NedKelly
SD Card Copier - Could not create FAT
Tue Jul 10, 2018 1:51 am
i have a 16 GB SD card (with NOOBS on it) and am trying to put it all onto a 32 GB SD card. I have tried using the SD Card Copier in the accessories menu with no success. I have formatted the 32 GB card on my MAC as MSDOS-FAT. I then run SD Card Copier and put the 16 GB SD card I am booted from in the From Device and the 32 GB card in to To Device and then click on Start. But every time after about 10 seconds or so I get the message "Could not create FAT". What could I be doing wrong?
Man in a van
Re: SD Card Copier - Could not create FAT
Tue Jul 10, 2018 10:07 am
Hi Ned, have you tried using
https://www.sdcard.org/downloads/formatter_4/
to format the card?
Ronnie
thagrol
Tue Jul 10, 2018 10:08 pm
As I recall, (and I may be wrong) there's a limitation in the underlying librarise that linux uses to format and resize partitions that prevents resizing of FAT32. Try deleting all partitions on the 32GB card and letting the SD card copier partition and format it.
As a last resort, do a clean install of noobs onto the 32GB card then manually copy your changed/created files over.
Note to self: don't feed the trolls
If I've asked you a question, please answer it. I'm unlikely to be able to help without that information.
