farhan1786
dht11 value is none on cloud aws
Thu Nov 01, 2018 11:17 am
#!/usr/bin/python
# PROBLEM STATEMENT:
# This program will publish test mqtt messages using the AWS IOT hub
# To test this program you have to run first its companinon aws_iot_sub.py
# that will subscribe and show all the messages sent by this program
# STEPS:
# 1. Sign in to AWS Amazon > Services > AWS IoT > Settings > copy Endpoint
#    This is your awshost
# 2. Change following things in the below program:
#    a. awshost   (from step 1)
#    b. clientId  (Thing_Name)
#    c. thingName (Thing_Name)
#    d. caPath    (root-CA_certificate_Name)
#    e. certPath  (<Thing_Name>.cert.pem)
#    f. keyPath   (<Thing_Name>.private.key)
# 3. Paste aws_iot_pub.py & aws_iot_sub.py python scripts in folder where all unzipped aws files are kept.
# 4. Provide Executable permition for both the python scripts.
# 5. Run aws_iot_sub.py script
# 6. Run this aws_iot_pub.py python script
# importing libraries
import sys
import Adafruit_DHT
import paho.mqtt.client as paho
import os
import socket
import ssl
import time
from time import sleep
from random import uniform
connflag = False
def on_connect(client, userdata, flags, rc):                # func for making connection
    global connflag
    print ("Connected to AWS")
    connflag = True
    print("Connection returned result: " + str(rc) )
def on_message(client, userdata, msg):                      # Func for Sending msg
    print(msg.topic+" "+str(msg.payload))
#def on_log(client, userdata, level, buf):
#    print(msg.topic+" "+str(msg.payload))
mqttc = paho.Client()                                       # mqttc object
mqttc.on_connect = on_connect                               # assign on_connect func
mqttc.on_message = on_message                               # assign on_message func
#mqttc.on_log = on_log
#### Change following parameters ####
awshost = "uv0-ats.iot.us-west-2.amazonaws.com"      # Endpoint
awsport = 8883                                              # Port no.
clientId = "DHT11"                                     # Thing_Name
thingName = "DHT11"                                    # Thing_Name
caPath = "/home/pi/Downloads/root-CA.crt"                                      # Root_CA_Certificate_Name
certPath = "/home/pi/gajendra/9c02fd2f1d-certificate.pem.crt"                            # <Thing_Name>.cert.pem
keyPath = "/home/pi/gajendra/9c02fd2f1d-private.pem.key"                          # <Thing_Name>.private.key
mqttc.tls_set(caPath, certfile=certPath, keyfile=keyPath, cert_reqs=ssl.CERT_REQUIRED, tls_version=ssl.PROTOCOL_TLSv1_2, ciphers=None)  # pass parameters
mqttc.connect(awshost, awsport, keepalive=60)               # connect to aws server
mqttc.loop_start()                                          # Start the loop
while 1==1:
    sleep(5)
    if connflag == True:
        tempreading = uniform(20.0,25.0)                        # Generating Temperature Readings
        humidity, temperature = Adafruit_DHT.read_retry(11, 4)
        payload = ' {"temperature": %s, "humidity": %s} '%(temperature,humidity)
        #payload = '{ temperature:"temperature", Humidity:"humidity" }'
        mqttc.publish("temperature", payload, qos=1)        # topic: temperature # Publishing Temperature values
        print("msg sent: temperature " + payload ) # Print sent temperature msg on console
        time.sleep(1)
    else:
        print("waiting for connection...")
dht11 temperatura and humidity values show none in aws iot im using wifi for both
