Innyve89
Can I have this stepper motor lock in position?
Tue Apr 17, 2018 11:24 am
I currently have a bi polar stepper motor (https://www.robotshop.com/en/12v-17a-66 ... motor.html) powering a lever. When there is a weight on the lever the shaft turns.
I’m using a pwm controller (PCA9685) as an input to the stepper board (cytron SD02C) to get the motor to turn from the raspberry pi. I have the Dir,En, and pulse ( dir is direction, en is enable and pulse is pulse for it to turn) pins connected to the pwm controller. Is it possible to get it to lock with this setup?
https://www.cytron.io/p-sd02c
https://www.adafruit.com/product/815?gc ... gLZx_D_BwE
joan
Re: Can I have this stepper motor lock in position?
Tue Apr 17, 2018 11:28 am
What do you mean by lock?
pcmanbob
Tue Apr 17, 2018 11:37 am
Hi.
The normal function for a stepper motor is that it will hold a position once stepping instructions are stopped and power is still applied.
so having the enable pin active and no pulse command should make it hold its position, but a quick look at the user manual suggests this controller has a brake function, so it may not hold the motor in position by simple having the enable active.
you can only access the brake command if you talk to the controller via the UART interface.
By using the UART interface, user can:
On/Off, Run/Brake, and change motor’s rotation direction
Set motor speed
Request for encoder value
Track an encoder value and brake the motor
Set new baud rate for the driver
Sample source code for UART control is provided!
Innyve89
Tue Apr 17, 2018 2:24 pm
How can I have two of these setup if rpi has only one uart interface? Also could I have a python code that tells it to stop or go and such?
pcmanbob
Tue Apr 17, 2018 3:24 pm
I have no idea on any of your questions I don't have one of these boards to experiment with, I suggest you read the user manual.
https://docs.google.com/document/d/1eG9 ... _HuRw/view
