamesPi123
Sun Dec 30, 2018 6:30 am
Funny. Noticed this 2 weeks a go and tried all of the above and it still didn't work. Thought is wan only me.
JamesPi123
Sun Dec 30, 2018 6:38 am
Folks,
reboot
sources.list:
Cheers
Ken
On a side note (not that this matters), I can see you are using the webmin repository for Debian Sarge!
You are using Stretch (Sarge is from 2005 and the package might be old)
beerPriest
Wed Jan 02, 2019 9:00 pm
+1 still no solution for the sementation fault of obconf and lxappearance?
klricks
Fri Jan 04, 2019 2:00 am
+1 still no solution for the segmentation fault of obconf and lxappearance?
Having an issue posted in these forums is no guarantee that those who may be able to fix the issue will even see the post let alone solve it.
Another thread here: viewtopic.php?f=28&t=229983
klricks
Fri Jan 11, 2019 12:54 am
The obconf issue has been fixed with today's update:
sudo apt update
sudo apt upgrade
kenwatt1
Mon Jan 28, 2019 1:06 pm
Kricks,
Yes many thanks! Updated/upgraded a couple of days ago, and all appears stable.
Cheers
Ken
