Kove--
[resolved] wireless usb card: driver loaded but can't connect
Mon Oct 08, 2018 7:37 pm
After a lot of trouble I managed to load a driver for a tp-link usb wireless card. This is the device in the lsusb output
Bus 001 Device 006: ID 2357:0109
I took the driver from this website: http://www.fars-robotics.net/install-wifi (I failed a previous compiling from source, driver was loaded but card didn't work in the gui).
Now the card is working in the gui, but I can't connect to a network.
Trying to do truebleshooting, I've noticed in this thread https://www.raspberrypi.org/forums/view ... 28&t=44044 that raspian by default has some lines in /etc/network/interfaces. Mine was almost empty, so I added some lines regarding wlan0
cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
But still, if I try to connect to the network I get a strange "failed to disconnect" error in the gui
help...
Kove--
Re: wireless usb card: driver loaded but can't connect
Tue Oct 09, 2018 7:39 pm
please help, give me an hint at least
MrEngman
Tue Oct 09, 2018 8:56 pm
The post you referenced setting up wifi is out of date. Do not edit file /etc/network/interfaces.
File /etc/network/interfaces should look like
with no additional lines added.
File /etc/wpa_supplicant/wpa_supplicant.conf should look like
country=GB
update_config=1
network={
        ssid="network-name"
        psk="network_password"
        key_mgmt=WPA-PSK
Set the wifi name and password to you wifi settings. Make sure you have the line country=XX, where XX is the sountry code for where you are.
All my Pi work with these settings, Pi 0, Pi 0W, Pi B+, Pi 2B, Pi 3b and Pi 3B+, including with the wifi driver you are using.
Kove--
Tue Oct 09, 2018 9:34 pm
my files are like yours, but I still get the error "failed to disconnect" when I select the wifi network from the dropdown in the top-right corner
Kove--
Wed Oct 10, 2018 6:52 pm
Any idea about what should I check?
MrEngman
Wed Oct 10, 2018 7:38 pm
Presumably you removed the lines referencing wlan0 you added to the /etc/network/interfaces file? Then rebooted?
I have no idea why you are getting the "failed to disconnect" error. There are a very few other posts referencing that error, but no explanation why it happened.
I currently don't use the GUI and all my Pi run headless using wifi of various kinds without issues all running Raspbian Lite OS.
What Pi are you using and which OS and kernel version.
What does the output of command ifconfig show?
Kove--
Wed Oct 24, 2018 1:42 pm
yes
Raspbian, how can I find the pi version?
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.14.70-v7+ #1144 SMP Tue Sep 18 17:34:46 BST 2018 armv7l GNU/Linux
pi@raspberrypi:~ $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.181  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::b784:6c84:3288:286e  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:18:92:a5  txqueuelen 1000  (Ethernet)
        RX packets 5294  bytes 6794176 (6.4 MiB)
        RX errors 0  dropped 5  overruns 0  frame 0
        TX packets 4269  bytes 412299 (402.6 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 50:3e:aa:73:b6:a8  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 7440 (7.2 KiB)
        RX errors 0  dropped 63  overruns 0  frame 0
        TX packets 0  bytes 7440 (7.2 KiB)
Kove--
Sat Oct 27, 2018 3:06 pm
I just reinstalled Raspbian from the beginning to see if with a fresh start I obtain better results. Now I cant even install the driver.
My commands:
wget http://www.fars-robotics.net/install-wifi
chmod +x install-wifi
sudo ./install-wifi
And I get
pi@raspberrypi:/tmp $ sudo ./install-wifi
 *** Raspberry Pi wifi driver installer by MrEngman.
 *** Performing self-update
stat: impossibile eseguire stat di './install-wifi': File o directory non esistente
chmod: manca l'operando dopo "./install-wifi.tmp"
Try 'chmod --help' for more information.
 !!! Failed: Error while trying to set mode on ./install-wifi.tmp
What am I doing wrong this time....
Kove--
Sat Oct 27, 2018 3:20 pm
The right command was:
sudo wget http://downloads.fars-robotics.net/wifi-drivers/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
Kove--
Sat Oct 27, 2018 3:23 pm
Now it works!
Just needed a fresh install.
