RealistikDash
Git clone and apt not working.
Fri Jun 29, 2018 11:02 pm
Hi there, I have recently been having issues with my Pi. I can't seem to do anything download related on my pi.
When trying to do apt update, I get this:
Err:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
  Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 2a00:1098:0:80:1000:75:0:3 80]
0% [Connecting to archive.raspberrypi.org (93.93.130.39)]
Additionally, when trying to clone using git it gets stuck at
Cloning into 'Repository Name'
and then gives me a timeout error.
However, the internet connection to the pi is fine since Apache, FTP server, ssh, and wget work fine.
Roken
Re: Git clone and apt not working.
Sat Jun 30, 2018 5:42 am
Have you been playing with your dns settings? It seems that incoming connections are fine, whilst outgoing are failing.
What's the output of cat /etc/resolv.conf?
Headless PI. OMG, someone cut it's head off. Oh, hang on. it didn't have one to start with.
lmarmisa
Sat Jun 30, 2018 10:16 am
Try these commands and post the outputs:
ip route
ping -c4 8.8.8.8
ping -c4 google.com
RealistikDash
Sat Jun 30, 2018 2:10 pm
The only thing I've really done is set a static local IP which shouldn't affect those.
The output I get is
# Generated by resolvconf
nameserver 192.168.0.1
RealistikDash
Sat Jun 30, 2018 2:13 pm
ip route
ping -c4 8.8.8.8
ping -c4 google.com
The output I get is this:
root@raspberrypi:/home/pi# ip route
default via 192.168.0.1 dev wlan0 src 192.168.0.111 metric 303
192.168.0.0/24 dev wlan0 proto kernel scope link src 192.168.0.111 metric 303
root@raspberrypi:/home/pi# cat /etc/resolv.conf
root@raspberrypi:/home/pi# ping -c4 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=59 time=31.8 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=59 time=21.5 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=59 time=20.9 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=59 time=15.2 ms
--- 8.8.8.8 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3003ms
rtt min/avg/max/mdev = 15.253/22.420/31.873/5.992 ms
root@raspberrypi:/home/pi# ping -c4 google.com
PING google.com (216.58.204.46) 56(84) bytes of data.
64 bytes from lhr25s12-in-f46.1e100.net (216.58.204.46): icmp_seq=1 ttl=54 time=16.2 ms
64 bytes from lhr25s12-in-f46.1e100.net (216.58.204.46): icmp_seq=2 ttl=54 time=23.2 ms
64 bytes from lhr25s12-in-f46.1e100.net (216.58.204.46): icmp_seq=3 ttl=54 time=16.8 ms
64 bytes from lhr25s12-in-f46.1e100.net (216.58.204.46): icmp_seq=4 ttl=54 time=15.5 ms
--- google.com ping statistics ---
rtt min/avg/max/mdev = 15.520/17.980/23.268/3.091 ms
lmarmisa
Sat Jun 30, 2018 5:08 pm
Your network seems to work fine at this time.
But according to your comments, two completely independent commands are not completed due to network problems:
sudo apt-get update
git clone xxxx
Is your RPi connected to the network via wifi?.
Check if this command is completed correctly:
wget https://downloads.raspberrypi.org/raspbian_lite_latest -O /dev/null
RealistikDash
Sat Jun 30, 2018 5:56 pm
sudo apt-get update
git clone xxxx
My Pi is connected via WiFi.
The wget command is giving me timeouts.
pi@raspberrypi:~/Desktop/test $ wget https://downloads.raspberrypi.org/raspbian_lite_latest -O /dev/null
--2018-06-30 17:50:00--  https://downloads.raspberrypi.org/raspbian_lite_latest
Resolving downloads.raspberrypi.org (downloads.raspberrypi.org)... 93.93.130.214, 93.93.128.211, 93.93.128.230, ...
Connecting to downloads.raspberrypi.org (downloads.raspberrypi.org)|93.93.130.214|:443... failed: Connection timed out.
Connecting to downloads.raspberrypi.org (downloads.raspberrypi.org)|93.93.128.211|:443... failed: Connection timed out.
Connecting to downloads.raspberrypi.org (downloads.raspberrypi.org)|93.93.128.230|:443...
lmarmisa
Sun Jul 01, 2018 6:22 am
The ICMP protocol (ping) works but https does not. What about http?:
ping -c25 google.com
wget http://downloads.raspberrypi.org/raspbian_lite_latest -O /dev/null
RealistikDash
Sat Jul 07, 2018 5:14 pm
Hi, it still timeouts.
lmarmisa
Sat Jul 07, 2018 7:19 pm
Hmmm. Including ping?.
I believe that the problem could be related to your router in such a way that it is filtering the traffic of protocols http and https with origin your RPi destined to the Internet.
According to /etc/resolv.conf, the IP address of your router is 192.168.0.1:
Open a browser and try connecting to http://192.168.0.1
You can type this command too:
wget http://192.168.0.1 -O /dev/null
If you are able to connect to your router via http, the router is the source of your problem.
RealistikDash
Mon Jul 09, 2018 4:30 pm
Oh sorry, the google ping did work. I forgot to do it as I overlooked it.
The wget http://192.168.0.1 -O /dev/null command worked.
--2018-07-09 15:36:01--  http://192.168.0.1/
Connecting to 192.168.0.1:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
Saving to: ‘/dev/null’
/dev/null                         [ <=>                                              ]   7.36K  --.-KB/s    in 0.006s
2018-07-09 15:36:02 (1.23 MB/s) - ‘/dev/null’ saved [7533]
lmarmisa
Mon Jul 09, 2018 6:45 pm
The behaviour of your Pi seems good. The protocol http works fine inside your LAN but it fails when you try to access to the internet. The default route looks good. The gateway (your router, 192.168.0.1) is apparently dropping your http connections to the Internet.
I believe that the problem is due to your router. You should check its configuration. Why is your router filtering the outgoing http/https traffic with origin your RPi destined to the Internet?. I can not give an answer to that question at this time.
Have you assigned a static IP address to your RPi?. Have you changed the default network configuration (dhcp)?.
RealistikDash
Wed Jul 11, 2018 6:31 pm
I have assigned a static IP. Apt used to work (I don't know if it was before or after the static IP change).
lmarmisa
Wed Jul 11, 2018 10:10 pm
You assigned the IP 192.168.0.111. This address belongs very probably to the dhcp pool managed by your router. So, according to that IP address, the router could consider your RPi as a intruder and therefore it could drop its TCP/UDP traffic to the Internet.
Try defining a static IP not belonging to the pool. Maybe 192.168.0.2 could be a candidate. Then check if the access to the Internet works again.
pfletch101
Wed Jul 11, 2018 10:18 pm
If you wish to use a fixed IP address for your Pi (which is often a good idea), have the router assign it (based on the Pi's MAC address, which the router can usually display). Fixing the IP address at the device level is a recipe for (at best) confusion.
davidcoton
Wed Jul 11, 2018 11:10 pm
+1.
There are three possibilities as to what has happened.
  • The router thinks it can assign 192.168.0.111 and has blocked a device using that address that it didn't assign.
  • The router has assigned that address to another device, so the two devices conflict.
  • Two devices have the same device-level IP assignment.
If you assign an IP address at device level, YOU are responsible for making sure it is in the sub-net, otherwise unused, and NOT in the DHCP pool.
You may also have problems if the network configuration is changed, or if you move your Pi to another network.
As quoted above, it is far better to get the router to assign a "reserved" address based on the Pi's MAC. This solution is more robust and keeps the Pi portable (it will get a DHCP address on any other network that allows new devices).
Signature retired
