javierc
Recalbox not work in noobs 2.7.0 instaling with libreelec
Sun Apr 08, 2018 12:17 am
I have time using noobs, I used versions 2.4.2 and 2.4.4 always only installed Libreelec and recalbox without problems but with the version 2.7.0 recalbox not work.
Not is showned in the screen , any time flash or sound but not can get stable image.
Regards.
Re: Recalbox not work in noobs 2.7.0 instaling with libreelec
Sun Apr 08, 2018 2:13 pm
Regards.
NoobS will only show compatible Operating Systems for the model of Raspberry Pi you have, providing you have an active internet connection.
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
procount
Sun Apr 08, 2018 10:24 pm
If you are using a RPi3B+, you'll have to wait til the OSes are upgraded.
if you are using another RPi model, go back to using the older v2.4.4 of NOOBs.
Or use the latest version 2.5.5. of PINN.
PINN - NOOBS with the extras... https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=142574
ejoagoz
Fri May 11, 2018 12:51 pm
I think he says Recalbox load but doesn't show image. I have same problem with Noob 1.8.1. It should be a problem with default screen resolution. Any clue? :|
ShiftPlusOne
Mon May 14, 2018 7:41 am
ejoagoz wrote: I think he says Recalbox load but doesn't show image. I have same problem with Noob 1.8.1. It should be a problem with default screen resolution. Any clue? :|
Yup, that's the behaviour you get when bootcode.bin and start.elf don't match, which will be the case until Recalbox is updated.
