RPi 3 Model B will not read anything from SD card
Posted: Sun Dec 09, 2018 11:25 pm
by nelson.graham
I have tried using two different brand new SD cards and my Pi refuses to boot. There is no green light at all, not even a flicker. I have used the official SD card formatter and installed N00bs and also used etcher to write raspbian directly to the card. I am using an official power supply and all I get is the rainbow screen. I have tried every other troubleshooting forum and guide but I can't find anything helpful. I have heard that every Pi is able to boot when it leaves the factory so it is unlikely that the board is a dud. The pi foundation website is useless as it just links to more guides on how to install N00bs, which I have done and redone about 10 times now. I can clearly see that boot\kernel.img is present on the boot partition of the card but the pi refuses to read anything or show any signs of screen activity.
Re: RPi 3 Model B will not read anything from SD card
Posted: Mon Dec 10, 2018 6:18 am
by W. H. Heydt
What versions of NOOBS and Raspbian are you using? Are you sure your Pi is a Pi3B and not a Pi3B+?
The symptoms you describe are typical of using a version that pre-dates the release of the board.
