crosland
Connect to VNC server using hostname?
Sun Dec 09, 2018 6:35 pm
RPi Model 3B+ running Stretch. Trying to connect using RealVNC viewer on Windows 10.
Connecting by IP address works fine.
Trying to connect to hostname or hostname.local returns "vnc getaddrinfo: The requested name is valid, but no data of the requested type was found (11004)"
I can ping or ssh (PuTTY) by hostname if I set the appropriate options to force ipv4 connections.
Is this another ipv6/ipv4 issue? Is there a way to force the VNC viewer to use ipv4? I cannot find one.
Or is there another solution?
All suggestions appreciated.
mattmiller
Re: Connect to VNC server using hostname?
Sun Dec 09, 2018 6:46 pm
This has been an issue since about April
The theory at the time is that it was due to bug introduced into the MS win10 spring update.
After trying a load of things, I gave up and just went back to using ip addresses
It can be a bit intermittent and sometimes works (but then fails again)
pfletch101
Mon Dec 10, 2018 4:21 pm
Yes, at least on my network, Windows 10 is still having problems consistently recognizing and communicating with other Windows systems (sometimes even if I use their IP addresses). There is a rumor that this has been fixed in the latest major update, but that (at least initially) had so many other serious issues that I have not been brave enough to install it on any of my systems yet.
crosland
[Solved] Re: Connect to VNC server using hostname?
Sat Dec 22, 2018 6:12 pm
ITS FIXED :):):)
Version 1809 (OS Build 17763.195) (WIn 10 Home 64 bit)
Can now connect with VNC viewer using the Pis hostname.
mattmiller
Mon Dec 24, 2018 9:29 am
Yep - it been working consistently on my Win10 machine for the past week.
