Coco
Index.php doesn't auto launch with RPI/Apache
Sat Nov 17, 2018 3:14 am
I have setup an apache webserver on my RPI. On another computer, when I enter in the IP address of the RPI, I see Index of / and the html folder. Then when I click on this folder, it launches my index.php page.
I was wondering is there a way to configure a file on the RPI such that when I type in the IP address to my RPI, it automatically launches the index.php. I have been Googling for a couple of hours, haven't found a way so far. Any advice would be greatly appreciated.
HW/SW info:
RPI 3 Model B Rev 1.2
RPI 9 Stretch OS
PHP V 5.6.38-0
Paul Webster
Contact: Twitter
Re: Index.php doesn't auto launch with RPI/Apache
Sat Nov 17, 2018 7:28 am
In the Apache configuration, what have you set DocumentRoot to?
Coco
Sat Nov 17, 2018 3:38 pm
Thanks for the response. I found the DocumentRoot setting in the /etc/apache2/sites-available 000-default.conf folder. I saw it was set to: DocumentRoot /var/www/html Then I just changed it to: DocumentRoot /var/www/html/index.php and restarted the server. This did not change anything. It still doesn't launch the index.php file when I type in the address. I thought it should/would? But maybe this is the expected behavior? I will continue experimenting. Any other ideas/suggestions would be much appreciated.
Thanks.
Peter Ryan
Sat Nov 17, 2018 3:55 pm
DocumentRoot should point to a directory and not a file, so you should probably put it back to what it was (or another directory). And then add a "DirectoryIndex" line which tells it to look first for "index.html" and if that's not found, use "index.php":
DirectoryIndex index.html index.php
I'll ignore the fact you seem to be running an older version of PHP than is usual with Raspbian Stretch because if I mention that, it'll probably open a can of worms! :D
Coco
Sat Nov 17, 2018 9:16 pm
Thanks for additional information. I ended up doing a search for DocumentRoot and found there was another configuration file that was DocumentRoot /var/www. Then I updated that configuration file, and everything worked as expected. I am using PHP 7 now.
Thanks!
