codertarasvaskiv
I have 3 raspberries but on 1 of them wlan0 doesnt connect to wifi
Fri Jun 29, 2018 1:10 pm
I get this
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b8:27:eb:9d:54:c7 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions
How to debug this issue?
epoch1970
Re: I have 3 raspberries but on 1 of them wlan0 doesnt connect to wifi
Sat Jun 30, 2018 9:31 am
That interface is up but completely inactive (0 packet sent/received, 0 error)
Some config file could be missing or be wrong. Don’t forget to check cmdline.txt and config.txt.
On the command line, look for errors in “dmesg” and/or in the system log. “sudo tail -1500 /var/log/syslog | less” will let you page through the last 1500 lines of system messages, you could see something interesting there.
lmarmisa
Sat Jun 30, 2018 10:11 am
Have you modified the network configuration in any way?.
This command will show if the RPi is connected to wifi:
iwconfig wlan0
