SIRJP
Trouble with raspberry pink pi device and setting up the desktop GUI
Sun Sep 30, 2018 12:48 am
Hello, so I have a pink pi device which is basically a raspberry pi 3 model b with pinkpi software loaded onto the sd card. I have everything(keyboard, mouse, hdmi via TV) connected except an Ethernet cable, because I assume the desktop boot does not require it?
When I type (sudo raspi-config) then select boot options and then the desktop option for the GUI, it then prompts (do 'sudo apt-get install lightdm' to allow configuration of boot to desktop) followed by an error message. So when I type that install command, it loads and asks do you want to continue[y/n] and I type in y. But after it simply shows a whole bunch of(E: Failed to fetch http...).. How can I boot into the raspbian desktop interface?
scotty101
Re: Trouble with raspberry pink pi device and setting up the desktop GUI
Mon Oct 01, 2018 8:44 am
Basically you don't have an internet connection.....
You either need to configure the WiFi to connect to your local WiFi network or connect the ethernet cable to your internet router.
I had never heard of PinkPi before, is there a specific reason you are using this "distribution" rather than the standard raspberry pi OS Raspbian?
k-pi
Mon Oct 01, 2018 9:29 am
If you have X installed, you should be able to start it by typing startx at the prompt.
To add software requires an internet connection, unless you tranfer a downloaded file via USB.
kevinthefixer
Sat Oct 06, 2018 2:28 am
In any case, do you realize you are posting in the section for machines which are not Raspberry Pi?
Sat Oct 06, 2018 3:10 am
If you have this device, suggest you ask them to support:
https://www.stakebox.org/collections/stakeboxes/pinkpi
Retired disgracefully.....
