DaPeace
RPI3B+, POE-Hat and TSOP at GPIO, low range!
Tue Sep 18, 2018 7:49 am
last weekend i wanted to change my rpi3-mediacenter to rpi3-b+ and power it via poe-hat. That includes the use of an TSOP-IR-Diode for the remotecontrol. Ive tried around for a longer time and figured out, that the range where the remote-control is working, is 1-2m (way to less) with the poe-hat and without i get a much higher (usable) range. Could anybody give me a hint how to solve that?
Ive tried to power the tsop with 5v and 3.3v but that does not make any difference.
Regards, Jan
drgeoff
Re: RPI3B+, POE-Hat and TSOP at GPIO, low range!
Tue Sep 18, 2018 9:11 am
The official RPi PoE HAT? Are you aware of its design defects?
Read the details at https://www.raspberrypi.org/forums/view ... 5&t=220984
DaPeace
Tue Sep 18, 2018 11:25 am
Yes the official poe-hat. And i had the same problem as this one -> https://www.raspberrypi.org/forums/view ... p?t=220936
But i tried to repair it and i had this problem before the plug got broken too.
At the USB-Side i only used a keyboard and that worked for me. Did most of the configuration via SSH.
edit: ive seen that the thread you linked has several pages and is started to read a bit. Looks like this is some sideeffect of the more or less unusable poe-hat. I will try to separate the hat and the pi and look if the ir-diode is working then.. problem is that my case in the livingroom is a little small for this separation :x
