Pi 3B+ won't boot (added 4 MiB block between boot and rootfs)
Posted: Tue Jul 31, 2018 4:21 pm
by scollins15
I have struggled with using the Stretch Lite image from the Raspberry Pi website with the Pi 3 B+. Some background in the past there were issues with SD card corruption on the Pi 1 which I tried to limit by having a read only partition. To do this correctly I needed to add a 4MB block between the end of the boot and rootfs partition. Else it is possible inadvertant writes may happen in a read only partition when trying to write to a neighboring read/write partition.
In the past I have been able to take the stock image from raspberry pi and put it on an SD card. Which obviously still works and boots in the Pi 3B+. I would then zip up each partition as follows:
sudo dd if=/dev/sdb1 of=bootPartition
sudo dd if=/dev/sdb2 of=rootPartition
Next using fdisk in Linux I would create a new SD card with 2 partitions as follows:
Command (m for help): n
Partition type:
   p   primary (0 primary, 0 extended, 4 free)
   e   extended
Select (default p):
Using default response p
Partition number (1-4, default 1):
Using default value 1
First sector (2048-31116287, default 2048): 8192
Last sector, +sectors or +size{K,M,G} (8192-31116287, default 31116287): 131072
Command (m for help): t
Selected partition 1
Hex code (type L to list codes): c
Changed system type of partition 1 to c (W95 FAT32 (LBA))
Partition type:
   p   primary (1 primary, 0 extended, 3 free)
   e   extended
Select (default p):
Partition number (1-4, default 2):
Using default value 2
First sector (2048-31116287, default 2048): 139264
Last sector, +sectors or +size{K,M,G} (139264-31116287, default 31116287): 7632895
Partition number (1-4): 2
Hex code (type L to list codes): 83
Command (m for help): p
Disk /dev/sdb: 15.9 GB, 15931539456 bytes
64 heads, 32 sectors/track, 15193 cylinders, total 31116288 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x4d3ee428
   Device Boot      Start         End      Blocks   Id  System
/dev/sdb1            8192      131072       61440+   c  W95 FAT32 (LBA)
/dev/sdb2          139264     7632895     3746816   83  Linux
Command (m for help):w
Once I have my card formatted with the correct sized and spaced partitions I use the following to write the data from the stock image to the SD card.
sudo dd if=/bootPartition of=/dev/sdb1
sudo dd of=/rootPartition if=/dev/sdb2
The result is the SD card will not boot completely in the RPi 3B+. The following error is returned:
kernel panic-not syncing: VFS: unable to mount root fs on unknown-block(179,2)
I assume I have forgotten a step or part of my process from the past...Maybe I am getting old and forgetful!
Scot
Re: Pi 3B+ won't boot (added 4 MiB block between boot and rootfs)
Posted: Tue Jul 31, 2018 5:37 pm
by epoch1970
A little eyestrain, maybe?
Posted: Wed Aug 01, 2018 12:29 pm
by scollins15
Sorry, typing error on my part. I did in fact have them correct when I executed the command. I have tried this several times with no luck. Thanks
Posted: Wed Aug 01, 2018 6:33 pm
by fbe
Did you verify that the output of
lsblk -o NAME,PARTUUID
matches with the contents of cmdline.txt on your new boot partition and /etc/fstab on your new root partition?
Posted: Wed Aug 01, 2018 6:57 pm
by scollins15
The solution that worked for me was to change cmdline.txt to have root=/dev/mmcblk0 and to change the fstab file to have that as well. Both were using a UUID that was defined in the cmdline.txt file and for some reason or another it wouldn't boot completely. Although it did boot prior to moving the partitions with that same setting using the UUID.
Sounds like you were on to it...Thanks for the input.
Posted: Wed Aug 01, 2018 8:10 pm
by DirkS
Have you tried using PARTUUID?
Posted: Wed Aug 01, 2018 8:20 pm
by fbe
As I understand it - yes, but with invalid values. gparted created new partitions and the old values from the original Raspbian image didn't work anymore.
Posted: Wed Aug 01, 2018 9:58 pm
by DirkS
They should show up with 'sudo blkid'
Posted: Thu Aug 02, 2018 3:20 pm
by scollins15
The original image file from the Raspberry Pi site used had the following:
$ cat /boot/cmdline.txt
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=4d3ee428-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet init=/usr/lib/raspi-config/init_resize.sh
$ cat /etc/fstab
proc            /proc           proc    defaults          0       0
PARTUUID=4d3ee428-01  /boot           vfat    defaults          0       2
PARTUUID=4d3ee428-02  /               ext4    defaults,noatime  0       1
I stated this incorrectly when I said it was using the UUID, when in fact it was the PARTUUID as stated above. Anyhow this didn't work.
This was the smoking gun. See output below:
$ sudo blkid
/dev/mmcblk0: PTUUID="000a5026" PTTYPE="dos"
/dev/mmcblk0p1: LABEL="boot" UUID="3725-1C05" TYPE="vfat" PARTUUID="000a5026-01"
/dev/mmcblk0p2: LABEL="rootfs" UUID="fd695ef5-f047-44bd-b159-2a78c53af20a" TYPE="ext4" PARTUUID="000a5026-02"
Thanks @DirkS it is all better now :mrgreen:
Posted: Thu Aug 02, 2018 5:57 pm
by DirkS
Great!
Posted: Fri Aug 03, 2018 2:04 am
by aqk
I'm currently having boot problems also ( see my thread here)
Attached is a snapshot of the Gparted info. Isn't ~400Meg of free area kinda low for a linux rootfs partition?
Posted: Fri Aug 03, 2018 6:51 am
by rpdom
Isn't ~400Meg of free area kinda low[/b] for a linux rootfs partition?
Perfectly normal for a freshly created Raspbian SD card which hasn't completed its first boot yet. On the first (successful) boot the filesystem automatically gets expanded to use all of the unused space on the card.
Posted: Fri Aug 03, 2018 9:55 am
by jamesh
Please don't hijack other threads with new questions. Simply start a new thread, and keep to that thread rather than duplicating over multiple threads.
